Toymods » Tech & Conversions » Increasing Conrod Length
humble
Brisbane, QLD
Increasing Conrod Length Mon, 09 February 2004 02:52 Go to next message
Hi guys,
What are the practical implications of doing this? What are some practical methods of doing this with or without crankshaft modification? Pros and cons? Is increasing the block height with a thicker head gasket applicaable in this case?
Is it cost effective to get a new crank made, based on an existing stock or an aftermarket design? What materials are recommended for the 600HP - 1000HP range? Rough idea on cost (for a 6 cylinder) in terms of fabrication and materials?
Please oppine!
shinybluesteel
melbourne
Re: Increasing Conrod Length Mon, 09 February 2004 03:39 Go to previous messageGo to next message
why do you want to do this? no offence, but you seem to be confused as to what you want.
what you have here is what we in the engineering business like to call "a solution looking for a problem"
as far as i know:
The effect of increasing the length of a conrod is the reduction of inertial loading due to the conrod having to move through less of an angle as the crankshaft turns.
If you think about it, the crankshaft should not need modification at all, unless you want to change the stroke of the engine. it may need modification if you wanted to SHORTEN the con rods, due to them being closer to the crankshaft at BDC.
i am almost certain you would have to space the block with a spacer plate, as using head gaskets wouldnt give you the required height, and would be "as dodgy as all f*ck"
i would not reccomend changing conrod length unless you have a really, really good reason for it.
clubagreenie
1st street on the right
Re: Increasing Conrod Length Mon, 09 February 2004 03:47 Go to previous messageGo to next message
You could lengthen, then either deck the piston or change pin height. Maintains comp ratio and chamber vol either way.
But why? And what engine, perhaps someone knows the solution if we had more info.
Re: Increasing Conrod Length Mon, 09 February 2004 06:38 Go to previous messageGo to next message
Nishad, you would increase rod length by getting new ones made. To use the same block, you just get new pistons made with reduced compression height. You could extract a further mm or 2 by using smaller gudgeon pins - TRD has some lovely 20mm ones rather than the usual 22mm. You would use a crankshaft of standard dimension.
The main reason why one might use longer rods is to increase the rpm at which critical average piston speed is reached (roughly 4000ft/sec). The other effect is that it will increase the dwell time of the piston at TDC - this gives the burning charge more time to act on the piston.
With regard to getting a custom crank made, it is possible, but it will certainly set you back a pretty penny. If this is for a 2JZ, then I think you're probably wasting your time (money) getting it done - the standard crank is quite robust. As an example the JUN stroker kit for the 2JZGTE is about $14000 AUD.
humble
Brisbane, QLD
Re: Increasing Conrod Length Mon, 09 February 2004 09:20 Go to previous messageGo to next message
Hi guys,
Firstly thank you very much for the quick response(s) Smile
ShinyBlueSteel:
Well, the question was an exercise in extracting information from a larger knowledgebase (which is you guys) for the purpose of my personal education to a greater or lesser extent. Oh yeah and then there is my addiction to "Solutions looking for Problems" Smile Good to see that the engineering community hasn't completely lost their sense of humour! (Turns out real estate agents and accountants already have! Sad sad world we live in) Smile
Like Dave explained, the really really good reason(s) for increasing the length of the conrods are;
Due to the reduction in the angle the conrod moves through the cylinder:
- you can increase the RPM at which the "critical piston speed" is reached (thus we achieve a higher reving motor).
- due to resulting reduction in the intertial loading and the pressure on the cylider walls, the motor will tend to increase revs faster (needless to say, frictional losses are reduced).
Due to the change in the velocity curve of the moving piston, the piston "spends more time" closer to TDC, i.e. increases the dwell time around TDC thus giving the burning charge more time to act on the piston during the powerstroke. However, the negative effect of this is the consequent reduction in dwell time around the BDC reducing the low RPM breathing ability of the motor.
I believe you are wrong when it comes to saying the height of the crank has no effect on the conrod length. With everything else being the same, if you reduce the crank height by a x mm, then the stroke is reduced by a factor of x mm, true. However, the length of the conrod will have to be increased by a factor of x/2 mm to ensure that the compression volume to remain the same (because their is a x/2 mm reduction in radius around the axis of the crackshaft).
As for the headgasket are there any disadvantages in this scanario to using the thickest, "robust enough" headgasket (say which has been used in high power super/turbocharged applications to reduce the compression ratio)? Every fraction of a millimeter counts.
Once again, thanks for the adive mate. It's highly appreciated.
Dave:
As always thank you so very much for the quite insightful advice.
I would definitely go TRD gudgeon pins and custom pistons with reduced compression height.
I'm not thinking JUN stroker kit at all. I'm definitely not looking forward to increasing the stroke Smile I was thinking for the worst case scenario, in case I had to reduce the stroke a little in favour of increasing the rod length, I would need a new crank. Smile
I guess increasing the height of the block is unfortunately out of the question Sad
As for conrods/pistons do you know anyone who does good custom conrods/pistons? I need the engine to be able to deal with upto 600HP of power (not that I want it for any conceivable reason, just want to build a nicely over-engineered motor that revs to around 9K+ RPM).
Nishad
CelicaRA45
nth ringwood, Victoria
Re: Increasing Conrod Length Mon, 09 February 2004 09:42 Go to previous messageGo to next message
argo in morpothfor the rods and sps in melb do forge pistons with any pin height you wont
ed_ma61
Lost in the K hole
Re: Increasing Conrod Length Mon, 09 February 2004 10:00 Go to previous messageGo to next message
ey bro!
from thinking about this for about 2 minutes, im thinking the peak velocity of the piston should not be related to rod length as youre suggesting...
peak velocity will occur when the crank angle is 90deg BTDC and 90deg BBDC. a shorter rod will be less than perpendicular to both the crank and piston at this point, and thus the speed of the crank journal wont be 100% transferred to the piston. the longer the rod becomes, however, the closer to perpendicular the rod orientation will be to both the crank and piston, and thus, the velocity of the piston will actaully increase -> approaching the speed of the crank itself.
ie, what im saying is: the longer the rod - the higher the peak piston velocity (approaching the crank velocity - which is governed by stroke length).
i think the main advantage of the long crank is the fact that it travels through less of an arc per crank revolution, and thus your dealing with an accelerating system of lower inertia. it would also put less side forces into the piston, thus reducing friction and wear on the skirts (in fact you could install pistons with shorter skirts - further reducing weight and friction in the reciprocating assembly)
YES!! thicker head gaskets will open up your squish clearance between piston dome and head at TDC which will dramatically increase the likelyhood of detonation at high load. instead, you should aim for normal hg thickness with a TIGHT squish clearance, and concentrate on combustion chamber relieving and piston dome contours to get your totla combustion chamber volume up
cheers mate!
hope youre doing well!!
ed
[Updated on: Mon, 09 February 2004 10:06]
sideshow
Re: Increasing Conrod Length Mon, 09 February 2004 10:11 Go to previous messageGo to next message
why would u want to make the piston go higher out of the block
u really dont want the top of the piston(the outside part) to go higher than block top deck height
so i dont know y u would fit a headgasket to get more clearance so the piston doesnt hit the head
most common is longer stroke on the crank (means crank needs to be modified)
and then you get a shorter conrod
this is how you get stroker engines
if u want over 600 hp and have the engine be reliable
i would suggest a billet steel crankshaft made up from a brand new hunk of steel
i know that an fj20t with about 750 hp built properly with all good stuff and correct procedures with no cutting coners will cost you around 15000 dollars
then dont forget the other 10000 dollars u need to make the rest of the car handle the 750 hp
just remember this when spending big on the engine
it is only 1 piece in a big jigsaw puzzle and the weakest link will always break first
so my answer is fukin expensive
but hey when u want over 600 hp nothin is cheap
so maybe u can go rob a bank first hehehe
Re: Increasing Conrod Length Mon, 09 February 2004 10:14 Go to previous messageGo to next message
sideshow wrote on Mon, 09 February 2004 18:11
In the case of the 2JZ, I'd be making sure it was in good condition, but in no way do I see a need for a billet replacement to be sourced. The engine is very strong from the factory.
CelicaRA45
Re: Increasing Conrod Length Mon, 09 February 2004 11:00 Go to previous messageGo to next message
sideshow by increasing the rod length you also move the pin height further up the piston and can change it from 22 to 20 to give you 2mm in length then you go from there moving rings further up and making them 1.1 mm also and oil control 2mm
sideshow
Re: Increasing Conrod Length Mon, 09 February 2004 11:51 Go to previous messageGo to next message
movin piston higher means machining top of piston
so i dont know y u would go and fit thicker headgasket incase piston comes up higher
i have heard u can run into probs if piston comes too hi out of the block
if engine is goin to rev over 8000 or 9000
then a billet is best way
i know its expensive but if it was a race car or similar then u would want it to be reliable
Re: Increasing Conrod Length Mon, 09 February 2004 12:03 Go to previous messageGo to next message
Supra generally doesn't have to rev that high to make power like an RB26. It has more torque due to its capacity.
Re: Increasing Conrod Length Mon, 09 February 2004 12:06 Go to previous messageGo to next message
humble wrote on Mon, 09 February 2004 20:20
Nishad
Nishad, I was merely using the JUN stroker kit as an example of cost. They supply a billet crank (amongst other things) as part of their kit. If you really had your heart set on a billet crank, I'd suggest talking to Crankshaft Rebuilders here in Melbourne. I'm sure Shuggy could do something for you.
You wouldn't need to reduce the stroke. You could safely move the gudgeon pin up the piston quite a few mm, and by using the TRD gudgeon pins (20mm), you cleverly gain another 1mm. Of course, all this has to be done in consideration with how much boost you plan to run. If you are going to this sort of expense, I'd strongly recommend chatting to an experienced engine builder.
With regard to rods, as Glenn suggested, Argo Engineering in Newcastle or Ridgecrest here in Melbourne would be helpful. With regard to pistons, SPS here in Dandenong are good too.
Allan
Re: Increasing Conrod Length Mon, 09 February 2004 12:07 Go to previous messageGo to next message
You crazy short ass white guy, what ya doing! like you need more power Razz
gold28
Madrid - Spain
Re: Increasing Conrod Length Tue, 10 February 2004 02:30 Go to previous messageGo to next message
I can't see how making the rods longer can be beneficial for reducing inertia. While the angle might be slightly less the mass has increased substantially.???
Yes there may be some negligible change in rotational inertia but you still have more mass to accelerate vertically and horizontally.
roger
Re: Increasing Conrod Length Wed, 11 February 2004 01:03 Go to previous messageGo to next message
I agree to some extent to what gold28 is saying. Do what you need to do to decrese piston accelerations and mass to decress forces on pistons. It is the change in velocity that is a killer not the amount of velocity involved.
[Updated on: Wed, 11 February 2004 01:04]
Re: Increasing Conrod Length Wed, 11 February 2004 23:53 Go to previous messageGo to next message
Correct.
By lengthening the conrod, you will be decreasing the peak piston acceleration. This, in turn, reduces the average piston speed. I am led to believe the current industry standard for maximum average piston speed is around 4000 ft/sec. Of course, by having new longer rods made, the materials used and the forging process will increase their strength and that limit can be upped.
By using a longer rod and decreasing the compression height of the piston, this allows the use of a shorter skirt piston. This will invariably be lighter and also less resistive forces on the bore. That said, if you were going to this expense, you'd probably be considering a moly coating on the skirts as well.
gold28
Madrid - Spain
Re: Increasing Conrod Length Thu, 12 February 2004 00:44 Go to previous messageGo to next message
Sounds like a lot of work in the name of reducing piston accelerations.
The average piston speed is zero, so I assume you are talking about the peak speed which would be inversely proportional to the cosine of the conrod angle. Or by average speed are you referring to the average speed for 1 stroke not 1 revolution. Hoy would average pistion speed be a design factor?? I would have thought peak speed would be a bigger consideration.
What would be the effective order of magnitude change that you are expecting for piston acceleration and consequently combustion chamber pressures?
The material changes could bring some good benefits though.
Re: Increasing Conrod Length Thu, 12 February 2004 00:56 Go to previous messageGo to next message
speed is non-directional, so it's speed curve will look sort of like a sine wave with troughs at 0.
Re: Increasing Conrod Length Thu, 12 February 2004 05:50 Go to previous messageGo to next message
Gold, if you were talking about velocity, I'd agree with you. Draven is right - speed is non directional.
It is a lot of trouble, but nowhere near as much grief as having the motor throw a leg out on you at 8500 in 5th.
And Greg is right, the motion of a piston is similar to simple harmonic motion. The longer the rod, the closer that piston speed graph is to a sine wave.
[Updated on: Thu, 12 February 2004 05:52]
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Increasing Conrod Length Thu, 12 February 2004 06:39 Go to previous messageGo to next message
i have done a lot of long rod conversions on race engines. the usual reason is to get smaller pin to crown height pistons. with the gudgeon higher up in the piston , you get less piston flutter and hence better ring sealing. the arguments about longer dwell time at TDC are mostly theoretical. only a few engines benefit from this, typically those with shit-house combustion design to start with. most performance engines already have optimied rod ratios, eg stroke to rod length. longer rods are relatively simple--pay money. at the cheap end, steal them out of a honda (beautiful rods typically), at the dear end, pay Argo, Carillo etc. They start at $250 each. FYI, all 4AG rods are standard at 122mm .
slydar
Re: Increasing Conrod Length Thu, 12 February 2004 10:57 Go to previous message
i am guessing at this point we are talking about a toyota 1jz or 2jz. have you considered the possibility of the 1j crank in the 2j block?
i will admit alot of what has been said is over my head, but that would give you room for your desired longer rods.
Previous Topic:Bigport 4age loom Problem
Next Topic:wiring diagrams
Current Time: Wed Oct 21 22:03:18 UTC 2026
Total time taken to generate the page: 0.0087850093841553 seconds
