Toymods » Tech & Conversions » 4age Engine check light
Kahless
4age Engine check light Mon, 09 February 2004 04:36 Go to next message
My engine check light comes on when i hit 4k rpm.
Is there any way I can check what the problem is. If so how because I have no idea.
Aren't there 2 pins i can short in the diagnosis thingy and get the error codes somehow. If I can what do the engine codes mean or where can I find them?
Andrew
IRA11Y
Club Member
Re: 4age Engine check light Mon, 09 February 2004 05:29 Go to previous messageGo to next message
short T1 and TE1 and count the number of flashes the engine warnign light gives
demuire
Ipswich
Re: 4age Engine check light Mon, 09 February 2004 12:32 Go to previous messageGo to next message
Where does the diagnostics box usually sit? Based on my wiring loom I'm guessing it's usually in the engine bay? Why put that in the engine bay when the check engine light is in the cabin? Wouldn't that make it kinda hard to check the number of flashes if you're by yourself?
Kahless
Re: 4age Engine check light Tue, 10 February 2004 02:07 Go to previous messageGo to next message
It doesnt start till you turn it on to reds. Its in the engine bay says diagnostics on top of it.
THe errors I got were 12, 43, 52
Any idea what they are?
Kahless
Re: 4age Engine check light Tue, 10 February 2004 02:13 Go to previous messageGo to next message
found them
Diagnostic Trouble Codes - 1991
Toyota
12 Engine RPM Signal.
13 Engine RPM Signal.
14 Ignition Signal.
16 ECT Control Signal.
21 Oxygen Sensor (OS) Signal.
22 Water Temperature Sensor (THW) Signal.
24 Intake Air Temperature Sensor (THA) Signal.
25 Air/Fuel ratio lean.
26 Air/Fuel ratio rich.
27 Sub-oxygen sensor signal.
31 Air Flow Meter Signal.
32 Air Flow Meter Signal.
41 Throttle Position Sensor (TPS).
42 Vehicle Speed Sensor (VSS) Signal.
43 Starter Circuit Signal.
51 Switch Condition Signal.
52 Knock Control Signal.
71 EGR system malfunction.
demuire
Ipswich
Re: 4age Engine check light Tue, 10 February 2004 03:02 Go to previous messageGo to next message
Ah, righty-o Smile In my case my diagnostics box is sitting on the floor (along with the rest of my loom Razz)
Hmm... based on your signals I'm guessing your car is knocking when it hits 4K?
IRA11Y
Club Member
Re: 4age Engine check light Tue, 10 February 2004 05:22 Go to previous messageGo to next message
looks like your knock sensor is stuffed
RobST162
Re: 4age Engine check light Tue, 10 February 2004 05:24 Go to previous messageGo to next message
yep common problem I think.. my mates fell off when we re-did his head gastket on his 4age
light came on.. codes pointed to the knock sensor which was just dangling between the firewall and the block! Very Happy
plugged a second hand one in and reset the puta and everything was schweet!
Kahless
Re: 4age Engine check light Wed, 11 February 2004 01:55 Go to previous messageGo to next message
I got the car off someone that babied it and I dont mean to but I thrash it a bit. I think its in shock at the moment
I'll give the second hand sensor a go. Theres an ae92 at pick and payless with the engine sitting in the boot. might give that a go. If its not the sensor what could be causing it?
[Updated on: Wed, 11 February 2004 01:58]
rob_RA40
c'town, NSW
Re: 4age Engine check light Wed, 11 February 2004 04:25 Go to previous messageGo to next message
Kahless wrote on Wed, 11 February 2004 12:55
dude. its ok to admit u thrash your engine. we are all car enthusiasts here, we understand man Nod hehehe
Kahless
Re: 4age Engine check light Thu, 12 February 2004 14:38 Go to previous messageGo to next message
Cool ok it gets thrashed alot, especially when I leave it at home and half the world tells me its a nice car to drive on my arrival home.
Two different sites said the error 52 is the knock sensor and 53 is the knock sensor bit in the ecu and the ecu is stuffed. I guess I'm looking for a new computer. Where is the ecu located?
Kahless
Re: 4age Engine check light Thu, 12 February 2004 14:48 Go to previous message
all three of the errors the ecu is a possible problem so I'm going to give that a go are the computers the same with all the 100kw 4ages. I have to do alot of work on a friends car tomorrow and he wont notice the computer missing for a few hours Surprised just to test things. His is an ae82
Previous Topic:20/21/22R ignitor wires? [solved]
Next Topic:suspension problem
Current Time: Fri Oct 23 21:57:33 UTC 2026
Total time taken to generate the page: 0.0059559345245361 seconds
