Toymods » Tech & Conversions » kinda weird auto box or diff? issues.
V8_MA61
kinda weird auto box or diff? issues. Sun, 01 February 2004 02:58 Go to next message
Im having some weird experiences with my auto box in the ma70 atm. It is clunking when i am pulled up and change gears, like r to d. It drives around brilliantly and changes both up and down with ease and no clunking. Or could it be the backlash in the diff???
Re: kinda weird auto box or diff? issues. Sun, 01 February 2004 15:28 Go to previous messageGo to next message
check the gearbox mount/s.
put it in nuetral and wiggle the tailshaft with wheels on the ground..... should tell you if diff is loose.
could it be internal backlash in the box?? how would you check on an auto?? hmmmm
V8_MA61
Re: kinda weird auto box or diff? issues. Mon, 02 February 2004 09:36 Go to previous messageGo to next message
uni's seem to be ok, but yeah im thinking it may bwe the backlash in the box as well..but im fucked if i know how to fix it!
Re: kinda weird auto box or diff? issues. Mon, 02 February 2004 12:09 Go to previous messageGo to next message
take to auto-trans shop and then bend over for some serious cash-extraction.... or
.. there might be some notes 'out there' about about adjusting them gearboxes (limited to gaps between solenoids/plungers and bands).
tried the electric transmission articles on <http://www.autoshop101.com/autoshop15.html> ?
can you get under it and identify the model of gearbox? the 1G-GTE uses an A340E gearbox - but your 7M might have improved hardware behind it.
V8_MA61
Re: kinda weird auto box or diff? issues. Mon, 02 February 2004 12:11 Go to previous messageGo to next message
charles yeah mine is an a340e
Re: kinda weird auto box or diff? issues. Mon, 02 February 2004 13:12 Go to previous messageGo to next message
am at a loss here - fluid level OK?
otherwise, google i think might helpful ... the autoshop PDFs that i have locally don't talk about diagnosing mechanical faults like 'clunks' ... ;(
V8_MA61
Re: kinda weird auto box or diff? issues. Tue, 03 February 2004 12:10 Go to previous messageGo to next message
do you want to sell your a340e charles?
HighRolla
icon2.gif  Re: kinda weird auto box or diff? issues. Thu, 04 March 2004 08:44 Go to previous messageGo to next message
Hey V8 MA61 - Did you solve his problem of clunking into P or reverse. A friends corolla jolts going into reverse but drives really well? Wondering if you solved your problem?
[Updated on: Thu, 04 March 2004 09:08]
dingaling
tas
Re: kinda weird auto box or diff? issues. Thu, 04 March 2004 14:13 Go to previous messageGo to next message
clunking here too.
My a340e transmission is shocking when i go from P to R. It shakes the whole car as if you were hit up the ass from another car. It's very worrying. It also does it when i go to D but not much.
This shouldn't be happening becuase the auto trans was recently reconditioned. Could it be the trans fluid? I will check my diff for looseness tommorow. It drives fine otherwise.
would love to know why it does this. I know these transmissions are also used in lexus's and are known to be very smooth transmissions.
clubagreenie
1st street on the right
Re: kinda weird auto box or diff? issues. Thu, 04 March 2004 20:16 Go to previous messageGo to next message
Check the fluid type, well known that toyotas only like toyota type 4 fluid evn if dextron is spec. Check this article at http://planetsoarer.com/autotrans/autotrans.htm . Talks about shudders and clunks and the fix.
HighRolla
Re: kinda weird auto box or diff? issues. Thu, 04 March 2004 22:13 Go to previous messageGo to next message
I read the article but it doesn't seem to offer any suggestions except a change of fluid (i did only skim maybe missed something)... I suppose it could be that simple. We know an auto specialist so might get him to have a look at it for a 6 pack (the corolla). The box has been reconditioned by the previous owner only 2 months ago..so if the mechanic tells me something bad I'll be taking the car back to where the trans got "recondidtioned".
HighRolla
Re: kinda weird auto box or diff? issues. Fri, 05 March 2004 10:08 Go to previous messageGo to next message
The auto dude reckoned it was mainly a broken gearbox mount causing the noise.. he said fix that and see if it stops it. I'm going to post a thread to find out where I can get these types of mounts cheap.
clubagreenie
Re: kinda weird auto box or diff? issues. Fri, 05 March 2004 22:28 Go to previous messageGo to next message
I agree it doesn't allude to all possible causes of clunks but basically if the auto doesn't have the correct oil then it will as the clutches slip/grab trying to cope. Kind of like puting standard oil in a LSD. Makes the same sorts of noises.
EDIT: didn't see second reply re mount. This too may do.
[Updated on: Fri, 05 March 2004 22:32]
dingaling
tas
Re: kinda weird auto box or diff? issues. Sat, 06 March 2004 02:24 Go to previous messageGo to next message
my tranny mounts are good, no play in the shaft either.
the supra manual says to use dextron 2, my auto trans dipstick has "dextron II" written on it. Would it be a bad idea to put this toyota type IV in there?
clubagreenie
Re: kinda weird auto box or diff? issues. Sat, 06 March 2004 07:29 Go to previous message
not from what I've heard, it's said that it smooths out shifts etc
Previous Topic:ra 40, brake ungrade
Next Topic:Some facts on dropping a 3SGTE into your Celica
Current Time: Sun Oct 25 05:45:53 UTC 2026
Total time taken to generate the page: 0.0053660869598389 seconds
