Toymods » Tech & Conversions » Supra GB in an AE86
Sprinter
Supra GB in an AE86 Thu, 29 January 2004 10:25 Go to next message
Hi all,
Which extension housing do I need with a Supra gearbox (W55/W57/W58/etc) for the best fitting through the standard shifter hole in the floorplan?
I know a few of you have already done this but havent easily found the answer searching the forums!?
Many thanks,
Denis
Re: Supra GB in an AE86 Thu, 29 January 2004 11:43 Go to previous messageGo to next message
RA60 W57, although chances are you'll still need to move things around a little bit Evil or Very Mad
Necros
Re: Supra GB in an AE86 Thu, 29 January 2004 14:52 Go to previous messageGo to next message
Will that sit the shifter slightly forward or back of the std hole?
It would be nice to bring the shifter back and inch or two...
Re: Supra GB in an AE86 Thu, 29 January 2004 23:42 Go to previous messageGo to next message
Probably be a tad far forward still. Trick is to do what I did with mine, cut the stick off about ¼" above the pivot, and weld a piece of flat steel on there then more it to where you like. Also a hint if you're using the Dellows bellhousing: your gearbox will end up on an angle, therefore if you don't cut the stick off, the gearstick ends up pointing horribly to the left... Evil or Very Mad
Necros
Re: Supra GB in an AE86 Fri, 30 January 2004 00:31 Go to previous messageGo to next message
From your exp with the dellow bell housing I think ill steer clear of em ;p Ill probably mod a RA60 W57 bellhousing!
Re: Supra GB in an AE86 Fri, 30 January 2004 00:32 Go to previous messageGo to next message
Whats to stop you from using one of the rear shifter housings? The ones from the Mk3 Supra's actually come out the back of the hole.
[Updated on: Fri, 30 January 2004 01:56]
Re: Supra GB in an AE86 Fri, 30 January 2004 01:54 Go to previous messageGo to next message
Mk2 W58's have the shifter in the middle position, same as the RA6x. It's the Mk3 boxes that have the rear shifter position.
Re: Supra GB in an AE86 Fri, 30 January 2004 01:55 Go to previous messageGo to next message
Dammit, my bad, thats what I meant Sad
Re: Supra GB in an AE86 Fri, 30 January 2004 10:56 Go to previous message
Although, despite my thoughts on the dellhousing, that starter motor hole on the other side might well prove useful in the end Evil or Very Mad I'll see how it goes when I get round to taking my engine out! Evil or Very Mad
Previous Topic:1ggue throttle bodies
Next Topic:carbie cleaner = lacquer thinner?
Current Time: Thu Oct 22 10:52:00 UTC 2026
Total time taken to generate the page: 0.0057320594787598 seconds
