Classifieds » Parts Wanted » engine mount for 3tgte to fit straight into a ta22
spoon_god
engine mount for 3tgte to fit straight into a ta22 Tue, 03 February 2004 00:50 Go to next message
as the topic says, anyone have one of these and want some extra cash?
And leagal in NSW would be helpfull.
roger
Re: engine mount for 3tgte to fit straight into a ta22 Tue, 03 February 2004 01:18 Go to previous messageGo to next message
Do you have the original 3tgt mounts ie the ones that bolt onto your engine? The pasanger side is the one you really need and is longer than the drivers side. Drives sid is a standard 2t one.
if so
I have a modified cross member avaliable the work was done by IDB in richmond I had this in my TA22 for a while. I will part with it at the right price ie $100 + postage. The reason it is so expensive is because it comes with negatice camber pins and the neccessary modification to the crossmember (pins and mounts) cost me $250
CLG
Perth, Western Australia
Re: engine mount for 3tgte to fit straight into a ta22 Tue, 03 February 2004 01:34 Go to previous messageGo to next message
Yep the for the RH Side, you simply use a TA22 steel and rubber mount. For the LH side, you need to keep the original 3TGTE Steel mount to clear the oil return pipe as it's longer. Doing this while using the original TA22 rubber mounts will see you run out of room between the mount and the body mount - hence the need to modify the body mount. I have used a Datsun 200B rubber mount, however this was a compromise, and something I have recently changed, as I wasn't happy with it.
Pick up the cross member above, and I have the engine mounts you need too, will PM you with the details.
Clint
spoon_god
Re: engine mount for 3tgte to fit straight into a ta22 Tue, 03 February 2004 03:29 Go to previous messageGo to next message
roger consider it sold, can you give me a week, need to wait till pay day Sad
roger
Re: engine mount for 3tgte to fit straight into a ta22 Tue, 03 February 2004 04:07 Go to previous messageGo to next message
No worries. The cross member is in bendigo I have to get down there to pick it up anyway and pack it so let me know when you want it by email with your postal address and I will COD it.
spoon_god
Re: engine mount for 3tgte to fit straight into a ta22 Wed, 11 February 2004 00:47 Go to previous message
sent mail roger thanks
Previous Topic:Wnnted: LSD
Next Topic:WTB- 40mm Solexs, needed for parts
Current Time: Fri Oct 23 10:32:35 UTC 2026
Total time taken to generate the page: 0.0075070858001709 seconds
