Toymods » Tech & Conversions » FAQ:: W5* Gearbox Information
Switch to threaded view of this topic Create a new topic
ed_ma61
Lost in the K hole
icon4.gif  FAQ:: W5* Gearbox Information Sat, 07 February 2004 04:15
FAQ:: Toyota W5* Gearboxes
The following is a compilation of prior threads and other available information on the Toyota W series (W50-W58) 5 speed manual gearboxes. It will always be a work in progress, so if feel you have something to contribute, please PM a moderator Very Happy
Last Updated Feb 7th 2004
Relevant Toymods Threads
What cars came with what gearbox::
http://forums.toymods.org.au/index.php?t=msg&t h=28643&start=0&rid=92&S=c5202163cebb1 441b11372f45fdb293e
What to look for when buying a w58 box::
http://forums.toymods.org.au/index.php?t=msg&t h=28561&start=0&rid=92&S=c5202163cebb1 441b11372f45fdb293e
Difference between w5x and R154 gearboxes::
http://forums.toymods.org.au/index.php?t=msg&t h=17358&rid=92&S=c5202163cebb1441b11372f45 fdb293e&pl_view=&start=0#msg_141484
Identifying the w50 gearbox::
http://forums.toymods.org.au/index.php?t=msg&t h=11112&rid=92&S=c5202163cebb1441b11372f45 fdb293e&pl_view=&start=0#msg_89225
Which box is stronger::
http://forums.toymods.org.au/index.php?t=msg&t h=145&rid=92&S=c5202163cebb1441b11372f45fd b293e&pl_view=&start=0#msg_850
Changing shifter positions::
http://forums.toymods.org.au/index.php?t=msg&t h=24970&rid=92&S=c5202163cebb1441b11372f45 fdb293e&pl_view=&start=0#msg_214308
Changing speedo drive gears::
http://forums.toymods.org.au/index.php?t=msg&t h=21974&rid=92&S=c5202163cebb1441b11372f45 fdb293e&pl_view=&start=0#msg_181753
Bellhousing Bolt Pattern Compatability with other boxes::
http://forums.toymods.org.au/index.php?t=msg&t h=46207&rid=92&S=be5f168aa61a68d3b0f62484f 3cad9ed&pl_view=&start=0#msg_421020
Replacing Worn Shifter Bushes
Green Support Bush = toyota PN# 33505-35020 $15.00
White Pivot Bush = toyota PN# 33548-31010 $7.00
Replacing the shifter bushes::
http://forums.toymods.org.au/index.php?t=msg&t h=15762&rid=92&S=c5202163cebb1441b11372f45 fdb293e&pl_view=&start=0#msg_128763
Other Relevant Web Resuorces
Gearbox tech info (drive ratios etc)::
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Gearboxes.html
Short shifter kits::
http://www.suprasport.com/suprasport/catalog/produ ct_info.php/cPath/31/products_id/204
http://www.celicasupra.com/phpBB2/viewtopic.php?t= 550&postdays=0&postorder=asc&start=0
http://www.perfectrun.com.au/carparts_list/toyota/ supra/suprainteriordressuplist.htm
Available Shifter Positions
http://www.conceptual.net.au/~peewee/Toyota_Supra_5spd_Shifter.jpg
"The above transmissions feature a range of gearshift positions as standard. Measured from the front face of the transmission these are : 18, 20, 21, 21.5 inches."
-MA61 supra is at far left
-MA70 supra - the jury is still out
-JZA80 supra (not pictured) is even further rear-mounted on a cantilever sub assembly
[Updated on: Thu, 16 June 2005 05:02] by Moderator
Previous Topic:Fuel Econ.Single or Twin Turbos.Which is better
Next Topic:Fuel setup for 4AGE in AE86
Current Time: Sat Oct 17 10:54:02 UTC 2026
Total time taken to generate the page: 0.007098913192749 seconds
