Toymods » Tech & Conversions » 18rgeu rebuild questions
people100
Rocklea qld
18rgeu rebuild questions Fri, 30 January 2004 09:51 Go to next message
i am about to rebuild my 18rgeu and have a few questions.
1. is there anything i should look for first.
2. How different is the 18rc head gasket to the 18rgeu one as im pretty sure i only had a 18rc head gasket in my geu.
3. can u buy cheap valve guides from like repco or something and are they the same as the 18rc ones but im assuming there different onm the top chain.
4. Where do i find the tensions for everything or can comeone help me out with that.
basically if there is anything else i should know please let me know
Thanks alot.
Steve M
Re: 18rgeu rebuild questions Sat, 31 January 2004 14:09 Go to previous messageGo to next message
1. If you plan to replace everything that moves, not really, other than cracked head or corroded water channels. Timing chain guides and dampers (top three) are a bitch to find and $$$$$.
O ring in the top timing chain tensioner is always a good idea too, its cheap to do.
2. Yes there is a difference, and no, you probably didn't have an 18rc one in there, while they might look the same, the two stud holes in the timing case are in different locations.
Try to avoid ACL easy fit gaskets, they look really cheap and I've heared that they are shit.
Durapro GS-BK690*D is made for an 18RGEU, ours was about $67, it is a graphite/metal hybrid that was recommended to us by an automotive engineer.
3. I dunno, new ones for an 18rgeu can be sourced through machining and engineering type peoples who have the right parts book. NO they ARE NOT the same as the 18rc ones, 18rg valves are 8.5mm diameter, which is not the same as the 18rc valves.
for this reason, the valve stem seals from a toyota 2L diesol engine are the right size if you can't easily source the 18rgeu ones.
You can find the tensions in an 18rc/18rg/18rgr or 18rc/18rgu/18rgeu engine manual should you be able to find one.
If you have trouble finding one, I have one and can tell you what they are. There would be a few previous posts with many of these details if you search for them.
anything else?
If you want part numbers, I wrote them all down whan we rebuilt my brother's 18rgu last year.
Re: 18rgeu rebuild questions Sat, 31 January 2004 14:16 Go to previous messageGo to next message
FWIW you can use an 18R-C gasket if you want to. Just cut off the timing cover section, then seal that part up with gasket goo. Plenty of people have done this and it works fine. Smile
Mr DOHC
Re: 18rgeu rebuild questions Sun, 01 February 2004 00:09 Go to previous message
norbie, would u put on as normal then "fill" the gap with goo
Previous Topic:hose blocks?
Next Topic:Tuned length vs log turbo manifolds!?
Current Time: Sat Nov 21 16:45:00 UTC 2026
Total time taken to generate the page: 0.0044538974761963 seconds
