Toymods » Tech & Conversions » KE70/TE72 synthesis
SeptemberSquallIndustries
KE70/TE72 synthesis Fri, 06 February 2004 12:24 Go to next message
Just thinking about another potential home for my 2T-G.
Would a KE70 sedan accept a TE72 (T18) engine and transmission crossmember, with 2T-G, T50 and TE72 tailshaft and differential? Or am I missing something?
Edit: New more detailed info below...
[Updated on: Mon, 02 August 2004 13:35]
Re: KE70/TE72 synthesis Fri, 06 February 2004 13:24 Go to previous messageGo to next message
it's been a while since i've seen a TE72, but do they have R&P steering??
do TE72 have rear coils?
in principal it would work, as long as steering is same, and rear spring mounts are same. as long as the 'configuration' of bits is the same, i don't see why it would be hard to swap across. does the TE72 use the KE70/AE86 floorpan??
2TG KE70 would be nice, bit different to the AE70's around
Re: KE70/TE72 synthesis Fri, 06 February 2004 14:06 Go to previous messageGo to next message
there will be some problems...
TE72 does NOT have racoon peanut steering
BUT TE72 driveline does bolt up to the KE70.
There is another option..... TE71!!!! I have only ever seen one of these, at pick'n'payless. Its a KE70 with a 2T or 3T and TE72 driveline.... but again this one has rotating ball steering!
So its possible, but you would have to make up your own engine mounts.
Re: KE70/TE72 synthesis Fri, 06 February 2004 21:41 Go to previous messageGo to next message
But surely if you're using a TE- engine crossmember the 2T-G will bolt to these mounts...?
IRA11Y
Club Member
Re: KE70/TE72 synthesis Sat, 07 February 2004 02:18 Go to previous messageGo to next message
well if you can get the Xmember in then yes it will bolt up.. the trans shouldnt be an issue as theres two sets of location holes and it not hard to adapt something if they dont work out in any case.
im not positive it would bolt up but im geussing it would be pretty close (see,s drill in a though bubble ), but the TE71 i could say with asssured certainty would
ae95
Re: KE70/TE72 synthesis Wed, 11 February 2004 08:28 Go to previous messageGo to next message
the te71 would have been an import and theyre a fair bit different to the t18 we see around.
IRA11Y
Club Member
Re: KE70/TE72 synthesis Wed, 11 February 2004 08:33 Go to previous messageGo to next message
yes they were an import here but came standard as the DX corolla in NZ, and there were lots of them so you should be able to find parts there
STR8 2.8
Re: KE70/TE72 synthesis Wed, 11 February 2004 08:35 Go to previous messageGo to next message
THE WITZL wrote on Sat, 07 February 2004 01:06
Laughing
i like that
Re: KE70/TE72 synthesis Wed, 11 February 2004 12:13 Go to previous messageGo to next message
I actually have 2 TE71s in my backyard at the moment Evil or Very Mad The ae71/ae86 crossmember will bolt straight in, giving you racoon peanut steering, but you'll have to mod the shaft/column to fit onto it yourself Evil or Very Mad
The diffs etc. will all swap straight over no dramas. If anyones interested in the remains of a very rusty TE71, PM me soon, as it's going to get crushed otherwise!
Re: KE70/TE72 synthesis Mon, 02 August 2004 13:31 Go to previous messageGo to next message
Sorry to resurrect this, thinking more seriously about attacking it now.
Crossmembers:
AE/KE/TE are interchangeable.
TE (ie. TE71, TE72) use recirculating ball steering.
AE, KE use rack and pinion.
Goal:
KE70 shell, 2T-G, rack and pinion.
So:
1. Fit TE crossmember and adapt rack and pinion to suit. Is this feasable, by welding mounts onto the crossmember from a sample KE70 rack maybe?
2. Utilise AE/KE crossmember with rack and pinion and adapt 2T-G to suit (prefer use KE70 member as fitted OEM.)
Is KE crossmember front sump?
Is AE crossmember front sump?
Is the KE/AE steering rack et. al. the same? ie. If using AE71 crossmember will the existing KE rack fit it?
Re: KE70/TE72 synthesis Tue, 03 August 2004 01:30 Go to previous messageGo to next message
why not just go 4age in AE71?
Re: KE70/TE72 synthesis Tue, 03 August 2004 04:42 Go to previous messageGo to next message
Good question. I've got access to a 2T-G and KE70.
Super Jamie
On Probation
North East NSW
Re: KE70/TE72 synthesis Tue, 03 August 2004 05:48 Go to previous messageGo to next message
keep in mind you can't put an older engine in a newer car, for example a 1975 2t-g into a 1980 ke70, unless you run it on lpg
Re: KE70/TE72 synthesis Tue, 03 August 2004 07:03 Go to previous messageGo to next message
Engine is 88260, hopefully will be okay. Thanks for the advice, I'll look into it.
Any suggestions as to the mechanical issue?
Purple_Beasty
New Zealand
Re: KE70/TE72 synthesis Tue, 03 August 2004 09:02 Go to previous message
http://www.arfabuck.orcon.net.nz/KE70-2tgeu.htm
Should have all the info you need for the swap.
Callum
Previous Topic:Help with valve adjustment on 89 Cressida 7m-ge motor
Next Topic:ma70, ga70 body differences?
Current Time: Sun Nov 1 23:01:22 UTC 2026
Total time taken to generate the page: 0.011909008026123 seconds
