Toymods » Tech & Conversions » 4age Exhaust
-=NiGz=-
Compton.Sydney
4age Exhaust Sat, 31 January 2004 05:49 Go to next message
This Mechanic told me the Exhaust size on my 4age is to big Confused before i got it, asked muffler places they said 2inch is amp. Is this true that it is too big?
NickAE86
Brisvegas
Re: 4age Exhaust Sat, 31 January 2004 06:25 Go to previous messageGo to next message
2" would be fine on a 4age.
why did he tell you its too big? is it affecting the drivability of the car?
what car is it in?
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Sat, 31 January 2004 06:35 Go to previous messageGo to next message
Its in a Seca Sx. Nah not really just hearin small back fires n shit said thats caused by the big exhuast
de_rift
Wollongong
Re: 4age Exhaust Sat, 31 January 2004 07:02 Go to previous messageGo to next message
hearing the noise is caused by the exhaust, but the noise is not caused by the exhaust.
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Sat, 31 January 2004 07:03 Go to previous messageGo to next message
To do with the plugs?
NickAE86
Brisvegas
Re: 4age Exhaust Sat, 31 January 2004 07:23 Go to previous messageGo to next message
what de_rift said. The exhaust wont cause backfires...that could be any number of issues. Anyone familiar with common probs on a seca?
Kahless
Re: 4age Exhaust Sun, 01 February 2004 12:23 Go to previous messageGo to next message
mine does it too, but only when you back off the accelerator. i think its because of the change in pressure
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Sun, 01 February 2004 14:07 Go to previous messageGo to next message
same and on idle at times here and there you here it Confused
Re: 4age Exhaust Sun, 01 February 2004 15:20 Go to previous messageGo to next message
backfires through the exhaust are due to over rich mixture being ignited in the exhaust. when you lift off, the mixture must go very rich relative to the amount of air, and the start popping.
it can also be caused by a cylinder miss, causing the fresh unburnt charge to hit the hot exhaust...
2" is not too big. depend son the mods... 2" is about ideal for a worked 1.3L, but it's all to do with air flow Wink a 1.3L at 8000rpm will push as much air as a 1.6 at 6500rpm.
if you have shitty mufflers, it will "sound too big" ie like a gemini Razz. maybe thats what they were referring to?
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Mon, 02 February 2004 03:35 Go to previous messageGo to next message
I got a Running Rich problem at the moment thats prob cos of them popping sounds. Yeh i dont think 2 inch is too big for my car, does it gain a lil bit of power from this size of exhaust?
SW20R
Re: 4age Exhaust Mon, 02 February 2004 03:51 Go to previous messageGo to next message
2" is fine. are you running a cannon? he is most likely reffering to your muffler.. cannons are known todo this. backfiring and flaming. but dont worry much about it Wink
rich is good just aslong as its not lean!
factory is 1.5" and dont down grade you will feel a restriction and a flat spot!
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Mon, 02 February 2004 04:17 Go to previous messageGo to next message
Nah got a Dumpie hate the fucks out of cannons, there good if you got a turbo engine but on a N/A i reckon dumpies are the best.Laughing
Isnt Running rich a problem like will effect your preformance?
nah its not lean
Asher
Northgate, QLD
Re: 4age Exhaust Mon, 02 February 2004 04:26 Go to previous messageGo to next message
I know the sound your talking about, its not actully back fireing but yer that sound thats like that.
Come on guys, a big exhaust is good but you have to remember its only a 1.6L engine.
I've been told to get a 2" for my 2.4L.
adamb131
Re: 4age Exhaust Mon, 02 February 2004 04:40 Go to previous messageGo to next message
For an NA 4ag go to 2 1/4 inch max... 2 1/2 inch is too big... IMO 2 inch is too small for a worked 4ag. Just my 2Cents...
redlineGTi
syd- green valley
Re: 4age Exhaust Mon, 02 February 2004 06:44 Go to previous messageGo to next message
dued check ur timing, it's probably off, that'll probably be the cause.
SW20R
Re: 4age Exhaust Mon, 02 February 2004 07:24 Go to previous messageGo to next message
running rich = more fuel shouldnt give you performance problems!
dont you think that more fuel = more power?
some of it might be a waste but dont you feel your car more responsive?
Hirogen
Melbourne, Australia
      WTF is a jabber?
Re: 4age Exhaust Mon, 02 February 2004 07:26 Go to previous messageGo to next message
Usually it will backfire if you have had your foot flat to the floor (running full rich mixture) then when you let off it backfires a little. At least thats how mine is.
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Tue, 03 February 2004 04:00 Go to previous messageGo to next message
Did you fix your running rich problem
Kahless
Re: 4age Exhaust Fri, 06 February 2004 14:44 Go to previous messageGo to next message
i stopped it on mine by adjusting the mixture a bit. 2" sounds beautiful, thats what the cop was trying to tell me the other night. He said "your car is too loud" but he was trying to say "Damn that sounds nice"
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Sat, 07 February 2004 01:29 Go to previous messageGo to next message
Doesnt the ECU adjust the AIR/Feul ratio?
Kahless
Re: 4age Exhaust Wed, 11 February 2004 01:52 Go to previous messageGo to next message
I thought so, but my friend decided to adjust it even tho I thought it was set at factory and never to be touched again.
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Wed, 11 February 2004 04:20 Go to previous messageGo to next message
Nah dont touch that. still running rich tho? did you find a lack of preformance when your running rich?
Kahless
Re: 4age Exhaust Wed, 11 February 2004 14:48 Go to previous messageGo to next message
yeah I did but I was changing the fuel filter (in a bitch of a spot they are) and I pulled my air filter off to get to it, the hose is split all along the bottom so I have a few things to fix. Stupid ford piping
Kahless
Re: 4age Exhaust Thu, 19 February 2004 22:39 Go to previous messageGo to next message
it is again... stupid thing. I guess it needs a bit of work. I really noticed the performance loss... hell I still do. Right now it makes the camry lok like a beast (till you get past 3500 rpm)
-=NiGz=-
Compton.Sydney
Re: 4age Exhaust Fri, 20 February 2004 05:48 Go to previous messageGo to next message
Yeap same as my car. Performance loss can be from a blocked up CAT, running rich for a while can cause this. My car, when it idles at normal temp makes a popping sound here and there apparently that sound is from a blocked up cat.
I am sure my car has a blocked up cat cos been running rich for a while now 4 5 months.
AND YES A SWIFT GTI WAS ABLE TO KEEP UP TO ME Sad Mad proves the performance loss
ae8620v
Re: 4age Exhaust Tue, 09 March 2004 09:04 Go to previous messageGo to next message
nah thats not to big at all, if you want you could even go up to 2 1/4" that would be the max thought, i know when i get cars coming in that backfire it is usually due to poor tune or a small exhaust leak
TokenBlackGuy
      wtf is jabber
Re: 4age Exhaust Tue, 09 March 2004 09:09 Go to previous message
he got banned, again Shocked
Previous Topic:Swaaping sincromesh in gearbox
Next Topic:7mge sulphur smell
Current Time: Fri Nov 20 17:51:59 UTC 2026
Total time taken to generate the page: 0.0064079761505127 seconds
