Toymods » Tech & Conversions » Pedal box for ke25 hydraulic conversion
Rob20v
Geelong
Pedal box for ke25 hydraulic conversion Wed, 07 August 2002 12:30 Go to next message
Could anyone please tell me what pedal box i could use in my ke25to do a hydraulic conversion.
Preferably something that would allow me to fit a brake booster to the firewall (rather than using a remote booster).
I am also fitting a 2tg, (trying to make a levin copy)
Also interested in what brakes /struts would be a good upgrade without having to modify lower arms as everything I have looked at in Toyota range have different length lower arms.
Any help would be great.
Jonny2TG
Tasmania
Re: Pedal box for ke25 hydraulic conversion Wed, 07 August 2002 15:17 Go to previous messageGo to next message
I have done this to my KE35 (full levin copy). And I think you will just have to take the pedalbox out, modify it yourself with a bit of thought, a hacksaw, a welder, and a celica clutch pedal and box to copy. No easy way. Unless you get a TE20 pedal box sent from Japan.
Seadog
Re: Pedal box for ke25 hydraulic conversion Wed, 07 August 2002 20:13 Go to previous messageGo to next message
Hey! I'm in Canada at the moment, and over here they have TE2? with 2T's in them and they have hydraulic clutches. Of course it's all left hand drive stuff but the pedal box wouldn't matter. Don't ask me to bring one back though, I'm leaving tonight.
Jonny2TG
Tasmania
Re: Pedal box for ke25 hydraulic conversion Wed, 07 August 2002 23:34 Go to previous messageGo to next message
Um, yes, I think there would be a difference with the Left hand drive version. It would not just bolt in.
Rob20v
Geelong
Re: Pedal box for ke25 hydraulic conversion Fri, 09 August 2002 05:20 Go to previous messageGo to next message
I have already done this on a ke30 but they are a little easier as they already have a booster and a position for the clutch master cylinder. I modified and fitted a ta22 clutch pedal and just made it fit in the ke30 pedal box. This worked fine but on the ke25 there is less room and no pre designated position for the clutch master cylinder. Just hoping someone has done this and can give me some pointers before I rip into it.
Thanks Cool
Karl_skewes
New Zealand
Re: Pedal box for ke25 hydraulic conversion Sat, 10 August 2002 10:27 Go to previous messageGo to next message
WEll, you might run into clearance issues with your sidies on your 2TG. So... options:
1.) Weld a bolt off the side of the clutch pedal which pushes on Clutch master mounted against firewall.
2.) Run some sort of Bedford van or similar, with remote resorvoir, and everything contained up in the dash.
3.) something else all together.
Jonny2TG
Tasmania
Re: Pedal box for ke25 hydraulic conversion Sun, 11 August 2002 05:54 Go to previous messageGo to next message
Well Karl,
The 2TG came standard in the TE27 Levin, so if he used all the standard bits, its going to fit. In my TE37 type car, I have room for trumpets and socks, but only just.
Rob20v
Geelong
Re: Pedal box for ke25 hydraulic conversion Tue, 13 August 2002 12:00 Go to previous messageGo to next message
I have already done the full 2tg mod on a ke30 and am aware of the clearance problems in a ke25 but have seen 2tg's fitted to standard te27 so I know they fit with a firewall mounted booster and clutch hydraulics. My problem is that I can't get hold of standard te27 parts (I wish) in Melbourne so I was hoping someone might be able to help me locate some or point me in the right direction as to an easy mod.
Any help would be appreciated thanks.
Jonny2TG
Tasmania
Re: Pedal box for ke25 hydraulic conversion Tue, 13 August 2002 12:32 Go to previous messageGo to next message
How is the TE brake booster and stuff different to the KE one? I would have thought the KE booster was smaller, or non-existant, making for more room? You will run out of room if the engine is not mounted in the middle, or in the proper position. Remember that the TE and KE crossmember is different, don't think you can just plonk the engine on the KE crossmember and have everything line up. Well, thats with the KE30 anyhow.
The TE engine is ment to have the crank dead in the middle of the car, and the engine is on a slight lean to the left side.
Hunty
Re: Pedal box for ke25 hydraulic conversion Wed, 14 August 2002 12:23 Go to previous messageGo to next message
Rob20v
could you give me any more information on converting a ke30 rolla to a hydro clutch (2tg is going to be fitted) ie. what pedal box to get from what car ect i heard ta22 ones will bolt up? also is there any modifyong of the box itself? is it just bolt it up and away you go do any fluid lines need to be riged up ect any help greatly appreciated!!
Thanks!
Jonny2TG
Tasmania
Re: Pedal box for ke25 hydraulic conversion Wed, 14 August 2002 14:31 Go to previous messageGo to next message
go here:
http://www.tassie.net.au/~jar
Keep the KE30 pedal box, use a Celica clutch pedal, or some hydralic clutch pedal. Drill the hole in the fire wall for the master cylinder (obviouse place). The pedal box needs to be cut, welded, modifyed. Use your brain. Its too hard to show you over the internet.
Hunty
Re: Pedal box for ke25 hydraulic conversion Wed, 14 August 2002 16:49 Go to previous messageGo to next message
Thanks heaps for your info jonny!!!!!
Rob20v
Geelong
Re: Pedal box for ke25 hydraulic conversion Fri, 16 August 2002 13:52 Go to previous messageGo to next message
Thanks for advice Jonny2tg, I know the ke30 mod isn't too bad to do (have done one I used to race), my problem is that the ke25 (same as ke20 under bonnet in Aus) has no power assistance standard but I have seen them with this so I know they fit. I was just hoping someone could help me with an easy solution to a few drama's I was having. The biggest problem we have doing these mods is the availability of parts in different country's is a drag as different spec cars were not available everywhere and to do them neatly and legally we need to use the right stuff.
Would be interested to know what spec engines were fitted to KE series vehicles in New Zealand to see if any thing was available there.
muv12a
Re: Pedal box for ke25 hydraulic conversion Sun, 07 December 2003 08:43 Go to previous messageGo to next message
if your still interested.... i used a rx-7 series 1 hydrolic master in my KE25 when i did my 12A conversion.
i also used a Ford KB Laser brake master ( with a remote booster)
and they sat real nice to each other. hardly any mods needed to be done to the firewall or clutch pedal....it was easy once we knew what to use.
muv
dr650
adelaide
Re: Pedal box for ke25 hydraulic conversion Thu, 11 December 2003 09:44 Go to previous messageGo to next message
any pics
muv12a
Re: Pedal box for ke25 hydraulic conversion Fri, 12 December 2003 06:27 Go to previous message
see my engine bay pics at;
http://www.cardomain.com/memberpage/463647
Previous Topic:18RU rocker cover oil leak
Next Topic:URGENT need Pics of 2002+ rolla
Current Time: Thu Nov 19 01:09:53 UTC 2026
Total time taken to generate the page: 0.008112907409668 seconds
