Toymods » Tech & Conversions » the art of intercooler pipe leaks?
Ribbo
Northern Beaches
the art of intercooler pipe leaks? Sat, 31 January 2004 05:02 Go to next message
Ok so what are your tricks in finding leaks in intercooler pipes or the intercooler themselves? There must be an art to it
thanx
TE72_Turbo
Re: the art of intercooler pipe leaks? Sat, 31 January 2004 06:46 Go to previous messageGo to next message
Do you have an air compressor & access to a welder? The best way to find leaks is to take a short section of mild steel exhaust pipe that will fit in place of your air filter/airbox (with a hose clamp of course), weld a circular plate to one side of it, and a 6mm diameter fitting through the plate (a piece of small pipe such as fuel line will do). With the car turned off, hook the fitting up via some vaccum hose to an air blower on your air compressor, and pressurise the system to about 10psi. You will clearly hear/feel any leaks in the intake plumbing and intercooler. Might sound like a hassle, but its guaranteed to isolate any leaks... Smile
Danish
Re: the art of intercooler pipe leaks? Sat, 31 January 2004 08:36 Go to previous messageGo to next message
To find C02 leaks in the beer gas lines we use soapy water. The idea is that you cover all the piping in the soapy water and eventually any air leaks will bubble up and be noticable.
I think this would be easy to do on a stationary car. Just rev it a bit to force air pressure through.
clubagreenie
1st street on the right
Re: the art of intercooler pipe leaks? Sat, 31 January 2004 12:00 Go to previous messageGo to next message
Have to agree, soapy water in a spray bottle. Use it for leaks on dive gear for work.
Ribbo
Northern Beaches
Re: the art of intercooler pipe leaks? Sat, 31 January 2004 23:59 Go to previous messageGo to next message
thanx guys, I found 3 leaks by taking pipes out and intercooler and putting them in a bath and blowing into one end hehe. Sounds silly but it worked Smile
TE72_Turbo, that sounds like a good idea but a bit much work hehe considering I knew I was gonna have to take the pipes out anyway to fix up the welds.
The other 2 you can't really do because while the car is sitting there in neutrel you can't get it onto boost.
Thanx guys.
Re: the art of intercooler pipe leaks? Sun, 01 February 2004 01:19 Go to previous message
Dyno and soapy water Evil or Very Mad
Previous Topic:Exhaust mani gaskit goo?
Next Topic:3K redline
Current Time: Sun Oct 25 23:24:31 UTC 2026
Total time taken to generate the page: 0.051756858825684 seconds
