Toymods » Tech & Conversions » Need help from xA6x owners
Purple_Beasty
New Zealand
icon5.gif  Need help from xA6x owners Sat, 31 January 2004 11:05 Go to next message
Just need to get some measurements to assist with the IRS conversion in my RWD Starlet.
Prefer from a standard car, but a nice handling, evenly lowered car will do.
Need the following measurements-
Front crossmember to ground (both sides)
Measurements from ground to each of the 4 rear IRS mounts (to the floorpan not the rear crossmember)
Diff and floorpan section I am using is from a TA63, but I understand the floorpan is shared with the RA63, and the MA61 (other than the extended front).
Any help would be very appreciated, I want to ensure I match the mounting heights for the front and rear crossmembers to avoid any odd handling issues.
Callum
ThatDogsFullySickMate
BrisVegas---YeeeHAW
Re: Need help from xA6x owners Sat, 31 January 2004 11:23 Go to previous messageGo to next message
mine is lowered 4 inches, do you want me to get the tape out and give you some figures
V8_MA61
Re: Need help from xA6x owners Sat, 31 January 2004 11:24 Go to previous messageGo to next message
ta63 or sa63?
I thought the only 60 celicas were ra60, sa63 and ra65???
BrisVegas---YeeeHAW
Re: Need help from xA6x owners Sat, 31 January 2004 11:40 Go to previous messageGo to next message
there was
ra60 21rc (aus)
ra60 20r (usa)
ra61 20r (usa) and 22rc i think
ta63 was 3tgte (jap)
sa63 2sc (aus)
aa64 4age (jap)
ra64 18rg (jap)
ra65 (22re) aus
and either a ta64 or ta65 got the 4tgte but this was restricted to race, they made 200 of these
im sure there are more variations, cant remember what ra62 was
[Updated on: Sat, 31 January 2004 11:42]
Stefan
Hobart, Tas
Re: Need help from xA6x owners Sat, 31 January 2004 13:03 Go to previous messageGo to next message
Mine is lowered an inch or so all round (King Springs) I can take measurements for you sometime, if you like, but I don't have anywhere level to park on unfortunately. Only bit of flat ground is the front lawn, which isn't so good to measure to!
FullySik - 4 inches, eh? All round or just the front? 4 inches at the back would be neg-camber city!
c2888
Re: Need help from xA6x owners Sat, 31 January 2004 14:05 Go to previous messageGo to next message
I've got a stock TA63 sitting outside, still intact Smile
A rarity i'm sure.
If it's not raining in the o so sunny Victoria tomorrow I might pull a tape measure out. damn rain
pics of it here
http://www.alphalink.com.au/~soyracer/ta63/page1.h tml
I've moved it to my backyard, so I won't be measuring on the grass
dodgydan
Purple_Beasty
New Zealand
Re: Need help from xA6x owners Sat, 31 January 2004 18:06 Go to previous messageGo to next message
c2888 wrote on Sun, 01 February 2004 03:05
A rarity i'm sure.
pics of it here
dodgydan
That would be much appreciated, we had the measurements but they disapeared somewhere in my shed. Crying or Very Sad
The actual car we are using for parts was a TA63 Carina 4 door with the 3T-GTE/W55/F code IRS.
Details and some pics of the rear end progress here.
http://forums.toymods.org.au/index.php?t=msg&t h=27918&start=0&rid=129&S=35f5df57f1f3 e2ea1b80d048607d2b65
Callum
PS - There was also an RA63, with 18RGEU/W55/F code IRS in Japan
BrisVegas---YeeeHAW
Re: Need help from xA6x owners Sat, 31 January 2004 23:17 Go to previous messageGo to next message
Stefan wrote on Sun, 01 February 2004 00:03
sure is stefan, the inside of the tyres wear down quickly so i use hard compound tyres, im using a supra diff so in the wet i dont have any traction problems thanks to the lsd
it does handle like its on rails even in the wet
c2888
Re: Need help from xA6x owners Sun, 01 February 2004 00:19 Go to previous messageGo to next message
Left Right
Front 144 146
Rear 293 289
Rear 448 463
Bog Stock, uneveness, hopefully because it's sitting on pavers and not bent. All measurements in mm.
All before lunch too.
dodgydan
Purple_Beasty
New Zealand
Re: Need help from xA6x owners Sun, 01 February 2004 08:55 Go to previous messageGo to next message
Thanks Dan, very much appreciated.
Callum
Purple_Beasty
New Zealand
Re: Need help from xA6x owners Mon, 02 February 2004 10:08 Go to previous message
Dan
Could you confirm what point the front measurements were from. Was it the lowest point on the crossmember or fron the point where it mounts to the chassis rails?
Callum
Previous Topic:1uz to w58 gearbox bell housing
Next Topic:diff ratio with 4AGZE or GTE
Current Time: Fri Oct 30 16:32:29 UTC 2026
Total time taken to generate the page: 0.22228193283081 seconds
