Toymods » Tech & Conversions » people running 4AGE with aftermarket ecus's
IRA11Y
Club Member
people running 4AGE with aftermarket ecus's Thu, 29 January 2004 07:47 Go to next message
do any of you have your basic map details for the 4AGE from your supplier?
im after a simple safe map to check against my own ign, inj, load and rpm points to make sure i can run in the new engine safely (still learning to play with these bloody things ) before getting the full dyno done once the kms are up.
any help would be good
ps i allready have a heavily modified map from a race engine i just need the basic 4A map
so even if you just have moderate cams it will be fine for me to double check on
Grega
melbourne.victoria.austra...
Re: people running 4AGE with aftermarket ecus's Thu, 29 January 2004 09:44 Go to previous messageGo to next message
michael
get on the haltech website - get the windows software and there is a 4AGE map in there - should help you along mate.
IRA11Y
Club Member
Re: people running 4AGE with aftermarket ecus's Thu, 29 January 2004 18:42 Go to previous messageGo to next message
got the software, but couldnt find a specific 4AGE map... can you direct me to where id find it in the software?
TerryOBeirne
Redbank Plains,near Ipswi...
Re: people running 4AGE with aftermarket ecus's Thu, 29 January 2004 20:26 Go to previous messageGo to next message
I have Motec maps, but they are un-useable without the ECU
IRA11Y
Club Member
Re: people running 4AGE with aftermarket ecus's Fri, 30 January 2004 05:12 Go to previous messageGo to next message
terry i just need the numbers at each 250rpm and 12.5% band point for Ign and Inj. basically i want to emulate a base map as a starting point to run in my engine then ill dyno it to get much better performance.
so if you can provide that information ill give you a big Hug Smile
i have the microsoft software for Motec but im not sure if i can get the maps to come up without the ecu???
Grega
Re: people running 4AGE with aftermarket ecus's Fri, 30 January 2004 06:46 Go to previous messageGo to next message
michael
download the E11 software (its here : http://www.haltech.com.au/downloads/Halwin_V1_3_ex press.zip)
install the software
run it
select file
load all maps
select c:\program files\haltech\halwinv1_3\basemaps\toyota
select 4AGE-multitooth.map
click open
then select what you need to look at in ignition/fueling whatever
if you can't get this to work let me know and i'll help
grega
[Updated on: Fri, 30 January 2004 06:47]
IRA11Y
Club Member
Re: people running 4AGE with aftermarket ecus's Fri, 30 January 2004 09:10 Go to previous messageGo to next message
thanks grega... just spent an hour recalibrating each point... arrggghh my eyes are hurting Sad
will see what happens tomorrow Rolling Eyes
cswan
Re: people running 4AGE with aftermarket ecus's Sun, 01 February 2004 04:59 Go to previous message
The motec maps will be editable without the ECU.
I've recently put an M4 on a 100kw motor with huge cams and have managed to get it running OK (but I'm now out of wide-band lambda support!).
If you need any help with the calibrations of the sensors, I'd be happy to help but I won't be back home until mid next week.
Let me know how you're going. It's great fun using the Motec.
If you're willing, I'd love to have a look at the race tuned map for interest sake.
Previous Topic:3SGTE into ST184
Next Topic:1ggte questions
Current Time: Mon Nov 2 06:06:46 UTC 2026
Total time taken to generate the page: 0.03929591178894 seconds
