Classifieds » Miscellaneous » ***BARGAIN*** SW20 MR2 TRD Engine Mounts + other bits
bbaacchhyy
***BARGAIN*** SW20 MR2 TRD Engine Mounts + other bits Sun, 01 February 2004 22:41 Go to next message
I have for sale (from imported 1/2 cut. A set 3 of the four - both side and front mounts) TRD Engine Mounts for the SW20 MR2.
These were removed from a 92 Turbo 1/2 cut as part of a previous project, and now they need to be cleared from the shed to clear the Visa card Shocked that came in the other day.
They are a little dusty, but otherwise, top condition. New, the set costs over $400, but that is without postage, duties and taxes. Part numbers are 12361-SW211, 12372-SW211, & 12362-SW211
Great for those hard launches, and easy to install
Asking $299, but any sensible offer will not be refused Very Happy
I also have :
  • a set of rear 91/92 taillights + garnish $100 ono
  • a pair of '93+ rear calipers (as is $100, or rebuilt for $150)
a set of rear 91/92 taillights + garnish,
Michael Bhttp://forums.toymods.org.au/index.php?t=getfile&id=3069http://forums.toymods.org.au/index.php?t=getfile&id=3070
Attachment: MVC-829F.JPG
(Size: 61.02KB, Downloaded 77 time(s))
Attachment: MVC-832F.JPG
(Size: 59.74KB, Downloaded 74 time(s))
TerryOBeirne
Redbank Plains,near Ipswi...
Re: ***BARGAIN*** SW20 MR2 TRD Engine Mounts + other bits Sun, 01 February 2004 23:29 Go to previous messageGo to next message
what pads are in the rear calipers??> anything special?????.
bbaacchhyy
Re: ***BARGAIN*** SW20 MR2 TRD Engine Mounts + other bits Sun, 01 February 2004 23:47 Go to previous message
There is no difference in the pads (DB405). The difference is that the discs are larger diameter and thicker than the pre '91 models. It is just a straight bolt up conversion.
The specs from the DBA Catalog ;
12/89 - 12/91.....DBA581 - 263mm dia x 16mm thick
..................(Avail in Std & Slotted)
12/91 on..........DBA583 - 281mm dia x 22mm thick
..................(Avail in Std, Slotted & X-drilled)
Ideal for the budget version of rear brake upgrade when you upgrade the fronts.
When I mean rebuilt calipers, it means with new seals and dust boots.
Michael B
Previous Topic:oil catch can
Next Topic:3T-GTE custom turbo manifold suit CT20-B or CT26 - SOLD
Current Time: Wed Oct 28 18:23:30 UTC 2026
Total time taken to generate the page: 0.022974967956543 seconds
