Toymods » Tech & Conversions » AE86 alternator position
ae95
AE86 alternator position Tue, 27 January 2004 12:47 Go to next message
Hi guys,
In my 4age ae86 my alternator is mounted underneath the dizzy with the alternator bracket attaching to the head (where one of the bolts used to hold the dizzy tight is)
well anyway that bolt has been snapped into the head so the alternator flops around with hardly any tension on the belt. so im thinking of relocating under the inlet manifold. can this be done with stock brackets? which ones do i need?
slydar
Re: AE86 alternator position Tue, 27 January 2004 13:32 Go to previous messageGo to next message
i would suggest just go have a look at an import yard, and buy an entire setup.
dont forget to check out 4ac, 4af and 7af set ups too.
[Updated on: Tue, 27 January 2004 13:35]
shinybluesteel
melbourne
Re: AE86 alternator position Tue, 27 January 2004 21:48 Go to previous messageGo to next message
hmm, what 4AGE is it? a RWD one? the alternator on my smallport is already under the inlet manifold. i think the best thing for you to do is remove the bolt and put a new one in, unless it is really hard to get out.
there could be holes on the other side, dunno.
o
ae95
Re: AE86 alternator position Wed, 28 January 2004 07:19 Go to previous messageGo to next message
The snapped bolt has a easy out snapped into it which makes it almost impossible to remove.
i believe it is a rwd 4age but i am not sure since the car has been converted
Flogbag
Sydney (Campbelltown...!)
Re: AE86 alternator position Wed, 28 January 2004 07:31 Go to previous messageGo to next message
if u cant relocate it easily there are thread and weld guys that come to you
i used to have a mini and a engine mount bolt snapped on the block n so did the easy out he drilled it out and fitted a helicoil for about $100
Re: AE86 alternator position Wed, 28 January 2004 07:43 Go to previous messageGo to next message
ae95 wrote on Wed, 28 January 2004 15:19
Goddamn, I have never snapped an easy out, it musta been well rusted/stuck in there
ae95
Re: AE86 alternator position Wed, 28 January 2004 07:47 Go to previous messageGo to next message
apparently easy outs snap pretty easily Sad
Re: AE86 alternator position Wed, 28 January 2004 07:55 Go to previous messageGo to next message
An easyout should be fiarly easy to get out, coz it will only just be gripping, so I would attempt to get that out first, (maybe drill it out, I can't see it being to hard), and then go and buy an expensive one.
There is no point pissing around trying to move the alternator if you can put it back easily.
You said the bolt is going into the head, so thats ali, which shouldnt be too hard. Try again I saw, maybe with the next size easyout
ae95
Re: AE86 alternator position Wed, 28 January 2004 08:46 Go to previous messageGo to next message
yeah, the problem is you need a really hard tipped drill bit to drill into the easy out.
ae95
Re: AE86 alternator position Wed, 28 January 2004 08:49 Go to previous messageGo to next message
would there be a problem with drilling a new hole in the head next to the old hole?
Re: AE86 alternator position Wed, 28 January 2004 15:33 Go to previous message
I'd say so
There may not be enough strength there to hold the forces an alternator at full revs might give.
I still say buy a quality bit, and quality easyout and try again
for the $15odd it will cost, it could save a lot of hassles.
And if it fails, your no worse off.
Previous Topic:no oil at all
Next Topic:idle revs for a sprinter
Current Time: Fri Nov 20 13:51:30 UTC 2026
Total time taken to generate the page: 0.0049951076507568 seconds
