Toymods » Tech & Conversions » ST205 brakes on a 185
Puffy
ST205 brakes on a 185 Thu, 29 January 2004 12:21 Go to next message
Hi Guys,
Finally got my hands on a set of 205 brakes Very Happy (thanks Joe) and am about to attempt the conversion. Anyone done this or knows what is exactly involved.
Question ?
The 205 rotors are huge Shocked and sit deeper on the hub. The lower ball joint underneath is just touching the disc at the moment. Is a spacer necessary between the hub and the disc or will clearence increase once the car is lowered and the arms straighten. The hub has a little bit of play back and forth and was wondering if this will give me more clearence once the CV's are installed and tightened as I think this will push the hub out. Im just not sure if this will be enough.
Thanks,
Anhar Khamas
GT4 Group A Carlos Sainz #13
wiso
Re: ST205 brakes on a 185 Thu, 29 January 2004 14:16 Go to previous messageGo to next message
I think you would need a spacer of some sort, but if this is not safe enough maybe you would need 205 hubs? I was told that no matter what you do 205 rotors don't seem to balence properly on a 185, I know JustenGT4 attempted this but gave up cause it was too difficult, instead he had custom rotors made up. try PMing him and alert him to this thread.
Puffy
Re: ST205 brakes on a 185 Fri, 30 January 2004 09:30 Go to previous messageGo to next message
From memory Justen did finish the conversion as I saw it at a toymods dyno day a couple of years back. I spoke to him and he gave me a few pointers Smile ...... thanks wiso for the direction.
What I am now wondering is would the whole 205 hub and all bolt up to the existing parts eg steering arm, suspension etc to make this conversion a true bolt on?
Anhar Khamas
GT4 Group A
Classique71
Colac, Victoria
Re: ST205 brakes on a 185 Fri, 30 January 2004 10:33 Go to previous messageGo to next message
i believe they do eventually go on though machining of the disc is needed , and you need a spacer + the calipers have to be threaded somehow ..
Check alltrac.net puffy - i think theres a " how to " there
though better than our stoppers - from what ive also heard they weigh an absolute tonne but if you CAN do them - go for it - they sure as hell will stop better than the single floaters..
the back st205 twin pots are pretty much bolt on - bar having to remove the dust shield - or modify via a persuadometer so it has the clearance ..
Ill be chasing 205 back's but most likely go stupid and see justen about his custom front rotors .. Apparantly they leave the 205 ones begging ..
[Updated on: Fri, 30 January 2004 10:35]
spectral
Re: ST205 brakes on a 185 Fri, 30 January 2004 10:38 Go to previous messageGo to next message
There is also the Wilwood 4 pot kit with 325mm rotors that is going for $1195 or something USD.
Its a bolt on kit that has all the lines and brackets to hook up.
With the good exchange rate, its probably quite a decent buy.
Double check the legality of bits thou :S
EDIT: http://www.alltrac.net/tuning/brakefaq.html is the link Stuart was referring too.
[Updated on: Fri, 30 January 2004 10:40]
Puffy
Re: ST205 brakes on a 185 Fri, 30 January 2004 11:05 Go to previous messageGo to next message
Stuart I found that this is very basic information compared to whats really involved but Justen gave me measurements which is what I was looking for.
The 205s are aluminum calipers and even though they are more then double the size of the originals, they weigh about the same if not less.
Spectral - Thats not a bad price at all considering that willwoods are the lightest and one of the most durable calipers out there. I did go to Racebrakes and they use 4 pot AP calipers, DBA rotors, braided lines, Race pads, and AP fluid for about $2600 AUS fitted which aint too bad.
I just went for the 205s because its gonna give me the best $$ vs gain.
Anyone that wants to pull apart there 205 to answer my Question about interchangeable hubs please feel free to do so Rolling Eyes
Anhar Khamas
GT4 Group A
Classique71
Colac, Victoria
Re: ST205 brakes on a 185 Fri, 30 January 2004 11:12 Go to previous messageGo to next message
haha ! ask gary too Smile
and while hes at it he can pull apart his intercooler setup to show me how mine should roughly go on Smile
Nods to the brakes though - im going on heresay - personally id love any brakes better than what i have - and even they arent half bad ..
mind you - your car puts out a lot morre ponies than mine so any upgrade to Stop is a good thing
Puffy
Re: ST205 brakes on a 185 Fri, 30 January 2004 11:39 Go to previous messageGo to next message
"mind you - your car puts out a lot morre ponies than mine so any upgrade to Stop is a good thing"
At the moment the only power Im making is about 0.02kw at the cigerette lighter but the goal is 200kw / high 11 to a flat 12sec pass - which ever comes first.
Gary..... do you hear that. I have a Supa Cheap shifter and Im on my way to your place.
Anhar Khamas
GT4 Group A
spectral
Re: ST205 brakes on a 185 Fri, 30 January 2004 11:40 Go to previous messageGo to next message
200Kw will come first Smile
Classique71
Colac, Victoria
Re: ST205 brakes on a 185 Fri, 30 January 2004 11:55 Go to previous messageGo to next message
Anhar - SOunds like you and I are aiming for around the same ballpark - though im aiming or a better time around phillip island - then i am along a dragstrip Smile
Im already on the way to the magical 200kw Smile
Got a group A motor on the way - thats going to be slowly built up to slot in Smile
Just need to find one of those damn Group A gearboxes in time !PS i knew you were going the 205 motor swap - but did you stick with the ct20b - or upgrade further ?
Im looking at highflowing my ct26 with a 50 ish trim + ecu + injectors + cams + forgies
[Updated on: Fri, 30 January 2004 11:56]
Toobs
Re: ST205 brakes on a 185 Fri, 30 January 2004 21:32 Go to previous messageGo to next message
I hate to say it but most 4WD cars make pretty poor drag cars... the only way to get a GT4 going hard at the start is to do a 3500-4000rpm clutch dump... obviously this is not very clutch friendly and would put quite a lot of strain on the gearbox & driveshaft/s...
According to most people I have spoken to about GT4's say you would need to be doing quite a bit of work to get 200+kw at all 4...
To get to 200+ from what I gather you would need the following level of hardware at minimum: (this is what was / am considering)
-Twin plate clutch
-Garrett GT30+ (maybe GT35...) and external wastegate etc. to go with
-Large FMC
-Forgies
-Head job
-ARP head studs / bolts etc.
-HKS metal head gasket
-Full Aussie exhaust system (i.e. dump pipe back)
-New ECU (Haltech? MoTeC?)
-Strengthened gearbox (cryogen?)
Should be able to run 20psi constantly and 30+ on the track with this type of setup and even then from what I hear its still unlikely that you would break 200kw at all 4...
You would prob be looking at 15-20K worth of mods to get 200+
Actually I would like to know of anyone that has gotten 200+ in a GT4 with street legal hardware... Seriously!
Puffy
Re: ST205 brakes on a 185 Sat, 31 January 2004 02:09 Go to previous messageGo to next message
Talk about gettin side tracked from the topic.
Toobs, I agree fully that GT4's are a very poor choice for a drag car thats why I want to do it.
I guess you do not know what hardware I using but lets say its far from stock. The car with the old 185 (internally standard)setup pushed out a 174kw @ all wheels at a moddest 1 bar. Since then I have reduced the cars wieght to 1290kg and just installed a new GEN III motor.
The Group A gearbox and driveline is almost industructable.I launch nothing under 5000 rpm and yes I have chewed up 4 clutchs and re sculptured some interesting pressure plates but thats what drag racing is about , pushing the limits.
A pod filter these days are considered illegal so what do you mean by street legal.
Anhar Khamas
GT4 Group A
Toobs
Re: ST205 brakes on a 185 Sat, 31 January 2004 07:10 Go to previous messageGo to next message
Sorry somebody said 200+kw gtfour Smile
Classique71
Colac, Victoria
Re: ST205 brakes on a 185 Sat, 31 January 2004 09:41 Go to previous messageGo to next message
heh - Anhars right - 180kw is obtainable quite easily with highflowed ct26, some strengthening of the internals , and a decent clutch setup
Steve bignalls machine using a highflowed ct26 , lightened internals - and some other custom goodies turns over 260Kw at the treads - and is daily driven .. thats BEFORE he give it some giggle gas ..
Its not impossible thats for sure - read up on that zoom 3sgte tuners guide for a nutshell rundown of whats needed to pump out 200 kw
Anhar again - getting BACK on topic - can you please take a heap of pics and maybe write up in detail how yopr heading with the 205 swap .. A good tech " how to " would be bloody handy ..
Puffy
Re: ST205 brakes on a 185 Sat, 31 January 2004 10:35 Go to previous messageGo to next message
I will definitly do a write up with pics as a reference for people that would like to attempt this in the future. I would just like to know if the hub transplant would be an option because if this mod can be exacuted with no fabrication then it would prove very popular for all 185 owners.
Anhar Khamas
GT4 Group A
Classique71
Colac, Victoria
Re: ST205 brakes on a 185 Mon, 08 March 2004 09:14 Go to previous messageGo to next message
Hows the write up on this going puffy ?
Btw - are you using the 205 rears as well ? if so do you change the rotor or keep the existing one and change just the calipers ?
Puffy
Re: ST205 brakes on a 185 Mon, 08 March 2004 13:00 Go to previous messageGo to next message
I dont have the rears Sad but know from people that have done the rear upgrade that its pretty much a bolt on conversion.
I have machined the discs down to 300mm . Tapped the caliper and hub with a 14m thread. The spacer that push the hub out needs to be 4mm thick as this will center the disc between the capilers perfectly. 5mm is what others have used but I found that to be a mm too much.
I have done some of the write up and will put it up once complete.
JustenGT4
Re: ST205 brakes on a 185 Tue, 09 March 2004 02:05 Go to previous message
Anhar,
Too late for you now i guess but no chance in hell the 205 hub assembly bolts up to a 185. They use the wanky Super Strut front suspension which has given everyone, including TTE, nothing but trouble.
Previous Topic:Cold air Induction for ST162
Next Topic:Help - 4A-G Conversion
Current Time: Wed Nov 18 18:53:07 UTC 2026
Total time taken to generate the page: 0.0056471824645996 seconds
