Toymods » Tech & Conversions » 1jz ma70 overheating when air-con running
lumpy
Adelaide, SA
1jz ma70 overheating when air-con running Sat, 07 February 2004 15:07 Go to next message
G'day all,
Some dramas with my ma70 supra powered by a 1jz - I've had the aircon regassed recently (gas fell out during conversion Rolling Eyes )
and now with the aircon running the car will overheat/get hot on a hot (30oC+) day. Without the aircon it runs fine (same temp all day every day). Essentially this means I can't run the air-con on hot days - making it damn useless.
I've noticed the jza70 doesn't run a condensor fan like the ma70 did - could this be a problem?
I've "burped" the cooling system with no success and am running out of ideas. Have any jza70 or ma70/71 conversion owners noticed this. I am running a pretty stock 1jz manual , using the ma70 condensor and jza70 compressor.
Caelum
Danish
Re: 1jz ma70 overheating when air-con running Sat, 07 February 2004 19:58 Go to previous messageGo to next message
Hey mate, you should have asked me first! my air-con is being reconstructed, and all the new piping and condenser is back in.
Mine runs at 92C on 25-35C nights without the aircon on, obviously (as it is not fully functional). I noticed it did creep up a bit higher, during the day in 40C heat, again without the air-con on in city traffic to around 100C maybe a little higher.
I will definitely put a big fan on the air-con condenser as it will overheat during a hot day without it. This is easily done with a separate thermostat switch and thermo fan like the ones I have on my radiator.
I'll also mention that my radiator has been reconditioned, and a new water pump and thermostat has been put in, I also have 1 electric gauge on my MicroTech and one Autometer mechanical gauge measuring water temps.
If a large fan over the condenser does not work, then I guess it's time for a thicker aluminum radiator. But I hope that won't be the case.
I am also putting my oil cooler on when I buy the parts off you. That should help a bit too.
[Updated on: Sat, 07 February 2004 20:01]
Cyber-punk
Brisbane, QLD
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 02:23 Go to previous messageGo to next message
you should probably try instlaling a condensor fan of some sort on the inlet side of the condensor
hopefully that will help with speeding up the cooling process and push away the hot ambient air around the condensor away from your radiator
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 07:06 Go to previous messageGo to next message
I thought it was a bit odd that the jza-70 didn't have a condensor fan, but the ma70 did. It looks like I'll try to find a fan and wire it into the exisiting relay/ciruit which should be working.
I do have a new radiator (a cressida one since they couldn't supply a new jza70 one!) and the cooling system was pressure cleaned.
Cheers guys Smile
Danish - I didn't think your air-con was working yet!
V8_MA61
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 08:08 Go to previous messageGo to next message
only the ma70 turbo models had condensor fans
My na ma70 has 3 thermos atm, 2 for cooling and 1 for override/ aircon.
[Updated on: Sun, 08 February 2004 08:09]
Danish
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 12:33 Go to previous messageGo to next message
"(as it is not fully functional). "
hehe Smile It should be by tommorow or tuesday I hope!
7M-Brisbane
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 12:50 Go to previous messageGo to next message
I am only guessing, as I didn't ever pay much attention to this side of things... but if I remember the number of cooling fans is actually dependant on whether the car is auto/manual.
V8_MA61
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 13:56 Go to previous messageGo to next message
mine is auto, so im guessing if that made a difference i should've had more fans, but i only had one 6.5" and the clutch fan.
Stenno
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 21:25 Go to previous messageGo to next message
Leigh you are corret, Manual MA7x Turbos did not have a condensor fan.
Lumpy - did you swap over the radiator from the front cut? if so did you have it cleaned out prior to installing it?
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Sun, 08 February 2004 22:45 Go to previous messageGo to next message
It has new radiator - I was using the front cut one for a while but the plastic top tank was cracked and it was very blocked. I took it to get cleaned and a replacement tank - but despite their earlier assurances the radiator place couldn't find a top tank to fit so I had to get a new radiator - it's a Cressida one from memory, but is exactly the same size and width as the jza70 one.
My car is also really sluggish off the line with the aircon running - it feels like a 4 cyl until it hits some boost. I expected a bit more drag but not to be this bad.
Stenno
Re: 1jz ma70 overheating when air-con running Mon, 09 February 2004 02:39 Go to previous messageGo to next message
are you 100% sure they're the same? Dimensions aside are they the same cores?
From memory the the turbo A70's ran a 3 row radiator but without verifying it for sure I'm probably wrong - I'll do a visual on my radiator this afternoon if you want?
Did you replace the thermostat? 1JZ-GTE's run an 82C thermostat, the same unit that's in the 2JZ-GTE. My 2JZ-GTE cooling temps were between 80-84C on the top outlet when it was on the dyno, and that's using the standard turbo A70 radiator.
Is the system getting air in it?
Danish
Re: 1jz ma70 overheating when air-con running Mon, 09 February 2004 03:08 Go to previous messageGo to next message
I just checked my operating temperature. 94C consistantly at cruising speed, at night on a warm night.
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Mon, 09 February 2004 03:24 Go to previous messageGo to next message
Not sure if they're the same cores - the radiator place said it was but.... If you could have a look that'd be great. Is it the thickness that will tell me the differrence between 2 and 3 core?
I haven't replaced the thermostat - do you think a cooler one would be better in this situation? No air in the system from what I can see (ran the burp test for 20 mins with no foaming/frothing).
Without the aircon running it is always spot on temperature, about 1/3rd of the way up the temp dial.
Skip
Re: 1jz ma70 overheating when air-con running Mon, 09 February 2004 07:02 Go to previous messageGo to next message
Stenno: I thought 1JZ thermostats were hotter than that? Like Danish my car sits on 93-94 degrees celcius.
V8_MA61
Re: 1jz ma70 overheating when air-con running Mon, 09 February 2004 07:42 Go to previous messageGo to next message
Stenno wrote on Mon, 09 February 2004 07:25
If thats the case, then why does my AUTO ma70 not have any type of condensor fan. It only had the one 6.5" sucker.
Stenno
Re: 1jz ma70 overheating when air-con running Mon, 09 February 2004 21:07 Go to previous messageGo to next message
Caelum - Radiator is a 2 row item and about 30mm thick - I'll have to remeasure it as I was in a rush yesturday.
Skip - they both run an 82C thermostat with the same toyota PN. I used a digital thermometer with 1 of the probes running inside the top outlet whilst the car was on the dyno. Either the replacement thermostat I got from Toyota is lazy (opens too early) or the thermometer is waaaaay out (quite possible).
V8_MA61 - There are 3 fans on the radiator, the main clutch fan and 2 small electric fans used when the air con is on - on the auto turbo's there was another fan that was located in front of the condensor on the drivers side, you can't miss it - was yours a turbo or non turbo from the factory?
V8_MA61
Re: 1jz ma70 overheating when air-con running Tue, 10 February 2004 10:24 Go to previous messageGo to next message
non turbo auto. And it has ONE small fan on the inside.
Stenno
Re: 1jz ma70 overheating when air-con running Tue, 10 February 2004 10:29 Go to previous messageGo to next message
non turbo, there is the key word.
Turbo auto's had the fan infront of the condensor, manual turbo's did not. As for non turbo's..*shrugs* who cares Wink
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 02:56 Go to previous messageGo to next message
Thank you to all for the advice, my radiator is about the same size as Stenno's, so I don't think it's that.
I've had plenty of opportunity to play around with the aircon during the weekend (on of the hottest ever in Adelaide!) and it seems to be the car is fine with the aircon running for a short period, then the temp starts to climb and climb. It's almost as thought it it's OK until it reaches a certain thermal load, then can't control it past that.
I've also noticed it gurgles through the overflow bottle after driving on a hot day (whether the aircon is on or not) so I'll try "burping" it again, perhaps on a steeper slope and for a longer time than previous.
Also, the Cressida radiator that's in it has a 0.9bar cap - should this be higher for the 1jz? What is the danger of running a 1.2 or 1.3 bar cap?
Stenno
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 05:43 Go to previous messageGo to next message
running a higher cap pressure means you raise the boiling point. I can't remember the exact numbers, but for every psi of cap pressure you can add 3deg F to the boiling point.
Constant air in the system, could be the radiator cap, a 'tired' hose somewhere in the cooling system, heating system could have a leak, and the list goes on.
How old is the rad cap? I was running a .9bar cap for interests sake.
for interests sake, the Cresida radiator is a different part number to the Supra/Soarer radiator part number, even the cores run different numbers.
I wouldn't put it past the core being the problem, If you were in Sydney I'd loan you my radiator for testing purposes. I may know somebody in Adelaide who *might* have a turbo radiator you borrow, I will get back to you on this.
[Updated on: Tue, 17 February 2004 20:54]
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 06:05 Go to previous messageGo to next message
Would that person be a certain 7m owning Danny T?? Smile
Because I've met him a few times and can give him a ring to see how generous he's feeling. The only forseeable problem may be that the shrould for the hydraulic fan may not fit onto it.
Bloody radiator place - promised the earth and then delivered something I didn't want because they stuffed it up. Plus they blew up my heater core when pressure cleaning the cooling system and flooded the interior!! The heater core/system has been looped out with a piece of hose.... until I can take the dash out and replace it. Crying or Very Sad
Radiator and radiator cap is less than 2 years old.
Thanks for the help Stenno.
Danish
icon13.gif  Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 07:42 Go to previous messageGo to next message
Well I got my car back yesturday and everything is running fine. However, it's about 35-40C today and I went from my house to the airport which is about 50 minutes away in stop and start traffic.
I had the air-conditioner on and it was keeping me very cool and the water temperature was reaching about 95-98C on the drive in. However, I had to turn the a/c off about almost 20 mins to my destination as it was starting to creep up over 100C.
After having the car off for about 20 mins I then started her up and drove home with the a/c on for about 5 mins. I then had to turn it off again because it was getting too hot. I think it registered a maximum of about 110C before it cooled down to 100C again.
I then had to leave it at my dads work to cool down for a few hours before he will drive it home.
Now what can I do? I have the standard GZ20 Radiator which works fine on 30-35C nights, and anything below that. But when the a/c is on it shoots up to over 100C after a while. The 2 thermo fans are set to go on at around 95C and when the a/c is on. I have a small standard inter-cooler.
I was thinking maybe the only choice would be to get a thicker aluminum radiator?
Looks like I am having the same problem as lumpy. Mad
[Updated on: Tue, 17 February 2004 07:44]
Skip
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 07:58 Go to previous messageGo to next message
Quote:
Now what can I do?
Put the windows down you wussy Very Happy
Seriously though, perhaps you should consider a JZA70 or JZZ30 type radiator, i got prices second hand for $250 - $300. Ali radiators are mega expensive, mine is only around 400x450x53 (core size), custom tanks etc. cost around $800, unfortunately this was all i could fit to do the job. Perhaps an off the shelf type from PWR or ADRAD will be cheaper than mine with the custom tanks. Failing that you could always try one of those TRD thermostats, the pros and cons have been discussed before.
[Updated on: Tue, 17 February 2004 08:00]
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 08:00 Go to previous messageGo to next message
Not sure if it'll help, but I may have a Cressida radiator for sale soon... Laughing Laughing Laughing
Is there any difference between a GZ20 and an MZ20 radiator? ie the MZ20 radiator is larger? If so this may be a quick fix, must be a few front cuts and the like with excess radiators?
Danish
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 08:43 Go to previous messageGo to next message
JZZ30 Radiators don't fit. It's a shame aluminum radiators are so expensive. With my new inter-cooler going in, in a few months that will block even more flow to the radiator.
I guess I'll have to find a thicker radiator then?
Just to reiterate, it has a new JZA80 water pump, new thermostat and a reconditioned radiator with a new cap. It also has been flushed with new coolant and distilled water.
[Updated on: Tue, 17 February 2004 10:31]
Stenno
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 21:09 Go to previous messageGo to next message
Lumpy - Yep, that would be him Smile. Ahh that stupid hydraulic fan :S that could pose a problem although the radiator top/bottom tanks *might* not be any different to a normal clutch fan radiator - you should be able to tell straight away if that's the case.
Something else just rang a bell - Are you running the plastic undercover? I did some testing a while back when I had the Anchor M in the car and cooling temps ran 10deg F warmer whilst cruising without the undercover installed.
Danish - GZ20 radiator cores are again a different core part number than the Turbo MZ20/MA70/JZA70 radiator cores - both yourself and Lumpy are having temp problems, and both of you are running non turbo cores - I know what I'd be replacing Wink
As for running a thicker radiator, not always a wise move - you want air to actually flow through the core, throwing a big thicker intercooler infront of the radiator will only make matters worse.
I believe Skip is right - PWR do make an off the shelf alloy radiator for the A70 Supra/Z20 Soarer. I'd be looking into them or trying to source a turbo radiator - however by the time you buy 1 and have it cleaned out it could be worth the extra expense of getting a brand new alloy unit.
Food for thought Smile
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Tue, 17 February 2004 21:49 Go to previous messageGo to next message
No worries. I'll give Danny a shout sometime soon - and we can directly compare radiators.
I am running the plastic underskirt as well - like your testing when I first put the 1jz and was testing it out it would get a fair bit warmer without the underskirt. I know these are important for generating the vacuum/airflow under the bonnet.
It'll be disppointing to have to replace the radiator - the bloody cressida one cost me $400 - almost halfway towards a decent aluminium one. I wasn't happy but didn't have much choice since my jza70 one couldn't be put back together.
Danish
Re: 1jz ma70 overheating when air-con running Wed, 18 February 2004 07:48 Go to previous messageGo to next message
I don't have an undertray! RPM stole it and forgot to put it back on. I know who I will be calling tomorow. I hope they didn't bloody throw it out.
Are you sure they are different sizes? The old 1G was turbo.
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 02:02 Go to previous messageGo to next message
Adding insult to injury the bloody thing has sprung a coolant leak somewhere now as well - looks like it's around the water-pump area. Just more things to do on the weekend.
Hopefully the air-con/cooling system will all be fixed in time for winter Confused . When I have to pull the dash out and replace the heater core. Embarassed
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 11:30 Go to previous messageGo to next message
UNFUNKING BELIEVEABLE!!!!! Shocked Shocked Shocked
I was working on my car tonight, trying to find the source of the coolant leak, when I noticed something jammed between the sump and the plastic underskirt. It looked like a pulley??? So I undid the underskirt to find the outer rim/pulley part of my crankpulley/harmonic balancer!!!!!!
It has sheared off completely around the rubber section of the harmonic balancer. Funnily enough, the seperpentine belt is still running, the alternator and power steering pump work fine as the belt is still running around the rubber stump of what's left of the harmonic balancer/crankpulley.
This may explain why it's overheating when the air-con's running - it's probably not running the hydraulic fan all that well!!
Thankfully the pulley didn't fly off through radiator. Is the 1jz always this bloody tough?!! Shocked
Danish
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 12:08 Go to previous messageGo to next message
Hah! Oh jeebus! w00t! Shocked
spans
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 12:45 Go to previous messageGo to next message
Funny thing that.
Just happened to a mate of mine who has done a manual conversion, but we figured that the harmonic balancer from the manuals was tougher than the one in the auto's. (We both drive JZA70's)
I'm doing a manual conversion to, so we both ordered new crank pulleys to make sure it doesn't happen again.
Undoubtably, this is one of the weaker parts of the 1JZ! I don't really have much of an idea what causes it but would like to know ..
Coincindently, this also happened to another mate of mine who drives a MK4 2JZ not too long ago ...
Danish
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 12:47 Go to previous messageGo to next message
So what actually happens, and where? Is it initially visible before it happens? Does anyone have any pictures of what to look out for?
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 22:30 Go to previous messageGo to next message
Dansih,
I'll show you the remains of mine when you come around. Now I have to find another one...
bbaacchhyy
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 23:32 Go to previous messageGo to next message
lumpy wrote on Thu, 19 February 2004 22:30
Hmmmm, yummy. You are right, lucky no damage done
Michael B
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Thu, 19 February 2004 23:59 Go to previous messageGo to next message
I have got another Harmonic Balancer on the way - now to see if this was the problem or the radiator. I've got access to a jza70 radiator, so I'll measure mine and the jza70 one to compare.
The coolant leak (adding insult to injury) is around the thermostat housing area.
With the balancer fixed, the leak fixed and all new coolant (the top of the range stuff) we'll see if the air-con still makes it overheat. Luckily the weather in Adelaide is a bit cooler this weekend - meaning fewer complaints from the missus about the aircon. Smile
And talking to a few people, apparently it's a common fault on the 1jz's.
MS-75
icon8.gif  Re: 1jz ma70 overheating when air-con running Fri, 20 February 2004 01:49 Go to previous messageGo to next message
Hmmm. Your harmonic balancer outer section comes off completely, and fails to go through the radiator, or break anything else critical AND the belt stays on, staving off any major engine damage.
A small piece of underbonnet insulation comes loose in my car, the turbo ingests the whole bit and suffs it through the motor, wrecking it.
Where is the justice in that Lumpy?
There is no god.
Sad
PS-now you know what that rattling noise was mate, and why it wouldn't do it the other night.......
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Fri, 20 February 2004 02:14 Go to previous messageGo to next message
Yes but.... The water leak was coming from my waterpump, thus necessitating replacement - another $100 spent!!! Razz
So really I had two car problems, but you only had one (complete engine failure) Confused
I know it's wrong of me to whinge!!! And I'm not! I just couldn't believe the BELT STAYED ON! Surprised More arse than class.
Have you had a chance to sift through the remains yet? It's possible the worst engine story ever. I think it means god wants you keep trying but with a bigger turbo next time. And on the bright side, your 4-link rear suspension hung together OK.
Stenno
Re: 1jz ma70 overheating when air-con running Fri, 20 February 2004 09:30 Go to previous messageGo to next message
MS-75 wrote on Fri, 20 February 2004 12:49
And that is why they invent air filters. Unlucky yes, but totally preventable in the first place, live and learn.
Lumpy - Interesting outcome, you'll find out soon enough if it cures your temp problems, best of luck with it.
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Sat, 21 February 2004 13:36 Go to previous messageGo to next message
Ummm... the following is a bit embarassing Embarassed
I had the harmonic balancer replaced, as well as the water pump/engine fan pump on Friday (the water pump was a BIG job - you virtually have to take the timing belt off to get to it)
When the mechanic (manys thanks to Greg - absolute champ!) put all the harmonic balancer etc back together he noticed the fan wasn't pushing much air. We bled the fan pump etc, but it didn't really help. So I compared my fan output with another 1jz conversion and his fan was pushing heaps more air. We were trying to figure it out when he said "It's like the fan control computer isn't working" - at which point I thought "what f**king fan computer"!!!! I couldn't recall installing it...... apparently it controls the fan speed on the 1jz, increasing as the temp increases for more cooling effect. D'oh!
Then, just as I was thinking where I could get a computer from, a fellow Supra owner (Danny T) found it still attached to the dashboard from my half-cut when he was looking at some of my parts for sale!!!! Now I just have to wire the bloody thing in. Also, I may need to change to a jza70 radiator since my Cressida radiator is missing a sensor in the bottom of it. Is this important to the fan control, or does it take it's input from the thermostat?
Embarassed Whoops! I was so proud how neat my conversion is...
Danish
Re: 1jz ma70 overheating when air-con running Sat, 21 February 2004 18:17 Go to previous messageGo to next message
Ah that must explain alot for you then! Smile
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Sun, 29 February 2004 04:31 Go to previous messageGo to next message
Now that I've fixed it.....
It was as simple as;
1. Find plug from engine loom that fits fan computer socket (note that it says "not used" in my handwriting!!)
2. Plug computer in.
3. Marvel at high speed air rushing through the engine bay from fan. Smile
I don't have the bottom of the radaitor temp sensor connected, which seems to mean it's on high all the time but my temp remains constant (doesn't get too cold). However when the aircon is on the car no longer overheats. Ta Da!! Smile
wastegate
Gold Coast
Re: 1jz ma70 overheating when air-con running Sun, 29 February 2004 23:05 Go to previous messageGo to next message
Come to think of it my fan is not pushing all that much air as well Very Happy shame shame shame!
So where is this computer located Lumpy? Dash wise..
wastegate
Gold Coast
Re: 1jz ma70 overheating when air-con running Mon, 01 March 2004 00:08 Go to previous messageGo to next message
Nevermind, had a look on the EPC to where it is, above the ECU sorta. Will have to check that tonight.
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Mon, 01 March 2004 02:16 Go to previous messageGo to next message
Mine in the left corner of the dash, actually tucked into the side part of the dashboard. It was kind of "around the corner" from the glovebox which is why we didn't notice it.
Made a big difference to the volume of air going through the radiator etc.
HKS_TRD
Re: 1jz ma70 overheating when air-con running Mon, 01 March 2004 02:17 Go to previous messageGo to next message
Good to hear you got the problem sorted out!
lumpy
Adelaide, SA
Re: 1jz ma70 overheating when air-con running Mon, 01 March 2004 02:46 Go to previous messageGo to next message
Thanks to your good eyesight! Cool
BabyZ
Armidale
Re: 1jz ma70 overheating when air-con running Mon, 13 December 2004 21:49 Go to previous messageGo to next message
Hey Lumpy (or HKS_TRD),
What half-cut was your 1JZ out of? And what was written on the fan computer box?
The reason I ask is that I am trying to work out the wiring for my fan computer in my 1JZed Cressida. I spent about a month looking around the glove-box for a controller, and eventually found a box marked "Cooling Fan" over above the drivers side kick panel Confused
Being over there, the wiring is more part of the 'body' harness than engine, so I can seem myself having to strip wiring from it and integrate it into the Cressida loom Sad
I have similar issues with the power steering control, but that's another problem Razz My half-cut is a JZX81 (I'm assuming it was a Chaser).
Any help is appreciated Smile
BabyZ
Armidale
Re: 1jz ma70 overheating when air-con running Wed, 15 December 2004 07:13 Go to previous messageGo to next message
Hmmm ... maybe I should have started a new thread ...
oh, and bump ... Rolling Eyes
wastegate
Gold Coast
Re: 1jz ma70 overheating when air-con running Wed, 15 December 2004 10:10 Go to previous message
Well in my JZA70 the plug was part of the engine loom that came though the firewall.
Previous Topic:4age block part number
Next Topic:Dave Marley-Wallace!! Where are you! I want to know about your hilux diff conversion
Current Time: Sun Oct 25 02:58:21 UTC 2026
Total time taken to generate the page: 0.010766983032227 seconds
