Toymods » Tech & Conversions » RWD 4AGE radiator inlet and outlet pipes
demuire
Ipswich
RWD 4AGE radiator inlet and outlet pipes Fri, 30 January 2004 00:48 Go to next message
Am about to get my radiator recored and outlet pipe moved from passenger to drivers side...
Can anyone tell me how far off the center point in the car the inlet and outlet pipes are supposed to be? I've been told the inlet is 6 inches from the edge of the block, but I don't have engine in car yet so can't tell where that is...
Grega
melbourne.victoria.austra...
Re: RWD 4AGE radiator inlet and outlet pipes Fri, 30 January 2004 06:51 Go to previous messageGo to next message
fook
i used the stock ta22 radiator and got 3 cores put in it
the bottom was moved from one side to the other in the same possy
the same with the top - there is a section in the top where you can put the thing on the other side - what i did do differently with the top was put a right angle on it facing the drivers side of the car so the hose loops round in a 180 degree fashion. i used a piece of flexible/bendy hose for this.
the bottom one is a datsun bluebird hose cut down to suit.
let me know if you want a photo.
Grega
Re: RWD 4AGE radiator inlet and outlet pipes Fri, 30 January 2004 06:53 Go to previous messageGo to next message
too bad you get one anyway.
http://www.vncommodore.com/images/celica/ta22017.jpg
bit hard to see the top inlet, but you get the idea with the radiator and the angle.
demuire
Ipswich
Re: RWD 4AGE radiator inlet and outlet pipes Fri, 30 January 2004 06:54 Go to previous message
Grega: Yup, I'm using my stock KE35 one with a 3 core in it. How much did you pay for yours? I've been quoted $275.
I've more or less decided to wait till I get the engine in the car before I get the core and outlets done, at least then I'll have a better idea of where they're supposed to be... I think I only need to move my bottom one (from passenger side to drivers side) but not sure if I need to move the top one left or right on the drivers side or not...
Previous Topic:Removing boot lock
Next Topic:Neutral safety switch location in MX73 Cressida Sedan
Current Time: Sat Oct 17 22:34:38 UTC 2026
Total time taken to generate the page: 0.0047318935394287 seconds
