Toymods » Tech & Conversions » CV Boot Replacement for Drive Shaft (MA61)
ZZT231
melbourne.vic.au
CV Boot Replacement for Drive Shaft (MA61) Fri, 30 January 2004 01:02 Go to next message
Hey All,
I dilema is that there is no replacement known at the local parts store for CV Boots in the drive shafts of my Supra/Celica. Does anyone know a replacement part for the outer boots? (PNC # 04437-22020)
If I have to match it up, what compariable vehicles were fitted with similar dimentions were there?
Cheers.
HighRolla
Re: CV Boot Replacement for Drive Shaft (MA61) Fri, 30 January 2004 02:59 Go to previous message
When I bought a CV boot for my corolla it was a universal one with a few different locations to tie it i.e you could cut the boot if the thickness of the joint was larger then the largest diameter fitting of the boot (worked sweet as). If you ring up a place that specifically deals with driveshafts and boots etc they will definately kit you up with one that will fit your car. If you're doing it yourself and the boot has not long split, use a cone and a stretch boot (lubricated) to save you taking the driveshaft completely off the car and hammering the joint apart. Clean out all old grease (as much as you can) then pack it up with new grease once new boot has been put over the top using cone.
Have a quick look here
http://home.swiftdsl.com.au/~benl1981/corolla/CV%2 0Boot%20Replacement/CV_boot_replacement.htm
Previous Topic:a/c question
Next Topic:Removing Air-Conditioning
Current Time: Thu Oct 22 13:37:28 UTC 2026
Total time taken to generate the page: 0.060679197311401 seconds
