Toymods » Tech & Conversions » Mandrel bend vs Press bend
TRD-AW11
Mandrel bend vs Press bend Fri, 30 January 2004 13:58 Go to next message
Would like to know if its worth getting madrel bend for a NA car or press bend...and how much power difference is there?
Coz the price for a mandrel bend is like almost double the price of the press bend...so if it only a gain of like 1-2 wheel kw compared to press bend then i just dont see any point in getting mandrel..
CLG
Perth, Western Australia
Re: Mandrel bend vs Press bend Fri, 30 January 2004 14:13 Go to previous messageGo to next message
really depends on the exhaust size and type of motor you want to run. I've used both, the secret is to match the pipe diamter to suit the engine.
Re: Mandrel bend vs Press bend Fri, 30 January 2004 15:03 Go to previous message
definitely... i used a mixture of press and mandrel... the main difference is in the radius of the bends..
for a high angle bend (90+?), mandrel will have larger diameter.
but a press bent with a larger inital diamter will have same diameter as smaller mandrel bent... Very Happy
the only places i would use mandrel bends on an NA car is over the diff, and when making up a set of extractors where space is of the essence, or tight large angle bends are needed. this is basically becuase mandrel has tighter (smaller radius) bends, and crushes less for high angle....
[Updated on: Fri, 30 January 2004 15:04]
Previous Topic:how to get a '69 steerin wheel off......
Next Topic:newbie questions...
Current Time: Fri Oct 23 02:58:28 UTC 2026
Total time taken to generate the page: 0.0047011375427246 seconds
