Classifieds » Parts Wanted » pair of 304 cams
Pheonix
Wa
pair of 304 cams Thu, 29 January 2004 09:35 Go to next message
hey guys im lookin for a pair of 304 cams for a 2t-geu head to go in my hybrid, thanks
CelicaRA45
nth ringwood, Victoria
Re: pair of 304 cams Sun, 01 February 2004 01:44 Go to previous messageGo to next message
as i have the master for them you would have to send me a pair of std 1s to be hardfaced or welded up then sent back to you about 450 round trip as im in melb send them by post and the guy will take 2weeks and them i send them back to you
Pheonix
Wa
Re: pair of 304 cams Sun, 01 February 2004 03:31 Go to previous messageGo to next message
450 is pretty good, wat are the specs of the master as in lift duration overlap etc. also since u are out sourcing how good a rep do these guys have cause i cant just send them bak if they are stuffed
ed_ma61
Lost in the K hole
Re: pair of 304 cams Sun, 01 February 2004 05:01 Go to previous messageGo to next message
damn good Nod
CelicaRA45
Re: pair of 304 cams Sun, 01 February 2004 09:34 Go to previous messageGo to next message
i have none this guy for 25 years and his work is spot on the specs on the trd 304 are 10mm lift also you could use the 288 on the exhaust these profiles were trd rally spec ,is your engine 1600 or 1800 or bored out to 2000 also ,cause they were used on the 2tg and 18rg for rallys over lap with the 304 on exhaust could be aproblem depends on how deep you valve reliefs are the specs are 304 10mm lift 260 at 50 from memory 288 9.6mm lift about 250 at 50 i have the set up here some where 104% at atdc and 104 btdc
Pheonix
Wa
Re: pair of 304 cams Tue, 03 February 2004 10:37 Go to previous messageGo to next message
the engine is goin to be using the 3t-c block with the 2t-geu head and 86mm pistons (i think from memory) so it would be around 1.9L area. the plan was to have 304/304 cams with some head work, oversized valves, larger injectors, etc. Ive read on toysport.com that the hubrid runs well with a 304/304 setup, heres the address http://www.toysport.com/webpages/Techinfo/Enginemo d/2tg_18rg_3tg_tech_notes.htm
yeah im very interested in getting the cams made Very Happy
CelicaRA45
Re: pair of 304 cams Wed, 04 February 2004 05:27 Go to previous message
can get them from trd japan 540 each plus postage these are billets
Previous Topic:ae82 twin cam front hubs
Next Topic:TA22 rear Springs Upper insulator
Current Time: Thu Nov 19 18:43:30 UTC 2026
Total time taken to generate the page: 0.0061180591583252 seconds
