Toymods » Tech & Conversions » AE86 clutch line with 4age conversion
Flogbag
Sydney (Campbelltown...!)
AE86 clutch line with 4age conversion Wed, 28 January 2004 07:40 Go to next message
hey
just wondering wat u all do with the clutch line being in the path of the exhaust??
ive seen it where ppl have bent the pipe a lil n had the flexi line going over the pipe but thats a lil rough can you get longer flexi lines made up n kinda loop it over the exhaust so its a bit away n doesnt get affected from the heat
at work i have seen the new rodeos have the clutch line kinda near the exhaust n they have a chunky rubber secton with another metal heat protector that goes over the flexi lines...
ideas anyone...?
IRA11Y
Club Member
Re: AE86 clutch line with 4age conversion Wed, 28 January 2004 09:39 Go to previous messageGo to next message
get a custom line made up from brake hose.. any brake specialist can do this for around $60
Flogbag
Re: AE86 clutch line with 4age conversion Wed, 28 January 2004 10:05 Go to previous messageGo to next message
custom hose
u mean from the guard where the steel line ends to the slave cylinder??
long enought to go high n over the exhaust pipe
Necros
Re: AE86 clutch line with 4age conversion Wed, 28 January 2004 11:01 Go to previous messageGo to next message
Anthony Kellam <akellam@optusnet.com.au> sells 4-1 TRD style extractors and also clutch line kits to go over them...
From memory he charges $40 or sumtin for the clutch line...
FKN16V
NSW, East Coast
Re: AE86 clutch line with 4age conversion Wed, 28 January 2004 11:02 Go to previous messageGo to next message
Exhaust tape is all you'll need, cost me $20.
Just make sure who ever installs the exhaust keeps the line as far away as possible from the exhaust and you'll have no dramas.
Ill be in campbelltown on thursday if you want to look.
Steve
[Updated on: Wed, 28 January 2004 11:05]
shindeokure
melbourne
Re: AE86 clutch line with 4age conversion Wed, 28 January 2004 13:44 Go to previous messageGo to next message
i bought a hose kit from anthony kellam which loops over the exhaust and i don't have any problems, but if you're really fussy and have time/money, source out the japanese ae86 bellhousing as the clutch-fork sticks out the opposite side.. and run a new line to it.
cswan
icon5.gif  Re: AE86 clutch line with 4age conversion Sun, 01 February 2004 05:04 Go to previous messageGo to next message
I've used the standard clutch to a 4A based T50 gearbox and I've had no probs.
...Not sure everyone means by "over the exhaust"....
EVOSTi
cambo
      no
Re: AE86 clutch line with 4age conversion Sun, 01 February 2004 09:51 Go to previous messageGo to next message
i run the hose right near the exhaust with no probs.
Green_Comet
Victoria, Melbourne
Re: AE86 clutch line with 4age conversion Thu, 05 February 2004 02:32 Go to previous messageGo to next message
I wanted to order a set of extractors and clutch line kit from Anthony Kellam, but im finding it hard to get in touch with him, he isnt answering him email!! Confused
JDM hachi
was adelaide now newcastle
Re: AE86 clutch line with 4age conversion Thu, 05 February 2004 03:10 Go to previous messageGo to next message
i found that swapping the clutch line over with the bleed nipple at the slave cylinder gave me enough length to avoid the exhaust, there were no problems for me when i did this., give it a go, if it doesn't work for you, then get the custom one.
matty.
c2888
Re: AE86 clutch line with 4age conversion Fri, 06 February 2004 01:36 Go to previous message
I was trying to think why you guys were having problems, as i couldn't remember that i did change it.
I also swapped mine like jdm hachi. hose for nipple, you have to pull the olive out and swap that to the other hole too.
The only time my pedal is affected is if i idle in one spot for 5 mins or more, tends to go a bit soft. But once moving it's all good, bit of airflow. Stupid extractor wrap tape, ran out about 10cms short of the clutch slave.
dodgydan
Previous Topic:Best place to get nuts and bolts - NorthShore, Syd area
Next Topic:3S-GE turbo project
Current Time: Thu Nov 19 14:11:15 UTC 2026
Total time taken to generate the page: 0.029562950134277 seconds
