Toymods » Tech & Conversions » Reving Problem
Corolla Boy
icon5.gif  Reving Problem Tue, 06 August 2002 13:10 Go to next message
I own a AE82 corolla (Carbie), when the car is in no gear and I press the accelerator pedel and release, the engine revs (say 2000rpm) but sticks on the 2000rpm for a few seconds then goes down slowley. It dosen't go down the second I release the accelerator pedel like a normal car would. But if I have the aircon on this problem dosen't occur the revs drop down normally. What could be the cause of this engine still reving(few seconds) after I release the accelerator pedel??
ed_ma61
Lost in the K hole
Re: Reving Problem Tue, 06 August 2002 14:34 Go to previous messageGo to next message
sticky throtte bearing, acc cable, goo inside the intake (pcv), gummed up carb jets.
get a can of 'carby cleaner' the $2 stuff, and just go NUTS on the carby and surrounds, with and without the engine running.
ed
Jonny2TG
Tasmania
Re: Reving Problem Tue, 06 August 2002 15:13 Go to previous messageGo to next message
Many engines have a device to deliberately slow the throttle closing. This reduces nitrogen oxides or something. Even efi cars have it. It looks like a daphram thing with a rod sticking out into the throttle linkage. Sort of like suspension for your throttle.
Corolla Boy
Re: Reving Problem Tue, 06 August 2002 22:28 Go to previous messageGo to next message
Thanks for that ed I'll try it and see how we go
Corolla Boy
Re: Reving Problem Tue, 06 August 2002 22:30 Go to previous messageGo to next message
Yeh Johnny true, but the thing is that it wasn't doing it before
Karl_skewes
New Zealand
Re: Reving Problem Wed, 07 August 2002 07:31 Go to previous messageGo to next message
this on 2TGEUs Jonny?
I've just fixed my throttle so i get 100% instead of 80%. It was as simple as flipping the cable holder 180deg and adjusting out the slack again Razz
BTW: what are the 2 air tubes on the diaghram for idle air bypass for?
ae102_3sgte
Canada
Re: Reving Problem Wed, 07 August 2002 10:54 Go to previous message
Does your car have an A/C idle up diagphragm linked to the throttle?
When they get old they can spring a leak, causing symptoms like you describe. Ones that I have seen bump up the idle when there is no vacuum applied.
Previous Topic:18RG with electronic ignition into RA23
Next Topic:boost tacho
Current Time: Fri Oct 30 20:19:11 UTC 2026
Total time taken to generate the page: 0.0046019554138184 seconds
