Toymods » Tech & Conversions » 3sgte head gasket
Classique71
Colac, Victoria
3sgte head gasket Sat, 31 January 2004 10:55 Go to next message
Well - not 100% sure yet - but i think my headgaskets on theway out .. Crying or Very Sad
Anyone know the rough cost of a replacement ?
gabe
Re: 3sgte head gasket Sat, 31 January 2004 12:07 Go to previous messageGo to next message
Part Number - 1111588382
I paid $101.50 for mine.
Engine is a 185
Hope this helps
RobST162
Re: 3sgte head gasket Sat, 31 January 2004 12:52 Go to previous messageGo to next message
oh no! Stuey! What did ya do!? or is she just old... Sad what a pain for ya Sad
Draza
Wahroonga
Re: 3sgte head gasket Sat, 31 January 2004 22:57 Go to previous messageGo to next message
if its the original gasket and u've uped the boost then i would this to be expected. i would say go for a TRD metal gasket(brass, copper or something like that i cant think straight atm), no idea on the costs.
If anyone has a better idea post it.
Classique71
Colac, Victoria
Re: 3sgte head gasket Sun, 01 February 2004 02:51 Go to previous messageGo to next message
i was waiting for the 7m thing - but how many gt4's do you hear having Blown head gaskets
Anyway - imgetting it checked out properly next week ..
its either the head gasket - at worst case scenario - or a very clogged up radiator/thermostat coupled with bad airflow ..
You can guess which one i hope it is ..
Thanks for the parts number - The new motor will have an uprated head gasket in it - though i think if its needed to be replaced on this motor - ill put in a standard item ..
its been running 13 odd PSI of boost pretty much since it was bought - so its handled 200 thousand KM - not too bad - and nods - not totally unexpected.
TA22-3SGTE
MACKAY
Re: 3sgte head gasket Sun, 01 February 2004 11:52 Go to previous messageGo to next message
Get a genuine Toyota head gasket for a ST205 as these are a multi layer steel gasket , I paid $96 for mine .
Trevor
Classique71
Colac, Victoria
Re: 3sgte head gasket Sun, 01 February 2004 11:55 Go to previous messageGo to next message
re the 205 - they fitted on your block no problems ??
If i need one - this is better than the 185 unit im sure ..
Though - double checked water to see if theres milkiness today - none - no water in oil off dipstick , and no goo under the oil cap ..
Going to get the coolant system checked gor gas leakage - i believe they pout somethign on the radiator + check for bubbles ?
Hoping its not a BHG - morre likely a dead radiator or thermostat ..
TA22-3SGTE
MACKAY
Re: 3sgte head gasket Sun, 01 February 2004 12:31 Go to previous messageGo to next message
All 3S block paterns are the same , I have the 205 gasket on a 165 .
Trevor
RAV-GT4
Toymods member
Rydalmere, NSW
Re: 3sgte head gasket Sun, 01 February 2004 13:33 Go to previous messageGo to next message
I just bought the TRD ST205 head gasket (3-ply, 1mm). Apparently good for up to 22 Psi.
crazy_camry
Re: 3sgte head gasket Mon, 02 February 2004 08:15 Go to previous messageGo to next message
how many $$$, where from?
spectral
Re: 3sgte head gasket Mon, 02 February 2004 09:18 Go to previous messageGo to next message
$110 inc GST from Southside Toyota in Brisbane for the ST205 Metal gasket
Penrith Toyota said $147 for the same part Confused Pays to shop around, even with Toyota geniune parts.
gabe
Re: 3sgte head gasket Mon, 02 February 2004 13:07 Go to previous messageGo to next message
TA22-3SGTE wrote on Sun, 01 February 2004 19:52
Trevor
I wanted to do this but when I placed the 205 gasket on the 185 block, it partially covered up some water galleries, So i decided to put the 185 one on till I get serious.
Also did you replace the head bolts?? Are they torque to yield design?
RAV-GT4
Toymods member
Rydalmere, NSW
Re: 3sgte head gasket Mon, 02 February 2004 13:08 Go to previous messageGo to next message
Don't forget your Toymods 15% discount when you shop at Penrith Toyota parts. Very Happy Talk to Mark, the resident TRD guru there... Nod
Classique71
Colac, Victoria
Re: 3sgte head gasket Fri, 06 February 2004 06:55 Go to previous messageGo to next message
Well - its blowing bubbles thru the radiator ..
Sounds like ive bitten the big " oh fuck this "
So .. i have a blown head gasket .. CAr seems ok to get to and from work FOR NOW - will driving it for less than 5 mins either way create larger problems in the meantime till i can get it fixed ?
Also second dilemma -
I can either:
I can either repair the headgasket in this one , just the gasket - nothing else .
OR should i still get the group A motor + drive this one as is for the next few months - and build that up ( by asking bank for more money please ) and swap the bastard over in one hit
Either way ill have to pull a motor apart ..whats better
Also for those who have done it - Ideas on the cost to repair it ...
Cheapest method is the best atm - And will i need the head worked over ?
spectral
Re: 3sgte head gasket Fri, 06 February 2004 06:59 Go to previous messageGo to next message
you are probably going to have to pull the motor to get at the HG... it won't be easy to get it off... lot of f**king around.
I'd personally get a real move on with the GrpA donk. Kill two birds with the one stone. Borrow, beg or steal!
Be careful driving any more than a couple of minutes... gases can build up in the cooling system and cause hose blowouts etc... has personally happened to me (not in the GT4 thou).
RAV-GT4
Toymods member
Rydalmere, NSW
Re: 3sgte head gasket Fri, 06 February 2004 09:25 Go to previous messageGo to next message
Bite the bullet dude - go the whole hog (like I did). Very Happy Best thing I've done for this car so far. Nod
RobST162
Re: 3sgte head gasket Fri, 06 February 2004 15:10 Go to previous messageGo to next message
Stuey mate that sux
I really feel for you man... no toyota natties Sad *sniff*
hey I don't know about your engine, but for the 3sge there is no way I would need to take the engine out to do the hg, don't know if having the turbo and all would force an engine removal but hey if you can take the top off without undoing all the gbox and stuff you could do it yourself (take friggn' ages though)
I know nosssing.
Classique71
Colac, Victoria
Re: 3sgte head gasket Sat, 07 February 2004 01:49 Go to previous message
Im determined to get to dubbo still - Dont worry about that !
At this point my choice seems to be fix the motor - new HG for that - and still get the other one to build a sa monster ..
Wheteher or not im driving doesnt matter - Ill get there somehow - either shotgunning - or flying
Previous Topic:Fuel setup for 4AGE in AE86
Next Topic:Urgent Help Need - W57/8 G/box splitting.
Current Time: Wed Oct 14 12:34:39 UTC 2026
Total time taken to generate the page: 0.14817786216736 seconds
