Toymods » Tech & Conversions » s/c problems
mr_rolla
icon8.gif  s/c problems Thu, 29 January 2004 01:20 Go to next message
Hi all.
I have a AE92 SX with a 4AGZE installed. Everything has been running fine for the last 12mnths until.......
3 days ago i heard what can only be described as an awful grinding and rattling sound coming from what I thought was the water pump. After closer inspection I discovered it was actually the S/C.
I have taken the front cover of the s/c pulley and found that the cover has been deformed and damaged and there are metal filings on the inside of the pulley. (I have some pics but don't know how to add them to this).
What I am actually wondering is:
a. has anyone had this problem before?
b. Can the pulley be replaced with a fixed one (no clutch)
c. how do I remove the pulley without removing the motor?
Any feed back would be appreciated.
Daniel
Does anone have a 4AGZE Map out of a car at the monemt?
Can you take a pic of the front of the s/c pulley with the cover off?
[Updated on: Thu, 29 January 2004 04:18]
mr_rolla
Re: s/c problems Thu, 29 January 2004 04:26 Go to previous messageGo to next message
anyone got some pics?
SXer
Re: s/c problems Thu, 29 January 2004 06:15 Go to previous messageGo to next message
could it be the s/c clutch? You didn't happen to manually engage the s/c with a switch did you? Just guessing here... Sad
mr_rolla
Re: s/c problems Thu, 29 January 2004 09:07 Go to previous messageGo to next message
It could be im not entirely sure. I havn't been able to remove the pulley to see it the clutch is damaged.
speedchaser
Malaysia
Re: s/c problems Thu, 29 January 2004 10:59 Go to previous messageGo to next message
It's nearly impossible to take the SC pulley out without taking the whole SC out of the car. You could try though.
If you need a smaller SC pulley with clutch, let me know.
mr_rolla
Re: s/c problems Thu, 29 January 2004 11:53 Go to previous messageGo to next message
Thanks.
Ill give it a go tomorrow. Do you know how it is held on? (the pulley) I cant see the centre of the pulley, its a tight squezze.
speedchaser
Malaysia
Re: s/c problems Thu, 29 January 2004 17:46 Go to previous messageGo to next message
This is how the SC looks when you remove the clutch.
http://www.speedchaser.net/images/Pulley_Removal.JPG
We used a screwdriver to knock the nut out and you have the whole pulley out of the SC. Then you'll see the magnet underneath.
mr_rolla
Re: s/c problems Thu, 29 January 2004 22:56 Go to previous message
Thanks.
But does the clutch just pull out?
Previous Topic:AE86 wheel offset
Next Topic:5S-FE Timing Belt
Current Time: Fri Oct 23 18:27:54 UTC 2026
Total time taken to generate the page: 0.0044710636138916 seconds
