Toymods » Tech & Conversions » Quick Question: Will 86kw clutch kit bearing fit 100kw
ae95
Quick Question: Will 86kw clutch kit bearing fit 100kw Sun, 08 February 2004 07:47 Go to next message
Will the bearing from my 86kw clutch kit to suit my 4age ae86 fit my 100kw flywheel,pressure plate.
IRA11Y
Club Member
Re: Quick Question: Will 86kw clutch kit bearing fit 100kw Sun, 08 February 2004 08:10 Go to previous messageGo to next message
depends on what size flywheel and pressure plate the 100Kw is running.. some are the same size some arent, basically the are either 200 or 212mm
ae95
Re: Quick Question: Will 86kw clutch kit bearing fit 100kw Sun, 08 February 2004 10:03 Go to previous messageGo to next message
im going to be using a 100kw flywheel on my 4age ae86 and i have a clutch kit for a 86kw 4age ae86. im seeing what parts i can use with the new 100kw flywheel.
i dont have a 100kw engine. i have a 86kw 4age soon to be a 4agze. i will be using the 100kw flywheel as the 86kw one on the old motor is cracked. the flywheel is a 100kw size, 212mm? i'll be getting another pressure plate to suit this, so im wondering if ill also need a new bearing or i can use the one in the kit?
Re: Quick Question: Will 86kw clutch kit bearing fit 100kw Sun, 08 February 2004 11:08 Go to previous message
Depends exactly what the kit was specified for - when you pull it apart, take a look at the bearing and you'll soon be able to see if it's any good Evil or Very Mad
Previous Topic:custom dials
Next Topic:1GGTE Questions
Current Time: Wed Oct 28 23:04:16 UTC 2026
Total time taken to generate the page: 0.041290044784546 seconds
