Toymods » Tech & Conversions » 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts
1G-GTEFreAk
icon4.gif  3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Fri, 30 January 2004 23:38 Go to next message
Hey
New Modification here and need some info from anyone who has done this in the past.
Car 1995 ST202 Celica SII
Well what we want to do is take the 3S-GE and swap parts with a 3S-GTE to the 3S-GE to make it turbocharged.
Can we take the turbo,turbo manifold,and piping from the ST185 Celica,and bolt them directly unto the 3S-GE,what other mods do we have to do to make this work.
This is some crazy stuff but........
Please help. Confused
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sat, 31 January 2004 00:33 Go to previous messageGo to next message
out of interest... why wouldn't you just drop the whole 3s-gte in?
then turbo, oil lines, etc are already hooked up, compression is already dropped... the hard work is done (apart from some mods to sump and a few other things to get it in)
1G-GTEFreAk
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sat, 31 January 2004 00:35 Go to previous messageGo to next message
I do not have the 3S-GTE parts yet just want to know if it is possible.
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sat, 31 January 2004 00:57 Go to previous messageGo to next message
Anything is possible, but its a lot harder than doing it the right way.
1G-GTEFreAk
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sat, 31 January 2004 02:28 Go to previous messageGo to next message
we simply want to keep the 3S-GE and turboccharge it using the 3S-GTE turbo and Exhaust manifold,run a few pipes and a front mount intercooler and we hope everything bolts on well hopefully.
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sat, 31 January 2004 03:01 Go to previous messageGo to next message
Thing is though, you're missing the low-compression pistons, the oil squirters, the ECU that can handle boost etc...
1G-GTEFreAk
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sat, 31 January 2004 14:31 Go to previous messageGo to next message
Ok Will the 3S-GTE engine bolt onto the 3S-GE gearbox.
crazy_camry
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sun, 01 February 2004 00:16 Go to previous messageGo to next message
AFAIK, yes
smt_007
Re: 3S-GE converted to a 3S-GE turbo in a ST202 Celica Using 3S-GTE parts Sun, 01 February 2004 11:35 Go to previous message
Check this out, 3sge turbo making 595hp@wheels on 23psi boost. Shocked
http://www.cardomain.com/id/larrycam21983
Previous Topic:R12 a/c gas chemical name?
Next Topic:Using plates underneath the crossmember instead of RCA's?
Current Time: Sun Nov 1 11:49:39 UTC 2026
Total time taken to generate the page: 0.0054891109466553 seconds
