Classifieds » Miscellaneous » K-series EFI set-up (SOLD)
Meathead
icon14.gif  K-series EFI set-up (SOLD) Sat, 31 January 2004 08:41 Go to next message
This complete set-up for sale is a factory 4K EFI set-up, which includes:
ECU w/cut wiring loom
Air Flow Meter
EFI manifold
Fuel Rail
Fuel pressure regulator (on rail),
Air Plenum w/chrome curved runners
Injectors
Rocker Cover
Thermostat housing w/ECU's temp. sender & thermofan switch
Exhaust manifold
Basically everything you would require to EFI any K-series motor.
$375 no offers.
A couple of pics... e-mail for more...
http://images.cardomain.com/member_images/8/web/368000-368999/368424_13_full.jpg
http://images.cardomain.com/member_images/8/web/368000-368999/368424_12_full.jpg
[Updated on: Sat, 07 February 2004 06:56]
CLG
Perth, Western Australia
Re: K-series EFI set-up Sat, 31 January 2004 10:22 Go to previous messageGo to next message
What's the setup from Mr Head - specifically the computer?
Meathead
Re: K-series EFI set-up Sat, 31 January 2004 10:30 Go to previous messageGo to next message
CLG wrote on Sat, 31 January 2004 21:22
The computer is the factory 4K-E unit...
pro_ke
adelaide
Re: K-series EFI set-up Sat, 31 January 2004 12:01 Go to previous messageGo to next message
came out on K series starlets and some vans i think, not 100% about the vans though.
the setup looks nice!
ab
79rollaboy
NSW Engadine
Re: K-series EFI set-up Thu, 05 February 2004 05:15 Go to previous messageGo to next message
i never heard of 4K-Es before... so this would fit on non overhead cam engines??
Meathead
Re: K-series EFI set-up Thu, 05 February 2004 06:41 Go to previous messageGo to next message
79rollaboy wrote on Thu, 05 February 2004 16:15
...so this would fit on non overhead cam engines??
It'll bolt-on to any k-series engine: k, 2k, 3k, 4k, 5k, 7k, none of which are overhead cam....
I couldn't say if it'd suit any other engines ...Confused
alex_ta22
Newcastle, Hunter Valley
Re: K-series EFI set-up Thu, 05 February 2004 06:55 Go to previous messageGo to next message
i think he means will they fit the high cam 4k
Steve-AE86
Ademelaide, SA
Re: K-series EFI set-up Thu, 05 February 2004 08:27 Go to previous messageGo to next message
you do realise that the "Hi-Cam" 4k was still not overhead cam, right...?
it had a HIgher Lift cam than the other models...
that's all.
btw, this setup is pretty schmick looking, with the chrome intake runners, and all...sexy.
jazz up your KE30/55/70, whatever!!!
alex_ta22
Re: K-series EFI set-up Thu, 05 February 2004 08:39 Go to previous messageGo to next message
I know that, i just thought he was refering to the "high cam" because it is kind of an odd one out of the lot
Re: K-series EFI set-up Thu, 05 February 2004 12:22 Go to previous messageGo to next message
Steve-AE86 wrote on Thu, 05 February 2004 19:27
that's all.
LOL Laughing
tis a common misconception..
"Hicam" refers to the cam being placed "high in the block", and was an advertising campaign to counter the "overhead cams" of dattos etc of the time.
a "Hicam" 4K, is just aplain old boring 4K Wink
the actual cam is the same in lift and duration to the other 'normal' K type cams (non-hydro, and non -B cams)
4KE setup will fit onto any K motor, manifold can be ported enough to fit onto bigports.
show me the cam specs of a "HIgher Lift cam" Very Happy Wink
Re: K-series EFI set-up Thu, 05 February 2004 12:26 Go to previous messageGo to next message
does it have the thermostat housing with the temp ECU's temp sender adn the thermfoan switch?
cambelt
melb
Re: K-series EFI set-up Thu, 05 February 2004 12:55 Go to previous messageGo to next message
Yes it does.
irokin
Re: K-series EFI set-up Fri, 06 February 2004 01:20 Go to previous messageGo to next message
alex_ta22 wrote on Thu, 05 February 2004 19:39
My 3Ks cam is positioned higher than my Hi-Cam 4Ks
Re: K-series EFI set-up Fri, 06 February 2004 02:52 Go to previous messageGo to next message
irokin wrote on Fri, 06 February 2004 12:20
really? weird. can you measure it?
i have 3K timing chain and sprockets on my 4K, and did not notice any differences..
the 4K block has a taller deck height too, so mayb the cam is the same height relative to the crank?
measurements would be good!
[Updated on: Fri, 06 February 2004 14:12]
Meathead
Re: K-series EFI set-up Fri, 06 February 2004 03:30 Go to previous messageGo to next message
Cheers Stew... I'll get some shinier pics of my gear up tonight! Very Happy
da_snuff
Hobart
Re: K-series EFI set-up Fri, 06 February 2004 04:48 Go to previous messageGo to next message
would this setup give me more power than the twin carbs i have on a 5K at the moment? or would it just run smoother...... and start on 1 degree mornings?? Very Happy
might be interested, if you can be bothered doing a c.o.d
aidan
Meathead
Re: K-series EFI set-up Fri, 06 February 2004 05:10 Go to previous messageGo to next message
da_snuff wrote on Fri, 06 February 2004 15:48
Are these the factory twin aisans?
da_snuff's other Q
COD isn't a problem...
da_snuff
Hobart
Re: K-series EFI set-up Fri, 06 February 2004 06:21 Go to previous messageGo to next message
just standard ones yep, but lets say i put some new webers or something on it, honestly which would i be better off with? Very Happy
aidan
Meathead
Re: K-series EFI set-up Fri, 06 February 2004 09:58 Go to previous messageGo to next message
da_snuff wrote on Fri, 06 February 2004 17:21
IMO, you would be better off with EFI...
This thread would be a useful read: http://forums.toymods.org.au/index.php?t=msg&t h=5062&rid=2350&S=870c207243ab3fb7b8a16111 ef58150b&pl_view=&start=0#msg_41391
Steve-AE86
Ademelaide, SA
Re: K-series EFI set-up Fri, 06 February 2004 10:12 Go to previous messageGo to next message
also, think of the dollar factor here...
a pair of new webers...$1000 (maybe $800 if you shop around...)
meatheads efi setup....$375
der...
efi will always run smoother, use 1/5th of the fuel, and have just as much power, if tuned properly.
da_snuff
Hobart
Re: K-series EFI set-up Fri, 06 February 2004 23:34 Go to previous messageGo to next message
rightio, sorry for being stupid Very Happy
ill buy the whole set up then Evil or Very Mad
will send p.m
aidan
Meathead
Re: K-series EFI set-up Sat, 07 February 2004 02:53 Go to previous message
SOLD! Very Happy
Previous Topic:FS: ALPINE////// 12inch sub in box $160 A1
Next Topic:1JZ SARD 540cc injectors
Current Time: Sat Nov 21 07:57:15 UTC 2026
Total time taken to generate the page: 0.0076041221618652 seconds
