Toymods » Tech & Conversions » MX83 head unit
BoB_JonEz
MX83 head unit Wed, 07 August 2002 18:25 Go to next message
I was just wondering if anyone has any details about the factory head unit found in the MX83 Cressida Grande. I read somewhere that there is an external amplifier unit in the console/dash so I was wondering if the outputs from the head unit to that amplifier were similar to preouts in aftermarket head units, and what the output is for the amp.
If I can keep the factory head unit it will be a bonus, cuz a double DIN butt-ugly cd/tape player isn't much use to any thieving bogan, and keeps the car looking like a "granny mobile" as my gf calls it.
Grega
melbourne.victoria.austra...
Re: MX83 head unit Wed, 07 August 2002 22:15 Go to previous messageGo to next message
also bear in mind you have the volume knob and some of the controls on the dash which will be useless if you remove the stock double din radio.
my mate has an mx83 - he uses the stock speakers in his GLX with a CD player which plugs into the aerial connector and a line level convertor to drive a sub woofer - it sounds great!
that said i don't know of any amplifier anywhere in the car (aside from the one in his boot powering the sub)
Re: MX83 head unit Thu, 08 August 2002 05:19 Go to previous messageGo to next message
This is something I had thought about before too for when I can eventually afford an MX83. Best thing would be to rip out the stock unit and actually take a look at the back of it, see what plugs are there, and also look under seats etc. to see if there is an amp hiding there somewhere. That said sometimes it is possible to add pre-outs to a factory head unit.
mx83toy
Re: MX83 head unit Thu, 08 August 2002 14:13 Go to previous messageGo to next message
yeah you can use a converter but been there done that take my advice and dont
id leave the system alone its quite cool but if you like you can check my set up out heaps of subs, amps x 4 mids ,midbase's heaps of tweeters single din head deck the works
they are actually a great car for acustics if you got questions though im all ears
a single din unit is ok and the controls for the original deck will fade in to the background and you wont notice they are there after a while
stevevp
Brisbane Qld
Re: MX83 head unit Sat, 10 August 2002 01:58 Go to previous messageGo to next message
Yep, the head unit has an external amp bolted in behind it.
Its made by Technics and I think its 4x20 watts, I've pulled mine out as the cd player died. You should be able to tap in to the cable between to get the pre-outs for an external amp, but you will need to leave the unit installed as it also controls the satellite switches and volume control.
thunderbird1
Sydney Australia
Re: MX83 head unit Sat, 10 August 2002 04:27 Go to previous messageGo to next message
piss the controls off for the volume etc... thats where the boost gauge should live Wink
LUKE
frebbles
Re: MX83 head unit Sat, 10 August 2002 19:09 Go to previous message
Hey, I've pretty much done most things to that head unit, including removing it altogether...I doco'd it for ppl trying to do the same thing....
You can also use the amplifier without the head unit with some snazzy wiring and plug a discman or something into it as well...But if you are using an aftermarket head unit, you should remove it all together...Have a look at
this.
http://www.infaze.com.au/~frebbeck/tc_sterupg.php
Hope it helps even if just a little, any questions dont hesitate to contact me.
Cheers. fRebs..
[Updated on: Sat, 10 August 2002 19:09]
Previous Topic:AE86/KE70
Next Topic:3S-FE to 3S-GE Conversion
Current Time: Thu Nov 19 10:30:38 UTC 2026
Total time taken to generate the page: 0.0051438808441162 seconds
