Toymods » Tech & Conversions » Soarer door won't open
fingers
Darwin
icon13.gif  Soarer door won't open Sat, 31 January 2004 04:19 Go to next message
Hi all,
Just bought a Soarer (JZZ30) and a week after I bought it the drivers side door won't open. Mad
Passenger side works fine, can't open it from the inside or the outside. I've played with the door lock button and used the keys as well but when I pull the handle nothing happens.
Anybody had this happen to them? How was it resolved?
It's giving me the s#&ts and as the door is closed I'm not sure how to get the trim off to take a look. Sad
Any ideas/hints/suggestions would be greatly appreciated.
Fingers
[Updated on: Sat, 31 January 2004 04:20]
Chris Davey
sunny coast, qld
Re: Soarer door won't open Sat, 31 January 2004 07:03 Go to previous messageGo to next message
SO when you use the key it unlocks but you still can't open it with the handle?
If so, i would think that somehow the handle has disconnected itself from the latch? just a guess though Smile
I think it would be quite difficult if not impossible to get the door trim off with the door closed.
Soarer
Wollongong
Re: Soarer door won't open Sat, 31 January 2004 07:17 Go to previous messageGo to next message
Might be worth asking in here:
http://www.alsc.aus.as/
fingers
Darwin
Re: Soarer door won't open Sun, 01 February 2004 22:22 Go to previous messageGo to next message
bassaholic55 wrote on Sat, 31 January 2004 18:03
That's correct, I can see the lock flicking backwards and fowards but when you pull on either handle, nothing happens.
Right on there. There is a $2 plastic clip that holds the rod to the handle, it had broken and the rod had fallen out.
I managed to open the door by fluke when I wound down the window; it hit the rod and opened the door. It bent the rod though. So much so that when I pulled it back into place it broke. Mad
Managed to macguyver it all together with some wire so I can use it for now. Lucky its under warranty so I'll have to see what they say.
Fingers
Chris Davey
sunny coast, qld
Re: Soarer door won't open Mon, 02 February 2004 02:38 Go to previous message
good to hear you are getting it fixed Smile
Previous Topic:1UZ questions
Next Topic:TA22 restoration
Current Time: Wed Oct 28 05:25:39 UTC 2026
Total time taken to generate the page: 0.003817081451416 seconds
