Toymods » Tech & Conversions » 4A-C Head Gasket change
CamZH
Toodyay, WA
4A-C Head Gasket change Wed, 07 August 2002 10:34 Go to next message
Hey guys,
I've just offered to change the head gasket on a 4A-C, in a AE82.
Is there anything that i should look out for when doing this?
Do these things normally have a problem with head gaskets?
Apparently this one was change and the head was recod only 18months ago...
thanks,
CamZH
Re: 4A-C Head Gasket change Thu, 08 August 2002 04:35 Go to previous messageGo to next message
4AC's can be a little bit 7Mish this way, if they start going through gaskets, then theres a good chance that block is a bit twisty...
haggis
Re: 4A-C Head Gasket change Thu, 08 August 2002 05:41 Go to previous messageGo to next message
You shouldne have any problems with changing the head gasket. I did mine in about 4 hours by myself.
I left the inlet and exhaust manifold on the head, saving the need for replacing 2 gaskets. Makes it all a bit heavy to lift tho.
Like mrshin said, if you can, check the head and block for warping. Also look to see if there is any pitting on the edge of the cylinders or water jacket. They are quite close in a few places!
You will need to remove the cam and rockers to get to a couple of the head bolts, so make sure you check the timing marks!
CamZH
Toodyay, WA
Re: 4A-C Head Gasket change Thu, 08 August 2002 11:36 Go to previous message
Heavy?
Ha!
I'm used to working with old 6's and V8's!
Good ol' cast iron is good for buffing you up Razz
I'll make sure i check the block out, the head was recod when the gasket was done.
CamZH
Previous Topic:backfiring and poping
Next Topic:Gen4 3sgte wiring diagram
Current Time: Mon Nov 2 13:15:25 UTC 2026
Total time taken to generate the page: 0.078201055526733 seconds
