Toymods » Tech & Conversions » Running rich ST162
RWDboy
Running rich ST162 Fri, 30 January 2004 02:49 Go to next message
More qs for the ST162 boys out there.
My car always seemed to run fairly rich. Then I took the engine apart and recoed it, at the same time I got my injectors cleaned and flow tested and they flow up to 10% better now, and two of the four have a perfect spray pattern (the other two were 'off' but only very minorly).
As a result - my car now runs even richer, it smells very strongly like petrol at the exhaust and it blows dark (carbon-colour) smoke when flat-out.
Now - my oxy sensor (EGO) doesn't look like it's in its prime. I'm under the impression that the car is using closed-lamdba loop style efi setup and would adjust the mixture according the oxy sensor reading???
Is it possible that my oxy sensor is stuffed or semi-stuffed and is in no fewer terms telling the ecu to run rich? Or is this kind of rich running normal (not likely). I know that this has probably fucked my cat to hell over the past few years but I'm going to replace the exhaust system anyway.
If the EGO was totally stuffed would the ecu report it when diagnosed?
Also - where can I get a new oxy sensor from - if this is the problem? Or are there other possiblities? Let me know!
[Updated on: Fri, 30 January 2004 02:50]
RWDboy
Re: Running rich ST162 Sat, 31 January 2004 13:34 Go to previous messageGo to next message
*bump*
Alright - so someone tell me where a good place is to get a oxy sensor that'll suit my car.
Draza
Wahroonga
Re: Running rich ST162 Sat, 31 January 2004 22:53 Go to previous messageGo to next message
wrecker
FWDCelica
sydney,nsw.oz.
Re: Running rich ST162 Sat, 31 January 2004 23:55 Go to previous messageGo to next message
Dude,
NGK make one. Check out the web site.
No idea of the cost.
"http://www.ngk.com.au/content_feat.php?page=PartFi nder/sensors.php&Image=4&layer=layer2"
Read this to find out if its working:
"http://www.ngk.com.au/tech_info_oxygen_sensors_ind ex.htm"
[Updated on: Sat, 31 January 2004 23:58]
RWDboy
Re: Running rich ST162 Sun, 01 February 2004 01:13 Go to previous messageGo to next message
I'll have a look at both options and see what the cost is like!
-=NiGz=-
Compton.Sydney
Re: Running rich ST162 Sun, 01 February 2004 03:21 Go to previous messageGo to next message
Hey i got the same prob in my rolla. Got to do a EFI diagnostics on it to find the cause of the running rich prob. Pissin me off past few months. Have a feeling its my o2 sensor, but if your o2 sensor is gone wont your car idle funny?
RWDboy
Re: Running rich ST162 Sun, 01 February 2004 04:09 Go to previous message
Describe idle 'funny' Smile
Previous Topic:1ggte questions
Next Topic:Exhaust mani gaskit goo?
Current Time: Sat Oct 24 15:14:54 UTC 2026
Total time taken to generate the page: 0.0072669982910156 seconds
