Classifieds » Miscellaneous » FS time for a clean out again
IRA11Y
Club Member
icon1.gif  FS time for a clean out again Sat, 07 February 2004 06:42 Go to next message
here goes....
2 x stock sprinter wheels with tyres (no tread) $25
Barina / Swift tow bar $20
18mm aftermarket rear sway bar to suit KE70 ( any BW diff) $50
twin solex custom alloy plenium to suit 18r? $50
3SG coil and igniter, used , $80
small intercooler, suit small turbo mod, $80
86Kw factory ECU $80
Exedy h/d 212mm clutch and pressure plate, used, still good $50
86Kw 1mmOS piston kit brand new never used 20mm gudgeon (100Kw) would be ideal for mild 86Kw turbo build $180
3 X VL commonwhore coil packs, $75 the lot
SOLD AE86 roofline spoiler ( similar to early supra) $80
1 x set 86kw injectors, used, $50
SOLD 1 x set 100kw injectors, used, $50
1 x set 5M injectors, used, $60
AE86 S series diff drum to drum $60
1 x set 13 x 6 hotwire rims, gold, $100
[Updated on: Sun, 22 February 2004 06:21]
Siktoy ra23
Plumpton/sydney
Re: FS time for a clean out again Sat, 07 February 2004 08:48 Go to previous messageGo to next message
Will the diff fit an ra23
[Updated on: Sat, 07 February 2004 08:48]
people100
Rocklea qld
Re: FS time for a clean out again Sat, 07 February 2004 10:59 Go to previous messageGo to next message
how many cc are the injectors. will they suit a small turbo 18rgeu. do they all still work
Dood
Re: FS time for a clean out again Sat, 07 February 2004 11:56 Go to previous messageGo to next message
Any pics of the spoiler?
IRA11Y
Club Member
Re: FS time for a clean out again Sat, 07 February 2004 23:15 Go to previous messageGo to next message
sorry couldnt tell you for sure.
86Kw = 200cc
100kw = 250cc
5M = not positive but either 200 or 173cc
only you will know exactly what your setup is going to be.. i cannot possibly answer that question, sorry Smile
yes they all still work but i advise getting them cleaned before using.
http://www.toymods.org.au/~rod/Other%20Peoples%20Pics%20for%20Forums/IRA11Y/Rear%20Wing.jpg
Dood
Re: FS time for a clean out again Sun, 08 February 2004 05:43 Go to previous messageGo to next message
Ill take the spoiler, pm sent.
Kahless
Re: FS time for a clean out again Sun, 08 February 2004 13:41 Go to previous messageGo to next message
i'll take the 100 kw injectors
ed_ma61
Lost in the K hole
Re: FS time for a clean out again Sun, 08 February 2004 14:49 Go to previous messageGo to next message
IRA11Y wrote on Sun, 08 February 2004 10:15
86Kw = 200cc
100kw = 250cc
5m-e is 185cc/min @ 41psi (pressure rating is a guess from memory - either that or 39psi, but i think its 41psi)
ed
TerryOBeirne
Redbank Plains,near Ipswi...
Re: FS time for a clean out again Sun, 08 February 2004 21:00 Go to previous messageGo to next message
what colour are the 5M injectors??
IRA11Y
Club Member
Re: FS time for a clean out again Mon, 09 February 2004 01:47 Go to previous messageGo to next message
terry, they are beige at the top, ND, 95500-04 1/4 ,5011 2
purpleminiep
Mentone
Re: FS time for a clean out again Mon, 09 February 2004 02:28 Go to previous messageGo to next message
Would the pistonslower the compression of a 100kw motor? All being equal waht comp in a stock 100kw motor
Brad
IRA11Y
Club Member
Re: FS time for a clean out again Mon, 09 February 2004 02:46 Go to previous messageGo to next message
yes they would lower the compression, i cant recall exact compression of the 100Kw from factory.. maybe 9.8?
[Updated on: Mon, 09 February 2004 02:46]
IRA11Y
Club Member
Re: FS time for a clean out again Tue, 10 February 2004 07:10 Go to previous messageGo to next message
Heres some pictures of the pistons, plenium as requested
http://ira11y.qnix.com.au/4sale/
IRA11Y
Club Member
Re: FS time for a clean out again Wed, 11 February 2004 04:08 Go to previous messageGo to next message
Spoiler is now sold
IRA11Y
Club Member
Re: FS time for a clean out again Sun, 22 February 2004 06:37 Go to previous messageGo to next message
bump
IRA11Y
Club Member
Re: FS time for a clean out again Sun, 22 February 2004 06:38 Go to previous messageGo to next message
bump
Les
Re: FS time for a clean out again Sun, 22 February 2004 11:03 Go to previous messageGo to next message
PM Sent re the rims
Les
Green_Comet
Victoria, Melbourne
Re: FS time for a clean out again Tue, 24 February 2004 02:37 Go to previous message
can u send a pic of the 13 x 6 hotwire rims?
interested.... Smile
Previous Topic:Damaged Corolla2 SR (Tercel) for sale
Next Topic:surge tank $100
Current Time: Mon Oct 12 16:50:32 UTC 2026
Total time taken to generate the page: 0.10692381858826 seconds
