Toymods » Tech & Conversions » 3S-GE qs (again!)
RWDboy
3S-GE qs (again!) Thu, 08 August 2002 04:10 Go to next message
Well, I'm trying to figure something out here, and I'm not completely sure. I need to know what gen 3S-GEs were put in what cars....I've got a slight picture, but I need some clarification.
The first gen 3S-GE was in the ST162 Celica (1986->1989).
They put the 3S-GTE into the ST165 Celica GT-4.
Then what happens from there? They didn't put 3S-GEs in the ST182 or ST18x, they put in the 5S-FE, but Toyota put 3S-GTEs in the ST185 (obviously). They also put 3S-GEs in the SW-20 and the 3S-GTE in the MR-2 GT of that time. Are these the Gen II 3S-GEs/GTEs?
Where would a "Gen III" 3S-GE fit in, because they didn't put a 3S-GE in the ST202 etc etc, but again, resorted to the 3S-GTE in the ST205.
I'm not sure, but did Japan have 3S-GE FWD Celicas in the form of a Celica GT (???) for the newer Celicas (1990/1994), but those didn't see the light of day down here?
st150
Malaysia
Re: 3S-GE qs (again!) Thu, 08 August 2002 06:03 Go to previous messageGo to next message
FWDboy,
Hi there, I'm from Malaysia & I'm using a 3S-GE. I hope I may be able to answer yr question.
OK, you werre right about the first part; the ST16# Celica, then came the ST18# which has the 165ps 3S-GE (I'm using this engine) & after that the ST20# which has 2 versions of the 3S-GE; the 180ps & the BEAMS VVTi 200ps model & the last should be from the Altezza FR which has the 210 ps model.
Are u running a 3S too ? If so, I hope we can exchange some notes on it.
Greetings from M'sia. Grin
[mikey]
Re: 3S-GE qs (again!) Thu, 08 August 2002 09:32 Go to previous messageGo to next message
3SGE
ST162 Celica Gen I Motor
ST182 Celica/Caldina Gen II Motor
ST202 Celica/Caldina Gen III Motor
Toyota Altezza Gen IV Motor (RWD)
Toyota Caldina Wagon Gen IV Motor (4WD)
SW20 MR2 Gen II Motor
SW21 MR2 Gen III Motor
3SGTE
ST165 Celica GT4 Gen I Motor
ST185 Celica GT4 Gen II Motor
ST185RC Celica GT4 Gen II Rally spec Motor
ST205 Celica GT4/Caldina Gen III Motor
There is probably more, but I dont know what else was released in Japan with these...
Michael
ae102_3sgte
Canada
Re: 3S-GE qs (again!) Thu, 08 August 2002 11:06 Go to previous messageGo to next message
Valve lifter/shim diameter increased on the Gen II 3SGTE.
Possibly na too? ( I havent taken the valve cover off of my gen II to check)
I have seen 3 different Gen 1 3SGTE that destroyed 1+ valve shims each.
The new cams have a larger base circle than the old ones, hopefully solving this problem.
Gen I and Gen II 3SGTE have different oil cooler designs.
Gen II 3SGE has an oil cooler under the oil filter. Gen I does not.
Gen II 3sge could also be referred to as a smallport. 'T-vis' is located 1/2 way up the intake runners.
Gen II 3SGTE has a different T-belt tensioner design.
ST150:
Have you put your 3SGE on a dyno?
I am curious how it compares to mine (which has wrong ecu...)
[mikey]
Re: 3S-GE qs (again!) Thu, 08 August 2002 11:47 Go to previous messageGo to next message
3SGTE
Gen II has 8.2mm lift in/ex, 55mm throttle body, ct26a turbo, 8.9:1 comp
Gen III has 8.9mm/8.2mm lift in/ex
Gen III has oil filter next to sump, gen III has ct20B turbo, 65mm throttle body, small ports, diff exhaust ports, stainless top piston rings, lower 8.5:1 comp, larger valves, 33mm in 29mm ex i think
lots of diff things =]
my 3sgte makes 204hp @ wheels...
gen II
standard turbo 14.5psi, front mount gt4 cooler, 3" ex turbo back, K&N pod filter, 8mm leads, ngk iridum 7 plugs, JDM ecu...
bout it...
makes around 210hp@wheels atm..
st150
Malaysia
Re: 3S-GE qs (again!) Fri, 09 August 2002 10:12 Go to previous messageGo to next message
ae102_3sgte,
No mate,
I've yet to run it on a dyno 'coz the area that I live in, doesn't have a dyno setup but I intend to after some upgrading soon. I've some runs with some Honda B16As & I kinda drop their jaw a little Laughing
Attached pleas find some pics of my old car.
Embarassed
Regards.http://nmeconline.tripod.com/carreviews/st150.html
RWDboy
Re: 3S-GE qs (again!) Fri, 09 August 2002 11:13 Go to previous messageGo to next message
So did Australia just get screwed over when it came to the FWD Celica's in the early nineties? Cause I only remember seeing the 2.2 litre 5S-FE engines domestically...???
st150
Malaysia
Re: 3S-GE qs (again!) Sat, 10 August 2002 12:54 Go to previous messageGo to next message
FWDBoy,
Yeap, I guess you could put it that way but look on the bright side, Malaysia's by far worse 'coz the Celica was never brought in at all by the local distributor !! All the Celicas here are brought in a "recondition" units by private importers, meaning refurbished used Japanese cars !! Think about that !!
On the lighter side, the local authorised agent's kind enough to order the parts us if we needed them which'll take about 2 weeks from Japan. I've just ordered a service kit for my power-steering pump a couple of days ago.
So OZ's not that bad after all. We have the 5S-FE in our Camrys. Embarassed
So, have you seen my Frankenstein ?
Embarassed
Regards.
st150
Malaysia
Re: 3S-GE qs (again!) Sat, 10 August 2002 12:57 Go to previous messageGo to next message
FWDBoy,
Embarassed
Regards.
st150
Malaysia
Re: 3S-GE qs (again!) Sat, 10 August 2002 13:11 Go to previous messageGo to next message
Embarassed Oops, sorry for the doublr posting... Embarassed Embarassed
ae102_3sgte
Canada
Re: 3S-GE qs (again!) Mon, 12 August 2002 03:13 Go to previous messageGo to next message
I was wondering about a few things.
Has anyone ever swapped a st165 3sgte block in to a ff celica?
I was hoping to find out if the axle will attach to the back of the block.
I dont feel like trying to line it up and making a bracket.I would be concerned that I would not get the angle right.
Has anyone ever tried fitting the internals from a 5sfe inside a 3sfe or gte block?
I understand that the stroke was changed to get the extra displacement. This leads me to wonder about rod length, piston pin height etc.
For example I know that the deck height of the 7AFE (longer stroke)is higher than its 1.6l brother.
I understand that the deck height is the same on the 5s and 3s engines.
Random thoughts to follow:(fishing for input)
Lots of ideas are swimming around in my head right now, Where would I be if I fit 5S crank with shorter 3sg(t)e rods and pistons
with the idea of building a low compression turbo motor.
Can I get a bit more displacement?
Would I need a spacer plate on the block to stop the pistons hitting the head? would a thicker H/G suffice?
I don't need the engine to live at the redline for hours on end,
but I realize there are limits when you stroke an engine. I have most of the parts to do some trial and error, I would appreciate anyone's thoughts.
(I do not know if it is preferred here to have multiple 3sg Q and A in one thread, or if it would be better to start a new thread-pls tell!)
Edit:
I guess the longer rods would only move the pistons higher in the cyl's. I believe piston speed would be lower though.
[Updated on: Tue, 13 August 2002 00:14]
st150
Malaysia
Re: 3S-GE qs (again!) Mon, 12 August 2002 12:13 Go to previous message
ae102_3sgte,
Well, I guess yr questions are quite similiar to mine, so my guess is as good as yrs Embarassed but the the idea of building a low compression turbo engine's that you can run a higher boost; hope I'm right about this. I learnt that from my friend who's running a 500 Hp SR20DET in a Ford Escort MK II.
Regards.
Previous Topic:Any good engine conversion workshop around sydney??
Next Topic:4A-GZE Wiring Diagram
Current Time: Fri Oct 23 02:06:00 UTC 2026
Total time taken to generate the page: 0.0049409866333008 seconds
