Toymods » Tech & Conversions » Nevo pulley install
old_mr2
Nevo pulley install Mon, 02 February 2004 06:49 Go to next message
Guys
I am about to purchase a Nevo upsized pulley for my ZE
just wondering how much for a mechanic to install it in my AW11.
Apparently the right side of the engine has to be dropped down to get at the pulleys. Has anyone here put 1 in themselves??
I dont think I could manage myself......
Is it possible to do it without dropping engine out?? sounds expensive.....
Martin
T APLUS 22
Re: Nevo pulley install Mon, 02 February 2004 08:43 Go to previous messageGo to next message
I my humbelest opinion, the only way you could get access to that without dropping the engine out would be to pull the car apart around the engine. I doubt I've been any help now. Razz
old_mr2
Re: Nevo pulley install Tue, 03 February 2004 00:45 Go to previous messageGo to next message
does anyone have any other info for me
Ben Wilson
Re: Nevo pulley install Tue, 03 February 2004 01:51 Go to previous messageGo to next message
I've put one in, it shouldn't be a big job for a mechanic. That being said, you should replace the woodruff key while you're in there, and that can be a mongerel....
adamb131
Re: Nevo pulley install Tue, 03 February 2004 02:03 Go to previous messageGo to next message
It takes about 5 minutes to undo the 3 nuts on the engine mounts on the drivers side. You don't even need to take the nuts right off the bolt.. just screw them to the end of the tread and the engine will drop about 2 inches. I just did an idler pulley adjustment in my AW11 on the weekend... 14mm soket and about 18inches of extension bars and it is a piece of piss! Crank pulley dunno... never been there... but i imagine you need some sort of puller tool!!! ie not your hand! Razz
old_mr2
Re: Nevo pulley install Tue, 03 February 2004 06:49 Go to previous messageGo to next message
what the hell is a Woodruff Key?
thanks Guys
my mechanic friend should be able to handle it.
I will have a talk to him...
I will let you know how I go Very Happy
Flogbag
Sydney (Campbelltown...!)
Re: Nevo pulley install Tue, 03 February 2004 10:50 Go to previous messageGo to next message
mechanic friend...
hate that line
hate being the mechanic friend sometimes....
if its not ur car giving u troubles its someone elses and expected to be done for free!!
any way about the crank pulley just take the wheel off n the inner guard n get to it from there just give it a spray with wd40 n a lil tap with a hammer if it doesnt come off straight away
do u replace the supercharger pulley or any of the other pulleys with that pulley kit...
[S.T.A.R.S]
ADELAIDE - Lenswood
Re: Nevo pulley install Tue, 03 February 2004 11:10 Go to previous messageGo to next message
not sure about mr2 but i did my timing belt on my rolla which required me to take the crank pulley off.
in the auto stores the crank pulley is called a harmonic balancer, so just buy a harmonic balancer puller from somewhere like repco or someshit for around 15 dollars.
screw it on the pulley and the pulley will slide off. i had the motor held up with a trolley jack under the sump with it lowered slightly caus i was spacing the engine mount out.
i used jason p's trick of having the torque wrench on the pulley bolt whilst giving the starter a quick flick. did the trick really nicely.
Re: Nevo pulley install Tue, 03 February 2004 11:26 Go to previous messageGo to next message
I put one on an AE101 GTZ a while back, you certainly don't have to take the engine out or anything... Actually, it's not that hard at all Evil or Very Mad Even easier with a hoist and a rattlegun, probably take about an hour.
old_mr2
Re: Nevo pulley install Sun, 08 February 2004 14:57 Go to previous messageGo to next message
Cant wait. Pulley to be installed very soon. Thanks for the comments guys.
Flogbag I dont expect anything. I pay him by the hour. jeez...
Spanktown
Inside a giant turbo (syd...
Re: Nevo pulley install Mon, 09 February 2004 02:20 Go to previous message
old mr2, i just did this to my sc mr2 about 3 weeks or more ago, and you notice the difference instantly! much more fun to drive.
Previous Topic:I can't belive I am writing about a subaru, but please help me all the same
Next Topic:ARP head studs for 18R-G
Current Time: Mon Nov 2 13:56:36 UTC 2026
Total time taken to generate the page: 0.0045909881591797 seconds
