Toymods » Tech & Conversions » T-40/T50 hybrid ?
t_temperley
icon5.gif  T-40/T50 hybrid ? Mon, 09 February 2004 11:58 Go to next message
Had a thought the other day, rebuilding a t50 gearbox using t-40 gear sets for 1 - 4th and using the t50 5th gear.
that way get a close ratio 5 speed.
Has anyone tried this?
Is it even possible?
Tom
Re: T-40/T50 hybrid ? Mon, 09 February 2004 13:46 Go to previous message
pretty much depends on the layshaft, and how the gears are arranged...
usually the layshaft will be shorter on the 4 speed, so will not work in a 4 speed box..
you could get another layshaft machned up, bu tthen you may as well get new gears made up as well....
grab a manual or pull some gearboxes apart and see....
fitting the individual gears onto the mainshaft should be easy tho..
Previous Topic:Quick Q: Where in Perth can i buy a helicoil?
Next Topic:4.5 Litre turbo crown Dyno this friday
Current Time: Fri Nov 20 15:02:45 UTC 2026
Total time taken to generate the page: 0.0050079822540283 seconds
