Toymods » Tech & Conversions » 1JZ radiator pressure cap
Skip
1JZ radiator pressure cap Mon, 09 February 2004 00:13 Go to next message
What is the pressure rating on the radiator cap for a standard 1JZ considering they run a little hotter than most engines? I ask cause I cant keep any water in my overflow bottle, as soon as i fill it and drive the car it always empties and pisses out everywhere. I have a 16 psi one.
Special Ed
I wanna go Hawaiiiiii.......
Re: 1JZ radiator pressure cap Mon, 09 February 2004 01:51 Go to previous messageGo to next message
I have a trd (hehe what a load of shit) 1.3 bar rad cap. Never had a problem with heat or dropping coolant.
rob_RA40
c'town, NSW
Re: 1JZ radiator pressure cap Mon, 09 February 2004 02:13 Go to previous messageGo to next message
cant say for sure but i think most toyos run water at 19psi.
Stenno
Re: 1JZ radiator pressure cap Mon, 09 February 2004 02:46 Go to previous messageGo to next message
on the JZA70 supras
Stock rad cap is rated to 14.9psi before it will open.
Skip
Re: 1JZ radiator pressure cap Mon, 09 February 2004 04:56 Go to previous messageGo to next message
What do you think might be causing the overflow to spew out water all the time? By the way im not losing radiator water, just the water i put in the overflow bottle.
Stenno
Re: 1JZ radiator pressure cap Mon, 09 February 2004 05:30 Go to previous messageGo to next message
Have you burped the cooling system properly?
Air in the system can/will force the fluid in the overflow bottle to spill out, as can the system being pressurised (blown head gasket).
Check the simple things first, radiator cap, thermostat and make sure the cooling system is free of air.
Skip
Re: 1JZ radiator pressure cap Mon, 09 February 2004 06:58 Go to previous messageGo to next message
How do you burp the system properly? Im sure ive read this before, but i searched and found nothing Sad
Re: 1JZ radiator pressure cap Mon, 09 February 2004 08:32 Go to previous messageGo to next message
Obvious question: are you actually filling your overflow bottle, like all the way to the top? If you do this the bottle will definitely overflow...
Skip
Re: 1JZ radiator pressure cap Mon, 09 February 2004 09:31 Go to previous messageGo to next message
No, only halfway, must be getting a fair bit of pressure in there. The bottle can be completely emptied.
Re: 1JZ radiator pressure cap Mon, 09 February 2004 11:03 Go to previous messageGo to next message
Skip wrote on Mon, 09 February 2004 14:58
I've always found the best way is to idle with the cap off with the front of the car on ramps or the like. Let it sit there till the water at the top of the radiator stops bubbling (i.e. all the air has escaped)
E30-323ti
Re: 1JZ radiator pressure cap Mon, 09 February 2004 20:16 Go to previous messageGo to next message
I've had the same problem Skip.
I have a swirl pot between the top hose and the radiator inlet, this has the radiator cap on it.
If I fill this up (as you'd expect it to be) it spits out to the overflow bottle, I've given up on filling it up and just leave it now, it is usually 1/2 empty (cold) and this allows the over flow bottle to be full.
That all sounds a bit messy doesn't it.
Basically, I can't fill the cooling system up as much as I thought I should be able to, when I do it overflows!!
I'm running a 1.1bar rad cap
Skip
Re: 1JZ radiator pressure cap Mon, 09 February 2004 23:39 Go to previous message
justcallmefrank: Thanks for the advise, ive idled the car with the cap off alot on the flat, but never with the front of the car raised. Will try tonight. Smile
Previous Topic:Turbo'ing a Lexus IS200
Next Topic:*URGENT* How essential are block to bellhousing braces?
Current Time: Fri Nov 20 16:15:39 UTC 2026
Total time taken to generate the page: 0.0087499618530273 seconds
