Toymods » Tech & Conversions » diff ratio with 4AGZE or GTE
hiaaa
diff ratio with 4AGZE or GTE Sun, 01 February 2004 01:09 Go to next message
Hi! I'm thinking change my sprinter's Hilux diff ratio from 3.72 to something higher, like 4.10 for better acceleration, but they only come with open center and I have to spend extra to get the gears swop over. The only easy one is the 4.30, they come with LSD center but I'm worry that shorten the gear range too much. Any idea?
Leon
Re: diff ratio with 4AGZE or GTE Sun, 01 February 2004 01:17 Go to previous messageGo to next message
4.11 would be my pick. 4.3 works great with NA 4AGE's, but with the extra torque a 4.11 seems to be the answer. However, I can't see the 4.3 being all that BAD, really. What gearbox are you using?
hiaaa
Re: diff ratio with 4AGZE or GTE Sun, 01 February 2004 01:22 Go to previous messageGo to next message
I got a T50 at the moment, but a W57 is on the way. Does the W57 have lower gear ratio than the T50??
Leon
hiaaa
Re: diff ratio with 4AGZE or GTE Sun, 01 February 2004 10:02 Go to previous messageGo to next message
Anyone?
Re: diff ratio with 4AGZE or GTE Sun, 01 February 2004 10:53 Go to previous messageGo to next message
Gear ratios here:
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Gearboxes.html
Re: diff ratio with 4AGZE or GTE Sun, 01 February 2004 15:26 Go to previous messageGo to next message
work out your shifting point in each gear and see which ratio will be better...
higher diff ratio will always be faster, but you don't want to have to change gears too often Wink
i have a 4.2 in my rolla which gives it a top speed of about 175.... 100km/hr is around 4500rpm.. (in 4th, 1:1)
do you go highway cruising much?
hmm, personally i'd go the 4.11 as well...good, but not annoying Wink
EVOSTi
cambo
      no
Re: diff ratio with 4AGZE or GTE Mon, 02 February 2004 06:08 Go to previous messageGo to next message
hmm i was told that my GB was a W59 out of a truck, maybe i could prove/disprove this by calculating what the rpm should be at a given speed, say 4th gear at 100kms? can someone work out the formula for me cause i cant be assed. well i spose you would need to know the circumference of the tyres and all that shit aye, bah i cant be bothered. Rolling Eyes
hiaaa
Re: diff ratio with 4AGZE or GTE Mon, 02 February 2004 08:33 Go to previous message
I don't drive the car much at all, just my fun car, and maybe try to do some track or drifting. I got 4.3 with my NA 4AG before and the first gear is useless (finish too quick) But if it got a turbo to push maybe different story.... I'm confused Confused
Leon
Previous Topic:Need help from xA6x owners
Next Topic:Conversion Costs
Current Time: Sat Oct 31 13:34:17 UTC 2026
Total time taken to generate the page: 0.086878061294556 seconds
