Toymods » Tech & Conversions » 3K redline
_555_
SOR, Perth
3K redline Fri, 30 January 2004 12:43 Go to next message
I know the 3K is for from been a performance engine, but I have one in my $100 KE30 motorkhana car and want to know how far I can rev it without too much damage.
I have searched the net, but not found anything so far.
Cheers.
CLG
Perth, Western Australia
Re: 3K redline Fri, 30 January 2004 14:16 Go to previous messageGo to next message
These ar tough little engine, and I doubt you'll break it through revs. I'd happily go to 7500 on a standard motor. where are you motorkhana'ing?
_555_
SOR, Perth
Re: 3K redline Fri, 30 January 2004 14:27 Go to previous messageGo to next message
CLG: Thanks for the reply, I never knew the 3K was so tough, however I have personally reved it very high (but could never tell how high as it doesn't have a tacho!) Until the engine sounded like it was going to break, but it never did.
I plan to go to a few local (in perth) moto's and khanacrosses this year with the KE30 beast although I still need to get my CAMS licence stuff sorted.
Also what diameter exhaust would you recomend for a stock 3K running extractors?
[Updated on: Fri, 30 January 2004 14:31]
CLG
Re: 3K redline Fri, 30 January 2004 14:35 Go to previous messageGo to next message
You'll only need a level 2 NS (non speed) for motorkhanas, but you will also need to be a memeber of a CAMS affiliated club to get one. I'm a member of the Mini Car Club here in Perth as it's one of the cheapest for this purpose ($15 a year). the CAMS license is only $50 so you get good insurance for $65/year in my opinion - but nothing else from CAMS, they're as useless as tits on a bull to talk too!
PM me if you want any pointers on setup for motorkhanas (yes, I still remember your "struts" post from a few months ago)?!
Clint
ps, if you have any spare K series motors that are stuffed, I'm always looking for them!!!?
Re: 3K redline Fri, 30 January 2004 15:00 Go to previous messageGo to next message
a totally stock motor will tend to lose power above 6-6500rpm, and valve bounce or points bounce around 6500-7500rpm, depending on condition of springs/points.
it revs much nicer of you balance the rods and pistons tho Wink
i rev my 4K to around 7K all the time, occasionally to 8K, and accidentally higher...
no real point revving past 6 with a stocko tho, as the cam and heas run out of puff..
have fun Smile
CLG
Re: 3K redline Fri, 30 January 2004 15:02 Go to previous messageGo to next message
Yep, God has spoken!!! Follow him for he speaks the truth!!! Laughing Laughing Laughing
Wondered when you were going to find this Stew?!!!
_555_
SOR, Perth
Re: 3K redline Fri, 30 January 2004 15:13 Go to previous messageGo to next message
So basically if I keep it below 6k it should be fine.
Thanks for the info BTW.
Purple_Beasty
New Zealand
icon10.gif  Re: 3K redline Fri, 30 January 2004 19:00 Go to previous messageGo to next message
With absolutely no mechanical sympathy I used to rev my 3K to 8000rpm. Only "work" done on this motor was a home job re-con on someones back doorstep ie new rings, bearings and not even honed. Held together for over 40,000ks in one year before I sold it.
This abuse included lots of 8000rpm launches at the drags and similar rev levels on grass. Never broke anything.
This shows just how strong and revvy a 3K is (my 4K with extractors would only go to 700rpm) but I would definitely NOT recommend this treatment unless you are willing to change the odd engine ocassionally. Shocked Shocked Shocked
Callum
pro_ke
adelaide
Re: 3K redline Sat, 31 January 2004 01:27 Go to previous messageGo to next message
my stock 3k used to hit valve bounce at about 8100rpm
ab
Re: 3K redline Sat, 31 January 2004 12:30 Go to previous messageGo to next message
CLG wrote on Sat, 31 January 2004 02:02
LOL Laughing
"The lord giveth, and the lord taketh away"
until i actually break a K motor i've built, i'm not much of a god Wink
Very Happy
one day...
mm alex you musta had some goo dcondition stocko valve springs. most of mine have been shagged... and they do get worse over time too... one motor bounced at 7500.. then 7000, then 6500.. then 6000....
pro_ke
adelaide
Re: 3K redline Sun, 01 February 2004 01:03 Go to previous message
well i valve bounced my old 4k about about 6500!
Previous Topic:the art of intercooler pipe leaks?
Next Topic:hose blocks?
Current Time: Wed Oct 28 06:14:23 UTC 2026
Total time taken to generate the page: 0.014758110046387 seconds
