Toymods » Tech & Conversions » AE92 Problems getting rego... SOLVED!
Conquest
Sydney/Wollongong
icon9.gif  AE92 Problems getting rego... SOLVED! Mon, 02 February 2004 13:35 Go to next message
No Message Body
[Updated on: Sun, 22 February 2004 13:22]
Grega
melbourne.victoria.austra...
Re: AE92 Problems getting rego... Mon, 02 February 2004 18:31 Go to previous messageGo to next message
get a second opinion, ie: go somewhere else.
walu
Re: AE92 Problems getting rego... Mon, 02 February 2004 20:25 Go to previous messageGo to next message
Depends if Toyota actually recorded all of that on a Pink Slip form. Since they are individually numbered and reported, the RTA can do follow ups when you go elsewhere and get another pinkslip.
At least get another opinion anyway. If they are full of crap, a kock on the door from the RTA should not be a problem anyway.
RobST162
Re: AE92 Problems getting rego... Tue, 03 February 2004 00:19 Go to previous messageGo to next message
yeah it is a pain when you go somehwere else because the info gets submitted to the RTA and they will see that you went somewhere else Sad IN theory you have to go back to the same place
What I would do...
Brake pedal pad? Fair enough & I can replace it myself. Yep good one
Steering rack leaks? Doesn't lose much fluid & I never need to top it up between the 5,000K service intervals.
Just clean up around the rack with a bit of rag and some carby clean/degreaser - whatev and go back. If it leaks that slowly then it won't have time to get dirty on your drive to the shop Smile
Rear muffler corroded? Bulls**t, maybe the tailpipe needs replacing but the muffler itself is in pretty good nick. Tricky. You *may* have to get like a stock?? muffler from a wrecker or somethiing should be cheap as. I paid like $30 for mine when my muffler fell off.
Oil leaks? Again it doesn't lose much oil & only needs replacing at the service intervals.
Just degrease mate
Brakes? Ok so I don't know about this one, but if the rear drums need work then maybe I should consider an upgrade to SX discs if it's worthwile.
Upgrading could be a pain.. new booster? hydraulic lines.. etc etc I dunno enough about how yours is set up. what do they mean by 'work'. You could take them apart and have a fiddle.. adjust a bit. as long as the workshop sees it is 'different' and 'better' you will probably be ok
Rear wheel bearings? Again I don't know about this one.
no idea. if they say so I guess so.. I don't know enough about bearings to know costs and stuff....
New clutch & flywheel? I've been expecting this since i've owned the car but $700 alone sounds like a bit much.
actually that isn't too bad a quote. Sad sounds about right. I imagine they mean a 'machined' flywheel...
hope this is some helpful food for thought anyway Smile
Conquest
Sydney/Wollongong
Re: AE92 Problems getting rego... Tue, 03 February 2004 01:34 Go to previous messageGo to next message
No Message Body
Scorpion
Menai area of Sydney
Re: AE92 Problems getting rego... Tue, 03 February 2004 04:41 Go to previous messageGo to next message
I might have some rear wheel hubs with bearings left over from a rear disc conversion if you really need one or two. Smile
Conquest
Sydney/Wollongong
icon14.gif  Re: AE92 Problems getting rego... Tue, 03 February 2004 07:55 Go to previous message
No Message Body
[Updated on: Sun, 22 February 2004 13:21]
Previous Topic:Removing 18R-G timing gear
Next Topic:Rebuilding my power steering rack...
Current Time: Wed Oct 28 06:21:49 UTC 2026
Total time taken to generate the page: 0.0044660568237305 seconds
