Toymods » Tech & Conversions » Ig-gte turbo question's
darket69
United Kingdom
Ig-gte turbo question's Mon, 02 February 2004 03:06 Go to next message
Hi .. can anyone tell me if the turbos are sequential or spin up together ..and also is there anyway of upping the boost to a reasonable level without fitting a boost controller ?
Many thanks
Re: Ig-gte turbo question's Mon, 02 February 2004 04:54 Go to previous messageGo to next message
1. The turbos are parallel. Only the 2JZ-GTE has sequential turbos.
2. Bleed valve.
darket69
United Kingdom
Re: Ig-gte turbo question's Tue, 03 February 2004 07:59 Go to previous messageGo to next message
Bleed valve ??? is there anywhere else i can read up on how to :-
1. get one
2. where does it fit and how to fit it Smile
Thanks for the reply
Re: Ig-gte turbo question's Tue, 03 February 2004 08:50 Go to previous messageGo to next message
You can get one from a variety of automotive shops, they are a REALLY simple device. You sit them in the vacuum lines for the wastegate actuator and "bleed" off some of the air that tells the wastegate to open.
darket69
United Kingdom
Re: Ig-gte turbo question's Tue, 03 February 2004 08:56 Go to previous messageGo to next message
so will i need two of them ? .. and if so how do i balance them out? any one got any installed pics?
Re: Ig-gte turbo question's Tue, 03 February 2004 09:02 Go to previous messageGo to next message
There should be instructions for running parallel turbos that comes with the bleed valve.
darket69
United Kingdom
Re: Ig-gte turbo question's Tue, 03 February 2004 09:17 Go to previous messageGo to next message
i was thinking of something like this .. but no mention of instructions :- http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&am p;item=2457154927&category=32094 so any other ideas m8 ?
thanks Smile
Re: Ig-gte turbo question's Tue, 03 February 2004 23:15 Go to previous message
That will work fine, but there's no need to pay so much money for a shiny riceboy valve when it's usually hidden in your engine bay where no-one can see it.
As for instructions, it couldn't be simpler; just find the reference line which goes to the wastegate actuator(s), snip it, and join it back together with the bleed valve. Adjust as necessary and start boosting!
Previous Topic:1jz - order of mods?
Next Topic:Cold Start Injector? Hard Cold Starting
Current Time: Sun Oct 18 01:10:00 UTC 2026
Total time taken to generate the page: 0.0058658123016357 seconds
