Toymods » Tech & Conversions » idle revs for a sprinter
Panda Tofu ^_^
idle revs for a sprinter Tue, 27 January 2004 16:12 Go to next message
just wondering what the average idle revs for a sprinter with a 4ac is cos mine was playing up a bit today and i fixed it but not sure if the revs are still abnormal, currently sitting at 1.5 at idle
TA22
Re: idle revs for a sprinter Tue, 27 January 2004 16:52 Go to previous messageGo to next message
dont quote me on it but i assume it should be about 800 to 900 rpm?
would anyone know what the timing should be on this engine?
NickAE86
Brisvegas
Re: idle revs for a sprinter Wed, 28 January 2004 02:10 Go to previous messageGo to next message
mine sits on 800rpm Very Happy
FKN16V
NSW, East Coast
Re: idle revs for a sprinter Wed, 28 January 2004 02:12 Go to previous messageGo to next message
TA22 wrote on Wed, 28 January 2004 03:52
That idle seems about right. Timing should be @900rpm max 13 deg btdc.
What seems to be the drama.
Steve
Panda Tofu ^_^
Re: idle revs for a sprinter Wed, 28 January 2004 02:38 Go to previous messageGo to next message
800 Sad bugga mines sits at 1300 till i give it a little throttle and it goes down to 1000-1100 :/ i know its only 200rpm or so over its still peace of mind i'm after Smile ne ideas?
Callifo
Gawler, SA
Re: idle revs for a sprinter Wed, 28 January 2004 06:27 Go to previous messageGo to next message
When you first turn the car on its about about 800rpm on mine but once it warms up it sits around 600rpm. When the aircon is on though sometimes it makes it idle rough until you rev it and it goes back to idling normally again.
Flogbag
Sydney (Campbelltown...!)
Re: idle revs for a sprinter Wed, 28 January 2004 07:22 Go to previous messageGo to next message
when i was tuning my 4AC i went on auto-tech encyclopedia and it had
spark plug gap 0.8mm
timing 3-7(deg) @ 900rpm
points gap 040-0.50
dwell angle 50-54
idle speed man 750 auto 800
valve clearance (hot not running) In 0.20mm Ex 0.30mm
i set mine up to that but advanced the timing a lil till it pinged then backed it off slightly cant remember wat it is but and it runs sweet as...
theres a sequence but
1 point gap
2 timing
3 idle mixture
4 idle speed
set it up in that sequence n u should be ok
Panda Tofu ^_^
Re: idle revs for a sprinter Wed, 28 January 2004 13:47 Go to previous messageGo to next message
thanx for the input fellas i'll give it a go.
TA22
Re: idle revs for a sprinter Wed, 28 January 2004 14:52 Go to previous messageGo to next message
i reckon if ur cars running a bit high it might be ur return spring on the throttle, u should give it a look as i had that problem with mine.
My girlfriends got the 4a engine and ive adjusted the timing accurately, it does not ping, and its not too retarted, and when she switches the car off, it keeps running for a sec and makes a screech noise like a belt is slipping. any ideas?
TA22
Re: idle revs for a sprinter Wed, 28 January 2004 14:55 Go to previous message
hey Flogbag, whats that auto-tech encyclopaedia?
Previous Topic:AE86 alternator position
Next Topic:Where to buy Celica st162 Quick shifter??
Current Time: Fri Nov 20 14:37:14 UTC 2026
Total time taken to generate the page: 0.0072240829467773 seconds
