| Author | Topic |
Fuel setup for 4AGE in AE86
Wed, 04 February 2004 03:16
Hi everyone,
well im finally about to change my engine from a stock 4ac to a 4age.
I want to know peoples ideas on what type of fuel setup to use! I dont know if i should use a surge tank setup or go try and find a efi fuel tank!
Was just wondering what would be the better setup in terms of cost,effectivness,and ease of setup...
ryan
Re: Fuel setup for 4AGE in AE86
Wed, 04 February 2004 04:04
Ease of setup will be a AE86 EFI tank with EFI pump already in it all bolts in!
But... people seem to ask crazy prices for AE86 EFI tanks! There was one for sale on the forum and the dude was chasing $500! yah right.
I've heard AE92? pumps fit in the AE86 tank with some small mods, but still means you have no good baffling.
There isn't much room under the AE86 for a lift pump, surge tank, efi pump etc. You can put in engine bay but not such a good idea as the fuel doesn't get much of a chance to cool down. I wouldn't recommend putting surge tanks and junk in the boot, its illegal and smells no matter how well you seal it.
Sorry just throwing ideas around there...
My AE86 currently has a efi pump cable tied to the tank. Definately not ideal but it was a rushed conversion and well its been that way for 2 + years now and never missed a beat.
I think next time i'll try fitting a pump inside the original tank, maybe get some baffling added also.
Joel
Wed, 04 February 2004 04:40
in my first 86, i used a vl commodore fuel pump mounted above the middle of the diff (nothing got hit/bumped), didn't use a surge tank, just the aussie fuel tank, all worked perfectly, if you want cheap and easy this is the way to go.
matty.
Wed, 04 February 2004 04:53
in my last sprinter i at first i had the surge tank in the "boot" with the lift pump and efi pump there also. noisy, smelly, and definately not legal.
i still put up with it though, until i wanted to sell the car. my solution then was to have a much smaller surge tank made up, which was fitted over on the passenger side of the car, there is a small triangularish shaped area behind a chassis cross brace. i ran all my lines along and mounted my fuel pumps to this. the exhaust runs close to this area too, so i made up a heat shield also.
so there is JUST enough room to run a surge tank under the car, if you want to.
Wed, 04 February 2004 06:21
ok then
sweet thanx for the ideas guys
much appreciated
Wed, 04 February 2004 12:55
I had pretty much the same setup as JDM Hachi on my old one and had no problems
Wed, 04 February 2004 13:09
With the fuel pump above the diff, is that the actual efi pump?
correct me if im wrong but i was told that efi pumps dont like pumping long distances (from above the diff to the engine)
and thats its better to put the efi pump in the engine bay and run a lift pump to it!
Or do u use the existing pump to feed fuel to the efi pump situated above the diff?
sorry about this, its alot better if i had a site with a diagram
or pictures..
thanx for the help anywyas
ryan
Wed, 04 February 2004 20:02
I got a vn pump and tank. Took it too a metal fabrication workshop, got the guy to rip open the vn tank and weld the baffles and all the rest into my standard tank.
All up it only cost about $250 i think it was.
Now i have baffles, efi pump and an endless list of upgrades if i need it.
Wed, 04 February 2004 23:53
I'm doing my fuel setup today actaully...
I've got a Vl turbo pump for $100, theres one screw hole above the diff that is on the angle, best to have the pump on the angle, a bit of common sense when your under there will see what i mean.
i'm using the original fuel lines, like with EFi hoses efi clamps etc,
i've heard many people saying this works perfectly fine, as long as you keep the fuel level in your tank higher than a 1/4
Fri, 06 February 2004 04:05
Well i have decided to go with a surge tank setup, with a vl turbo efi pump.
Does anyone know of a good lift pump to get, to feed fuel to the surge tank??
Fri, 06 February 2004 04:11
For a lift pump i use a "fuel flo" electric pump which was purchased from pep's for $80. mounted it above the diff
Fri, 06 February 2004 05:23
try an 85' mazda 626.. i pulled a facet pump out of one so i'm not sure if it is standard or not. make sure it is not gravity fed.
Fri, 06 February 2004 05:57
I can get you an AE86 efi tank for 300
If you want it pm me
Good Luck
Fri, 06 February 2004 14:46
Might head down to Holley Performance Parts, in flemington and check out the 97 GPH "Red" Electric Fuel Pump, should provide sufficient fuel flow to the surge!!
heres what im on about!!
http://www.holley.com/HiOctn/ProdLine/Products/FMS /FMSFP/12-801-1.html
also vl turbo efi pumps aint cheap...askin $280(new)
might have to check out a few wreckers!!
Fri, 06 February 2004 22:57
if you are "only" upgrading to the 4age, just get a normal vl fuel pump (non- turbo), should cost about $150 brand new, or go to a wrecker and get a second hand one (even a tired one will more than likely pump enough fuel for a 4age.)
matty
Fri, 06 February 2004 23:23
are the normal vl fuel pumps external like the turbo one??
Fri, 06 February 2004 23:35
yeah they sure are, thats what i used, with the budget setup i had, i never even had issues with fuel cut-out (with low tank level) so make the decision to get a surge tank after you give this setup a go, i used the factory fuel lines also, (ie 4ac), so technically for $100-150 should see you right all up, including filter, hoses, clamps, etc....., i know that "they" say that the 4ac fuel lines are inadequate but they served me fine, the import that i have now seems to have the same size lines, i have a gze and sr20 turbo pump mounted in my tank and have never had any issues. good luck.
matty.
Fri, 06 February 2004 23:39
oh ok thanks for the help matty,
much appreciated...
Sat, 07 February 2004 02:38
well just got back from the wreckers, picked up a vl efi pump, and a electric fuel pump (to act as a lift pump to the surge tank) from a old mazda 929..hopefully it works ok..
came all up to $50 so wasnt to bad, just have to get them all cleaned up now!!
