Toymods » Tech & Conversions » Urgent Help Need - W57/8 G/box splitting.
ra23celica
icon4.gif  Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 12:44 Go to next message
Guys and gals,
I need help and quick ! Sad
I need to remove the selector arm from a W57 g/box.
This arm is what the ball at the end of the g/stick slots in to.
I have taken off the 9 bolts around the middle of the casing and
the g/box moves apart about 10mm now.
But how do I slide the selector rod out of the arm ?
Do I need to take off the plate around the input shaft ?
Do I thump the 'muther' with a big hammer until the b@stard breaks open ?
All help appreciated.
Mitch.
Re: Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 13:04 Go to previous messageGo to next message
Give Peewee a call, check ur PM's.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 13:44 Go to previous messageGo to next message
Do you mean how do you slide the arm off the rod?
There's a 10mm bolt holding the arm onto the rod, did you pull that out?
ra23celica
Re: Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 14:12 Go to previous messageGo to next message
JCMF - I will give PeeWee a call tomorrow at a more reasonable hour !
BigWorm,
I could mean that - but I'm not good with the technical terms.
The arm/rod was bolted to the shaft with a 12mm bolt. That is out, but I still need to slide the selector shaft far enough 'back' into the gearbox so I can slip the arm/rod off.
Thanks guys.
Mitch.
BigWorm
Turramurra, Sydney.
Re: Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 14:30 Go to previous messageGo to next message
Ah ok, I think I know what you mean.
What's stopping the extension housing from coming off?
I've got a Toyota W58 rebuild manual here, & the only other thing are the 2 restrictor pins either side of the arm bit you're trying to remove. Have you pulled them out?
With those out, the 12mm blt out, & the 9 big bolts, the extension hoising should slide right off.
ra23celica
Re: Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 14:46 Go to previous messageGo to next message
BW - I should not need to pull those pins out as I still have to slide the rod off the shaft - but its late and dark outside, and I am tried and emotional (!) so I will try again tomorrow morning first thing.
Thanks for all your help dude !
Mitch.
gabe
Re: Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 15:04 Go to previous messageGo to next message
Mitch,
Mate remember I have a w58 manual and I split my gearbox only a couple of months ago, so its fresh in my mind!!
Dont hesitate to call mate, I can even come round and lend a hand if you need.
Gabe
PS I am free all weekend and have next week off also.
ra23celica
Re: Urgent Help Need - W57/8 G/box splitting. Fri, 06 February 2004 22:12 Go to previous message
Thanks Gabe,
I will give you a call over the weekend.
I'm just frustrated that I should be able to work this out myself Crying or Very Sad
Mitch.
Previous Topic:3sgte head gasket
Next Topic:Anyone know of good cheap exhaust place in Sydney?
Current Time: Fri Nov 20 05:41:35 UTC 2026
Total time taken to generate the page: 0.01101016998291 seconds
