Toymods » Tech & Conversions » fuel lines in a ta22
spoon_god
fuel lines in a ta22 Fri, 06 February 2004 00:37 Go to next message
just a quick question hopefully someone will know, did a search first couldn't find it covered in past threads. Are the fuel lines in a ta22 large enough to handle the flow of a vl pump for a 3t-gte?
Re: fuel lines in a ta22 Fri, 06 February 2004 03:12 Go to previous messageGo to next message
The fuel lines in a TA22 are designed for a suck-through carby pump, but you're replacing that with a high-pressure EFI pump which is pushing the fuel through the lines. Unless you're chasing huge power (like 400hp up) the stock lines will be enough.
[Updated on: Fri, 06 February 2004 07:12] by Moderator
spoon_god
Re: fuel lines in a ta22 Fri, 06 February 2004 03:51 Go to previous messageGo to next message
thanks guys, I hope your right Norbie, it's just stock at the moment, and getting it running is my priority, so I will try it your way but thanks boris for the insight
rob_RA40
c'town, NSW
Re: fuel lines in a ta22 Fri, 06 February 2004 03:54 Go to previous messageGo to next message
u have nothing to worry about, norbie is right. I have had a ride in a very tricked up TA22 3T-GTE (unconfirmed approx 350-400hp) and he was running std fuel lines no hassle.
spoon_god
Re: fuel lines in a ta22 Fri, 06 February 2004 04:11 Go to previous messageGo to next message
thanks Rob, good to hear
roger
Re: fuel lines in a ta22 Fri, 06 February 2004 04:27 Go to previous messageGo to next message
Norbie is right
than standard lines are fine, I ran mine on it for ages. By the way VL,VLturbo, JE, JD camira run the same pump
boris
On probation
Brisbane, Queensland
Re: fuel lines in a ta22 Fri, 06 February 2004 04:32 Go to previous messageGo to next message
brain fart Embarassed ... i meant to say 5/16. But if you all agree that the fuel lines can remain standard than thats what i will be doing.
hemi twofifteen turbo
Re: fuel lines in a ta22 Sat, 07 February 2004 05:21 Go to previous messageGo to next message
roger i don't know if that's correct about the vl, vlturbo, & camira running same pumps. VL turbo pumps are meant to be different i think...
Re: fuel lines in a ta22 Sat, 07 February 2004 05:27 Go to previous message
Compare the part numbers, you'll find they are in fact the same.
FWIW I'm running a JE Camira pump at the moment and it works great.
Previous Topic:Taking delivery of my first Toyota next Sat. need advice
Next Topic:Fuel Econ.Single or Twin Turbos.Which is better
Current Time: Tue Oct 20 12:49:04 UTC 2026
Total time taken to generate the page: 0.017409801483154 seconds
