Toymods » Tech & Conversions » #88261 Head
Syc02T
Lake Macquarie
icon2.gif  #88261 Head Wed, 07 August 2002 13:24 Go to next message
Any one know anything about this head off my 2tgeu. ie. What series, year of manufacture, comp ratio, special thing about the engine etc.
Thanks guys
[Updated on: Wed, 07 August 2002 13:24]
Jonny2TG
Tasmania
Re: #88261 Head Wed, 07 August 2002 15:13 Go to previous messageGo to next message
Head number 11111-88261
is a 2T-GEU engine.
Has double valve springs.
Its the last, or one of the latest 2TG engines made.
1588cc
compression is hard to say for sure unless you get hte pistons out, but probably 8.4:1 or 8.8:1.
It does not have EGR or any strange emissions stuff, but does have EFI, and a oxygen sensor I think, and 5th injector. It has electronic ignition, with mechanical/vacume advance.
It will have TOYOTA DOHC written on the cam cover it big square capital letters, and a plastic oil cap on the rear right side. And will have a thermo fan.
Probably made around 1979 to 1982, and came standard in the TE72 shape Levins, Truenos and sedan corolla GT cars. Also in some TA40 cars I believe.
[Updated on: Wed, 07 August 2002 15:14]
Hunty
Re: #88261 Head Wed, 07 August 2002 17:18 Go to previous messageGo to next message
Is it just me or does Johny have a little too much spare time on his hands?
Just kiddin Johny Smile
Jonny2TG
Tasmania
Re: #88261 Head Wed, 07 August 2002 23:38 Go to previous messageGo to next message
Not too much time, just a mis-use of time. I have so much other stuff to do. Goto go...
Syc02T
Lake Macquarie
Re: #88261 Head Fri, 09 August 2002 08:23 Go to previous messageGo to next message
Thanks Jonny,
I just heard prople talking about the 88260 head and nothing about the 61
Now how do i tell if i have the original 2tgeu block, the engine came with just enough things on it to make it run with the efi in a box and late model solex's on, i don't think i have a thermo because i have the normal clutchless 4 blade thingy.
Jonny2TG
Tasmania
Re: #88261 Head Fri, 09 August 2002 16:05 Go to previous messageGo to next message
To be honest, Im not sure of the difference between 88260 and 88261 heads. I know the difference in cam covers though. But I know the 88260 was avaliable with solex carbies, and EFI as well. You will find the EFI manifold and Carbie manifold is differnt by one bolt. THat will show what the head had on it originaly.
I don't think there is any difference with the block. But the 2TG pistons and pumps are different to the 2T ones. The 88220 and 88222 came with a fixed fan, the same as on 4K engines. The 2TGEU engines all came with a clutch fan, but all these things can be swapped.
I'm not sure how the 2TG oil pump and fuel pumps are different, but I think they have different part numbers. Im not sure what ones I have on my engine.
Also, look for part numbers on the inlet manifolds. The carbie manifold will say 88220 regardles, but the EFI one may say 88264 or something.
Karl_skewes
New Zealand
Re: #88261 Head Sat, 10 August 2002 10:22 Go to previous messageGo to next message
265 for 1 of mine. 261 for another........... yes i have heaps of 2TG(xx) bits Razz
thetoyman75
Club President
Re: #88261 Head Sun, 11 August 2002 13:43 Go to previous message
Jonny,
Just been thru the Aus Spec TA22 parts catalog Smile
The T, 2T, 2T-B and 2T-G all use the same Fuel pump. Obviously the 2TGEU uses and electric pump to supply the higher pressure.
The T, 2T, 2T-B and 2TG also all use the same Oil pump. not sure on the 2T-GEU but I beleive it is also the same.
As for Differences between the 88260 and the 88261 head. Not sure for certain. I am led to beleive the heads are much the same but I would be betting on them having slightly different Cam profiles. I'll have to check the two here out for any other differences if I get the chance.
I have the 88222 caseing here plus the 88260 and 88261 complete heads. Timing covers have long since gotten mixed up tho Sad
Oh and not all 88261 headed 2TGEU's had electronic ignition. Sad
Previous Topic:1JZ Auto Not shifting !!!!!!
Next Topic:Corona Mk2 2JZ progress
Current Time: Fri Oct 23 01:06:21 UTC 2026
Total time taken to generate the page: 0.0067629814147949 seconds
