Toymods » Tech & Conversions » Turbo'ing a Lexus IS200
Clever Hans
Turbo'ing a Lexus IS200 Mon, 09 February 2004 00:31 Go to next message
I am thinkning about turbo'ing an IS200. How strong is the drive train - the 6 speed gearbox and diff?
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 00:36 Go to previous messageGo to next message
A few people, not sure if they're on here have done custom turbo setups. A couple of magazines have featured them, one made 160rwkw.
The 1GFE is pretty tough. The gearbox is the same as used in the S15 200SX, so it should be up to the task as well as the diff. Lexus build quality standards tend to mean that everything is fairly over-engineered.
joorsh
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 01:58 Go to previous messageGo to next message
Didn't they release a turbo is200 in Japan? I think it was badged as an "Altezza". If you looked up the specs on that you could find out if it uses the same components as our lexus is200, or try and get your hands on the Altezza parts if they are different.
-Josh-
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 02:10 Go to previous messageGo to next message
No, the Altezza used a BEAMS 3SGE with 210ps. It was naturally aspirated and used the same box.
gold28
Madrid - Spain
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 02:22 Go to previous messageGo to next message
It's a shame you can't use the gte exhaust manifolds on FE head.
Anyhow, whats the guf on having forced induction on the VVTi head. Doesn't it push in a lot of valve overlap at higher reve. Shurely this is not a desirable thing for a turbo engine. You could probably disable this feature but would it then cause problems with emissions?? Not trying to knock it but genuinly interested in how it would work.
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 08:47 Go to previous messageGo to next message
From my understanding lots of valve overlap on a turbo engine is a bad thing at low rpm, but it's fine at high rpm. Since the VVTi progressively increases overlap as the revs increase I hypothesise it would all work out peachy. Now someone give me an IS200 so I can gather some empirical data. Smile
Soarer
Wollongong
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 09:26 Go to previous messageGo to next message
Norbie wrote on Mon, 09 February 2004 19:47
What about the IS300? It's got VVTi too Wink
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 12:19 Go to previous messageGo to next message
I like the cut of your jib!
Actually that would be very easy to do; you'd just swap in a late-model 2JZ-GTE with VVTi. And now that I think about it, that proves that VVTi + turbo = good. Smile
gold28
Madrid - Spain
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 20:48 Go to previous messageGo to next message
touche' Norbie
KOFFEE-BLACK
Re: Turbo'ing a Lexus IS200 Mon, 09 February 2004 23:48 Go to previous message
Yeah, but who has the $$ to buy an IS300, and start swapping engines!!???
There have been a few turbo ones, but I heard reliabilty gets the better of them.
Check out www.is300.net or http://nz.lexusownersclub.com/forums/
Previous Topic:Car Height
Next Topic:1JZ radiator pressure cap
Current Time: Fri Oct 23 23:32:36 UTC 2026
Total time taken to generate the page: 0.003978967666626 seconds
