Toymods » Tech & Conversions » need help wiring thermos!
V8_MA61
need help wiring thermos! Fri, 30 January 2004 12:39 Go to next message
Im having difficulties wiring up my thermo fans off the thermostat switch.
I am getting the power from the ignition..and i have tested there is power getting to the relay. 12v exactly
there are 4 pins on the relay - one was a permanent wired gnd wire.
The three others need to be for the fan output, thermo switch in, and the power.
The relay is a hella and has a 25amp fuse on the side of it. Im wondering if this fuse would be for the output/ input??
It shouldn't matter that on the relay i have fan - polarity output, and fan + from the battery should it?
I tested swapping the wires around, and they didnt want to turn on...They kicked on once, but that was plugging the fans in, not out...
Could it be this switch is only gonna work at a temperature..i.e the override doesnt work on it???
P.s i tried my 3 switches i own and nothing changed.
Thanks guys
Blake.
[Updated on: Fri, 30 January 2004 12:42]
shinybluesteel
melbourne
Re: need help wiring thermos! Fri, 30 January 2004 12:47 Go to previous messageGo to next message
go to supercheap and buy generic relay (5 bucks or so), or go to a wrecker and get a headlight or similar relay.
try to get the ones that have the "switch" symbol (for the pins you use for running the fan) and the "coil" or "resistor box type thing" symbol (these pins are where you run your switching wire) look for a relay that only has 4 pins, or 3, the 3 pinners use a common earth, get the simplest relay you can.
sorry if this seems condescending at all, but i know it took me a while to work out how relays work. i'm sure i will have problems hookingup my thermo fans.
good luck!
V8_MA61
Re: need help wiring thermos! Fri, 30 January 2004 12:51 Go to previous messageGo to next message
i have like 4 relays here and they all have numbered pins Confused
Re: need help wiring thermos! Fri, 30 January 2004 13:23 Go to previous messageGo to next message
blake, a standard relay uses these numbers - plus i'm assuming your using a thermo switch that has one wire on the back.
85 & 86 are the coil that drives the relay - one of them can be earthed, the other gets 12V. Seeing as a normal thermo switch provides a ground when triggered, i would wire it up as :
85 - from IGN 12v+
86 - to thermo switch
if you want to override the thermo switch, you run a second wire from 86 to a switch in the cabin, one side of switch gets wire, the other goes to ground.
It's important that you remember that your trigger is coming from the earth connection, not 12V+.
if your thermo switch has two wires, one gets connected to pin 86, the other is grounded.
The coil side of the relay uses minimal current so you won't need heavy-duty wires.
To joice the actual fans, get 12V from the battery or main power rail (usually from large cable from alternator) and via the fuse, connect it to pin 30.
power to the fans then comes from pin 87 (there's sometimes two of them so you can 'power-up' multiple wires). I run two wires to each fan (12+ and earth) so the earth from the fans comes back up to an easy to access spot (e.g. next to the relay).
you could also connect a low-wattage pilot light to a wire coming off pin87 for an idiot light in the cabin.
for this 'triggered' side of the relay use decent weight wires (except for the pilot lite).
this help?
V8_MA61
Re: need help wiring thermos! Fri, 30 January 2004 13:33 Go to previous messageGo to next message
that sounds good charles, was told the same thing by soarer21...ill try it tommorow. I dont need it wired into the cabin, as i already have a fan on the front as an over-ride when i switch the car off/ ac is on.
My ma70 has 3 thermos all up.
Steve-AE86
Ademelaide, SA
Re: need help wiring thermos! Fri, 30 January 2004 22:07 Go to previous messageGo to next message
http://www.users.bigpond.com/steveg101/thermo%20wiring1.jpg
http://www.users.bigpond.com/steveg101/thermo%20wiring2.jpg
here are 2 pics i drew quickly last night...
hopefully one should work for you!
steve
[Updated on: Fri, 30 January 2004 22:10]
V8_MA61
Re: need help wiring thermos! Sat, 31 January 2004 04:33 Go to previous messageGo to next message
whats the deal with the switch having a ground?
V8_MA61
Re: need help wiring thermos! Sat, 31 January 2004 08:47 Go to previous messageGo to next message
ok ok here is my current situation:
I own 3 thermo fan switches.
First one in the car, didnt turn on the fans - let the car get over half and it didnt switch on - turned off car and conceeded it didnt work. Tested continuity from the terminal in the switch to the outside of the switch...there was none.
2/3rd switches - tested for continuity as above...they were linked. these ones turned on the fans as soon as they were plugged in. The car was cooled down at this point.
I have it wired as such:
gnd wire
thermo switch wire
fan -
battery +
Fan + were siamesed on the same wire that went from the battery to the relay.
What the hell is happening?? Its surely not possible that all 3 of my switches are rooted?!!! Mad
SOMEONE HELP ME! Crying or Very Sad
ed_ma61
Lost in the K hole
Re: need help wiring thermos! Sat, 31 January 2004 09:03 Go to previous messageGo to next message
to makes sure youre termostatic switches are working properly, dangle them in a pot of water on the stove, multimeter attached.
with a thermometer, heat the water up and see where the switches turns on (if at all).
you MAY have 3 rooted switches.
i understand that if theyre rooted they come on automatically (tho my one doesnt!).
check them, and bin them if they dont work.
also check the switching function of ALL relays and other switches, and check your earths.
also, if you have 2 fans, might i suggest wiring up an independant circuit for each (failsafe against a relay or earth fucking out - and your engine overheating).
PLUS - put in an override switch on the dash
ed
gabe
Re: need help wiring thermos! Sat, 31 January 2004 09:09 Go to previous messageGo to next message
Something worth mentioning is the fact that a lot of 4 pin relays have a '87a' pin and not a '87' pin
Check to see if you have this type of relay.
the 87a pin is a Normally Closed contact. ie when you power the relay, the contacts are pulled open and obviously no current will flow.
V8_MA61
Re: need help wiring thermos! Sat, 31 January 2004 09:10 Go to previous messageGo to next message
what im saying is that the one that was rooted didnt come on AT ALL. I.e being hot in 110" water on a stove, or automatically when on the car..
Mine is an 87 pin gabe
V8_MA61
Re: need help wiring thermos! Sat, 31 January 2004 09:12 Go to previous messageGo to next message
i also have a 3rd fan on the front of the radiator, which is hooked up to accs, and a manual switch.
ed_ma61
Lost in the K hole
Re: need help wiring thermos! Sat, 31 January 2004 09:14 Go to previous messageGo to next message
am i missing something here??
THROW IT OUT
get a new switch and start again
V8_MA61
Re: need help wiring thermos! Sat, 31 January 2004 09:21 Go to previous messageGo to next message
but surely theres a reason they're doing this, its impossible they all could be rooted! Confused
IM lookinf towards wiring errors, but i cant see how theyd be wrong, as its the only way they relay can turn on Confused
gabe
Re: need help wiring thermos! Sat, 31 January 2004 09:46 Go to previous messageGo to next message
Remove the thermatic switch and join the wires together.
If the relay pulls in then the coil side of the relay is fine (except for the thermatic switch possibly)
With the relay pulled in, make sure there is voltage at the fans.
If there is voltage at the fans, or they turn on, then substitute a WORKING thermatic switch back into the circuit
Re: need help wiring thermos! Sat, 31 January 2004 10:34 Go to previous messageGo to next message
hi blake, i can come over on sunday with maps, spare relays and a multimeter and we can kill off this wiring problem plus work out where to get lost on the next cruise? Cool
ta, charles
[Updated on: Sat, 31 January 2004 10:35]
V8_MA61
Re: need help wiring thermos! Sat, 31 January 2004 10:44 Go to previous messageGo to next message
PLEEEASE CHARLES PLEEEASE!!! Smile
I'll give you a call tonight! I am beginning to think i have the wrong relay?? mine is 4 pin..maybe i need a 5 pin?
Re: need help wiring thermos! Sat, 31 January 2004 11:17 Go to previous messageGo to next message
blake, am working a a drawing now - will post it shortly. ta charles
V8_MA61
Re: need help wiring thermos! Sat, 31 January 2004 11:22 Go to previous messageGo to next message
thanks mate!
Yeah i spoke to allan, he has the same setup - it needs to be a 5 pin relay. I also checked a diagram that was sent to me about how to wire them up...its a 5 pin!
Dont have any of them spare do you? Ive got a 4 pin ill swap ya Wink
Re: need help wiring thermos! Sat, 31 January 2004 12:18 Go to previous message
hi blake,
this might help - to work on a 5pin relay
http://members.optushome.com.au/mkhala/red_celica/ pdfs/relay_diags.pdf (124Kb PDF)
CU sunday arvo.
Previous Topic:good tyres and how much
Next Topic:wiring up a 4age into a ae86
Current Time: Sat Nov 21 17:07:02 UTC 2026
Total time taken to generate the page: 0.0061330795288086 seconds
