Toymods » Tech & Conversions » Wiring a 1ggte into a ra23
Testa_Dura
Wiring a 1ggte into a ra23 Thu, 29 January 2004 04:46 Go to next message
i am having extreme difficulty in doin this myself as i cant get enough power to the igniter for some reason. Does any1 know of anybody who can make a loom to suit for a reasonable price? or perhaps have some wiring diagrams of a gen 3 engine? i have searched the archives and the diagrams that say gen3 all have different plugs and different colour wires. any help would be greatly appreciated
Dave
Re: Wiring a 1ggte into a ra23 Thu, 29 January 2004 04:51 Go to previous messageGo to next message
Where are you currently getting the power from for your igniter? If there's not enough power you need to create a new circuit from the battery using a relay and of course a fuse.
FKN16V
NSW, East Coast
Re: Wiring a 1ggte into a ra23 Thu, 29 January 2004 04:58 Go to previous messageGo to next message
try Grant of Sixworks, he may be busy, but it never hurts to try.
I believe he specializes in this sort of stuff.
he also has an article in this type of install in the article section.
Good luck.
Steve
ddeane
PNG
Re: Wiring a 1ggte into a ra23 Thu, 29 January 2004 05:28 Go to previous messageGo to next message
Hi
Are you sure that it is a Gen 3? As the wiring diagram in the gallery is for a gen 3. All the ones that I have seen have 26 pins on the large plug. If your has only 24 you might like to consider it to be a gen 2 There are pinouts for a gen 2 in the gallery. You might also do a search as I have posted a thread last year on the range of differences between a gen 2 and 3.
Craig
Testa_Dura
Re: Wiring a 1ggte into a ra23 Thu, 29 January 2004 07:42 Go to previous message
Thanks for the advice guys. i'm getting the power for the igniter and injectors just off the ecu at the moment. i was going to run a seperate power line from the battery to these however i don't know which wire is the power one on the igniter as the colours dont match with any diagrams i have. the diagram i have also shows a 4 pin plug on it where mine is a 6 pin plug. Does anybody have a number that i can contact Grant from Sixworks on?
Previous Topic:ULP filler
Next Topic:Can a stock 1JZ ECU run a single turbo
Current Time: Fri Nov 20 13:22:24 UTC 2026
Total time taken to generate the page: 0.031455039978027 seconds
