Toymods » Tech & Conversions » Exhaust mani gaskit goo?
chrisss
melb
Exhaust mani gaskit goo? Wed, 28 January 2004 06:29 Go to next message
$45 for a 5me ex mani gaskit - screw that!!!
any sealant that I can use? it only has a small leak but wont pass roadworth apparently.
its for the head-mani.
da_snuff
Hobart
Re: Exhaust mani gaskit goo? Wed, 28 January 2004 07:18 Go to previous messageGo to next message
yeh you can buy gasket sealer, not sure if it has a technical name or anything lets just leave it as gasket goo... but yeh i dont think it costs much, just a few bucks from supercheap or wherever u shop.
SeptemberSquallIndustries
Re: Exhaust mani gaskit goo? Wed, 28 January 2004 07:27 Go to previous messageGo to next message
RTV silicone gasket compound.
This stuff needs to be applied like a replacement gasket though, so you'd still have to remove the manifold and clean/face the contact surfaces for it to work. You can't just squirt it on the outside. When you torque the surfaces together, don't torque them too tight or the compound is squeezed too thin and will fail.
I've got some and am in Melbourne too, come borrow a bit if you want.
chrisss
melb
Re: Exhaust mani gaskit goo? Wed, 28 January 2004 08:13 Go to previous messageGo to next message
RTV compound eh.
I was thinking of reusing the gaskit and just using some goo on each side to help it seal.
septemberSquallInd, yeah where did you come up with that name, where bouts in melb r u?
Re: Exhaust mani gaskit goo? Wed, 28 January 2004 08:32 Go to previous messageGo to next message
I live in St. Kilda and frequently commute through the north, north-east, east and south-eastern suburbs. Hit me with a PM if I can be of any help.
RTV is what is printed on my tube, dunno if that's a brand/trade mark or actually a technical description of the product. Asking for silicone gasket compound will yield results.
The product is designed to completely replace the original gasket. There'd be no benefit to using it in conjunction with the original gasket, especially if it is already broken.
[Updated on: Wed, 28 January 2004 08:33]
chrisss
melb
Re: Exhaust mani gaskit goo? Thu, 29 January 2004 01:27 Go to previous messageGo to next message
thats it guys no further info?....yeah its a boring subject but u can do better.!!
Re: Exhaust mani gaskit goo? Thu, 29 January 2004 04:39 Go to previous messageGo to next message
What more information do you require? We've already told you the following:
What it's called:
Where to get it:
How much it costs:
How to use it:
...and we've even offered to [B]give[/B] you some and help you with your problem, even deliver it for you!:
Do better? How? By using magical think-power to fix your car sight-unseen? FFS if you want more info ask a specific question. What info do you need? We're not ESP-enabled here.
[Updated on: Thu, 29 January 2004 12:29]
chrisss
melb
Re: Exhaust mani gaskit goo? Thu, 29 January 2004 08:19 Go to previous messageGo to next message
ok dude you are obviously psychotic, think ill pass on your offer. Rolling Eyes
I just wanted to hear from someone who had actually had experience with the exact problem I have. Cool
I checked these silicon compounds out and the max temperature they can handle is 315 deg. Confused
anyway anyone who wants to contribute something without the attitude is welcome. Smile
Re: Exhaust mani gaskit goo? Thu, 29 January 2004 12:34 Go to previous messageGo to next message
I've used this product to seal an exhaust leak before.
I used a silicone-based gasket compound to seal my turbine exhaust housing gasket. It lasted for long enough for me to save the $50 for a real gasket next time I had the turbo off (about 3 months). You may be able to find compounds with different heat resistance ratings, like heat-rated engine/exhaust/brake enamels.
If you're not happy with the durability of a silicone gasket compound you may need to consider other options - like a real gasket maybe.
[Updated on: Thu, 29 January 2004 12:35]
Allan
Re: Exhaust mani gaskit goo? Thu, 29 January 2004 12:45 Go to previous messageGo to next message
i use CRC maniseal much better!
Allan
Re: Exhaust mani gaskit goo? Fri, 30 January 2004 10:53 Go to previous messageGo to next message
Yeah I've always tended to use maniseal for the exhaust, it goes slightly nasty after it's been 'baked' for a while, but it does seem to do the job, at least for a while (I tend to get my turbo manifold glowing brightly quite regularly, that might be part of the issue!) Evil or Very Mad
7M-Brisbane
Re: Exhaust mani gaskit goo? Sat, 31 January 2004 12:44 Go to previous messageGo to next message
I don't think that $45 is unreasonable for an exhaust gasket... if anything I'd have said that was a GOOD price Rolling Eyes
chrisss
melb
Re: Exhaust mani gaskit goo? Sun, 01 February 2004 01:48 Go to previous message
yeah but its for my mx62. spending 45 dollars on a car thats only worth 1000 is a lot!!
Previous Topic:Running rich ST162
Next Topic:the art of intercooler pipe leaks?
Current Time: Sun Oct 25 23:22:41 UTC 2026
Total time taken to generate the page: 0.038191080093384 seconds
